Driver Info: HX-1175b & HX-1175B1 (Pic Heavy)
I don’t understand what you are getting at there. Sorry about dinner :-/
I’m sure I don’t understand either.
What I mean is, the HX1175B isn’t made to drive emitters in series (at least I don’t think so), whereas the LCK will drive 3@5A per.
I was thinking that they don’t function in the same general manner.
EDIT 7/2/15: I wrote this before I understood a lot of the math and operation of these converters. I would now recommend a different setup than this---especially the inductor. Even though this setup works, it is very inefficient.
I have a few updates that I will post here soon, I may need to revise some of my prior thoughts. The biggest help in driving dedomed XM-L2s has been to change the inductor and to add some low ESR output capacitance. You really need a good 47uH inductor. I went with a 10.5A peak shielded inductor (the stock inductor is heavily influenced by its position relative to the output wires.)
The quality of the capacitor matters a lot in this type of application. You need low ESR. If you don't have good quality caps, then multiple low farad caps in parallel will be more effective than one large capacitor. Ceramic capacitors have the lowest ESR, but the capacity is low and if used by themselves can cause some issues with ringing (especially on the input side.)
This is from a driver with the 47uH shielded inductor, stock sense resistors, 70N02 FET, 1x150uF and 1x470uF low ESR caps, about 7A output. This is MUCH less ripple than with the stock set up. This will run on a dedomed XM-L2 without any issues--try it with the stock setup and you'll get a very brief flash.
Good update RMM. Thanks for keeping us posted. Looks like I need to eat my words a little about the output capacitance not helping ;). Low ESR seems to be the key to a lot of things. I assume that a shielded, 10.5A, 47uH inductor must be very large physically? Between the two large caps and the giant inductor, you seem to have assembled a real brick :p.
Can you try increasing the sample rate the next time you capture a trace? The outlier samples seem to be a long way out.
I see what you were thinking now. The HX-1175b is constructed using a chip meant in part for controlling high voltage LED strings. The HX-1175b itself is marketed as a driver for SST-90 of course, but I’ve seen little to indicate that it shouldn’t work for higher voltage loads. Thinking more about what I already said, I can’t really see how the PSU section (zener and resistor) for the buck controller would be the problem. I’ll probably pick one up sooner or later to try to learn a little more about it.
Took measurements with 2S and 3S driving an MT-G2. Cells were King Kong ICR's charged to 4.2ish volts. The cells are older and have internal resistance of about 40. Current to the MT-G2 with no driver was 6.5 amps.
2S 3S
High Low High Low
Input Current (Amps) 5 2.5 5 2.5
Emitter Current (Amps) 5.1 2.5
6.7
3.4
Sensor Bank (mV) 162 77 166 82
The driver used is completely stock. The HX-1175b1 only has High, Low, and Strobe modes.
EDIT: Fixed typos in table.
Ouchy,
If you get a chance, please post a pic of the 13amp driver. Also, it would be helpful to know what current 2S of your 18500's deliver when connected directly to an MT-G2.
How do I increase the sample rate on the DDS? I haven't seen any place to do that.
The inductor is actually the same size or smaller than the stock one, although I think it has higher DC resistance (more heat losses.) so it may not be the most efficient but it works well, is small enough to fit in most lights, and runs smooth. The saturation point is what I was really after since I think what happens with the stock inductor that wreaks havoc. With the stock inductor you can run pretty smooth up to a certain point then it just spikes like crazy! Sometimes you can have an LED working fine then you move the LED wires by the inductor and then it blows.
The driver fits well in the TK61 and my little mini intimidator. If you are happy with 6.5A-7A you can get away without the output capacitors but I've added them for extra insurance.
I just corrected a couple errors in the table in Post 155.
EDIT: Fixed again. The table is so small when I edit it that I can't really see it until it is posted. Numbers are all good now.
I tried to guess cell voltage under load and Vf of the emitter to get a rough idea of efficiency. Does it make sense for the driver to be more efficient on High mode?
2S 3S
High Low High Low
Input Current (Amps) 5.1 2.5 5 2.5
Emitter Current (Amps) 5 2.5 6.7 3.4
# of Cells 2 2 3 3
Cell Voltage w/Sag 3.9 3.9 3.9 3.9
Watts Input 39.8 19.5 58.5 29.25
Emitter Vf 6.8 6.25 7 6.45
Watts Output 34 15.625 46.9 21.93
Efficiency 85% 80% 80% 75%
Again, good info - thanks. It sounds like the included software with a DDS-120 doesn’t allow you to manually change that, but if you make a small time/division it will increase the sample rate on it’s own. This is the thread that leads me to believe that. It should be easy to tell since it displays the samplerate on the screen? There may be alternative software which would allow you to force a higher samplerate, but just making a smaller amount of time/div would do what we want here. Based on the specs I assume that the actual limit is either 50MSa/sec or 200MSa/sec.
EDIT: I could be wrong, but I think that in HKJ’s driver reviews he uses 1μs - 2μs per division.
I’m not sure, but I see that you did not adjust cell voltage sag for the different loads. Considering that we’re talking about 5A vs 2.5A, I’d say you’ve got to do that.
You could warm it over that 13A MT-G2 >)
Good point. I need to find a HKJ chart for the KK and adjust. I will do that later. What I really should do is set up a driver testing rig so that I can collect all the relevant info needed for this type of stuff.
Right now I only have two Efest IMR18500 handy. This is all jury rigged with different wires, alligator clips and magnets, but I got a reading of 5.9A.
Okay wight, I tested the voltage across the resistors while running the MTG at 13.45A and got a reading of .049v. I tested each resistor, and got that reading. What it means, I don’t have any clue. Hope I did it correctly.
Ouch! I went to take another reading before I disassembled everything, and smoke was coming out of both resistors. I sure am glad I checked this driver before it went into a light.
Do you see anything different in the components between the 13amp driver and the other 2 drivers. Any bad solder joints or solder bridging components?
I looked it all over with a jewelers loop and didn’t see anything different from the other ones. No burned or charred spots. I even tested a few solder spots with my DMM. Then again, my eyes aren’t that good.
Swap in new sense resistors please.
I’ll have to poke around to see if I can find some.
I swapped in some R086 resistors I scavenged from other drivers. Over 14A and started smoking. All the resistors have holes burned through the center.
