http://www.manafont.com/index.php?rp=08288
Link shows up now , didnt before
So when you click the link it shows your referral code as 08288. I updated the email to Jim. Now to wait a while for him to reply.
Sorry Old, manafont wouldnt insert your code for me. I went around twice with Jim via email and they wouldnt budge. I'll be buying this one from KD. MANAFONT LOSES AGAIN!
Its not really a big deal , I wouldn't hold that against them ...
Thank you for trying ...
Some times things just dont go to plan ..
The Manafont page shows it as also handling 10440's. Although one would fit it I can't imagine how it could be safe for a 10440. Its charge rate for a semi-depleted sub-3.6v cell is far to high a rate for a 10440.
Is this a so called intelligent charger? Ric from cnquality says the DRY is brighter with unprotected cells (sanyo 2600) but i was going to buy protected 2600 xtar cells. As and inexperienced user, wihtout time to constantly monitor the batteries i think unprotected cells would be unsafe. Unless (what ric told me) the charger is intelligent...
I have charged unprotected cells - and they come out the same as protected ones , 4.19v to 4.21v
I signed up for a new account through this link. I hope you get the points.
Oops, sorry I missed your review Matt! It's now frontpage'd and sticky'd.
Ordered this charger, receiving it in a week or 2 i hope :)
my xtar 2600's are now 8 hours charging and still it doesn't say fully charged, i'm getting afraid that i have a bad charger :s, can't measure batteries as i don't have a meter. Will ask a neighbour if i see him.
Take it easy, it is a very slow charger and your batteries might end up above 4.2 volt.
Seems about right my Ultrafire grey 2500mAh take 6Hrs to charge on my Ultrafire wf139.
I'll have some more patience then just thought 2600mah/500mah = around 5 hours, but i was told good batteries also charge slower... So i will see :)
The WF139 is fast compared to TR003P4
If the charger does use a CC/CV algorithm a good estimate is to add 50% to the calculated value. The CV phase slows things down.
The TR003P4 does not exactly charge with 500 mA, 150 to 200 mA would be more correct. If the batteries are empty it will take more than 12 hours to charge.
ow that's a lot slower than expected, but as long as it's a good charger i can get over that!
First battery is charged after 9 hours, put it in my KD C8 and wOWOWOWOwowowooot!
The light i owned before seems to put out 75 lumen max if i compare to the low of this light, just sick ... and then i still have a NW dry coming up :o
Thats very nice of you Chicago. Have you ordered anything from manafont yet? I just opened a new account through the same link and it didnt indicate that the referral was successful.
Trustfire TR003p4 15.19 usd (13.67 usd with coupon "DINOGIFTCARD") in Dinodirect http://www.dinodirect.com/li-ion-battery-fast-chargers-multifunctionl-cylindrical.html
Does anyone with this charger feel the battery in slot #1 is warmer than slot #2 and so on? Not that the heat is really noticeable just slightly warmer down the line. I am currently recharging Samsung ICR18650-22E recovered from an old laptop cell. So who knows the battery state, but I just think it's a little weird that the slot #1 battery is heated a bit and the slot #4 battery is cool as a cucumber. (All reading the same charged voltage btw)
