Efest IMR18650 3100mAh (Purple) 2014
Official specifications:
- Top: flat top
- Bottom: non-protected
- Typical Capacity: 3100mAh
- Min capacity: 3100mAh
- Max discharge current: 10A
- Pulse discharge current: 20A
- Quick charge current: 3000mA (1C)
- Quick discharge current: 2000mA
- Cycle life: 300 times
- Charge cut-off voltage: 4.2V ± 0.5V
- Charge cut-off current: 5A
- Initial Impedance: Max: 15mOhm
- Discharge cut-off voltage: 3.0V
- Temperature: discharge temperature range:-10°C—60°C, charge temperature range: 0°C—40°C
- Storage: 1 year:-20°C—25°C, 3 months:-20°C—45°C, 1 month:-20°C—60°C
- Size: weight: 50g, Length: 65 mm, Diameter: 18mm
High power and high capacity in the Efest purple line of high current cells.
Looking at this curve I will say that 20A is a bit high for continous load, but 10A is handleded very fine.
I had an accident during testing and I am missing one cell in some tests. The problem was that my load did not turn off after the 20A and discharged the cell completely.
Conclusion
The cell cannot match the ultra high current cells in power, but easily surpass them in energy at 10A. This is very good performance.
I will call it a acceptable cell.
Notes and links
Compare to 18650 and other batteries
