I was in on the group buy for the Supbeam X60, but dropped out after I learned more about the UI. Now I might be interested in this one. Does anyone know if this light steps down after running on Max for some time? If it does, can it be pushed back to Max by turning the control ring down a tad, then back up to Max?
Edit: I forgot to ask: does anyone have this light, and the Dry 3x XM-L? I still use the Dry quite frequently, so I’m wondering how this K40M compares to it.
Well i wasnt here for a fee months and i see not much has changed. There are gbs on every corner and you just can’t have em all. Im also interested to know the price before i can make a decision.
I have the K40M and it’s a fantastic light. The control ring has detents in it just like the ThruNite TN35 and the same modes as well. The grease they use is very stiff and it takes more effort to rotate the ring but depending on your view point that could be a good thing or a bad thing. The K40M is a little bit shorter than the TN35 and the head is a few mm less wide but man does it work well!
On a white wall the TN35 kills it with a tighter and brighter hotspot but outside it changes and the K40M has far more spill and at the 79m distance I was testing it even throws better! I was stunned and had to go back and redo just to satisfy my amazement.
Ahh thanks JohnnyMac, seems like a well built flashlight from a trust worthy manufacturer, I want more spill than throw at my area, this could be my first MT-G2 if priced within my budget.
Sorry...I had some beam shots posted here but the exposure time on them was different so it's not an accurate comparison. I will be retaking them tonight and reposting the accurate shots. ;)
Why the sudden fascination with Supbeam/Acebeam lights for high end expensive Group Buys? I would be more interested if someone would start one for the Fenix TK51 with it’s unique combination of flood and throw in one light, or another light of technical interest with some unique characteristic.
I already have three high power magnetic ring control lights, the Jetbeam RRT3, the Thrunite TN32 anf the Supbeam X40 and IMO the first two have poor UIs compared to the X40 due to the fact that they control the output in steps, like the K40M does. To me the big advantage of the magnetic ring user interface is the continuously variable output and neither of the first two lights listed have it. The X40 is also lacking in that the control ring does not have a standby position where the light is off except for parasitic drain, so none are ideal for a magnetic ring interface light IMO. I also have a Fandyfire Darth and the same comment applies to it as to the Jetbeam and Thrunite lights. The best magnetic ring user interfaces I have are on my Nitecore SRT7 and IFE2, Jetbeam RRT-0 and Jetbeam TCR2. Have the brightness continuously variable from standby to maximum output and add detents at the ends for any additional modes such as strobe, sos, colored LEDs operations etc. To me that is the best UI that I have yet tried and about the most idiot proof. Unfortunately no one offers it in a truly high powered light that I know of.
Not that I object to any group buy, but of late it seems to be a couple of very cheapy ones that are ho hum. And a lot of rather pricey ones, which frankly are just too pricey for me.
Can we have a group buy for something more mid range maybe?
I really don’t need just another cheap light that I won’t actually use and I can’t afford these expensive ones. But there are plenty in-between ones I’d be interested in.
