Cool review! Thank you ;-)
too funny! Hope Jane enjoyed it.
Are you having a 50% of sale on this?
Great job, thanks for sharing!
Yes I am, but please consider that the output will also be a bit less than stock.
now that truly belongs in a flashaholic museum
This made my day. I couldn’t help but LOL when I saw the bare piece. Thanks! Fresh, never-done-before review for an old school light.
Simply the best sk68 review ever!
+1
Very nicely done, thanks!
Yeah great job!
The main design problem, aside from the hollow pill, appears to be the thin section between the bottom of the pill and the finned part of the body. This may keep it from becoming too hot to hold, but it reduces the cooling of the led. A way for a clone maker to avoid that may be to make the light slightly longer and overlap the pill with the thick finned section. Or one could make the head thinner and the front of the body thicker. In practice, the finned section heats up about as much as the head does, so it may not be a serious problem. The overall thickness and the well shaped fins imply importance of thermal management, so these problems threaten its right to dominate it class.
An aftermarket fix for the hollow pill is to use a thicker star.
(The one I am working on with an XM-L2 on a Noctigon draws two amps. from an IRM, so I want to braid the tail spring/switch.)
Brilliant
It shows just how little metal to metal contact there is with a screwthread :weary:
Cheers David
I use thermal compound on all my lights with screw in pills and on most of the really high power ones at the head:body connection. Dont forget that on higher quality lights the threads are going to be more precision cut leading to a better amount of surface contact.
I’m surprised the lens cut so cleanly! I’m also surprised to see copper inside the clicky.
This needs an anatomy thread. Nice work Djozz.
Very well done
Look at the crappy threads on the tail cap.
Excellent !
What’s next ?
C8 ?
I'm surprised to see copper (brass) in the switch too.
The cutting did not go that clean, I sanded the individual pieces after the cutting, and then fitted it together again. The lens cut was even a bit polished with a piece of paper.
The problem with screw thread fit is apparently thermal expansion from the heat generated while machining. Of course more expensive lights can be made with the lath turning more slowly and maybe cooling liquid and better compensation for the expansion.
Cheaper lights, on the other hand, because they may sell in much larger quantities, can have more work and talent going into programming the numerical control, so they can have nicer shapes than more expensive lights can.
The perfect question gets the perfect answer. Where else but BLF? :bigsmile:
