2xAA utility lights
That one’s on my list, too. Amazon has their 300 lumen model for the same price, so I’d probably get that, to make sure it’s close to my level goal. Thanks.
You may want to check your price! I was about to buy 50 of them at that discount! :wink:
http://www.gearbest.com/led-flashlights/pp_20495.html
You can get 4 of these for the price of one nitecore. Rather solid little light. XPE emitter and decent brightness. It is a 2XAA light but they have a misprint in the specs section.
Just look up Cofly KX-D010.
I know you don’t want a strobe but sometimes you have to make exceptions if cost is your issue.
There is also some discount codes for gearbest and you get a discount for order more than one item.
Yea, I was ready to accept that, but was hoping for getting one without it. I’ll definitely throw this on on the list. Thanks.
Is 18650 a AA replacement or 123A replacement?
You really don’t want to get into 18650 unless you become more informed of them and buy high quality battery and charger. 18650 is not something you want to go cheap on. If you are into aa type lights then you can get some nice duracell ion core aa rechargeable or sanyo eneloops. 18650 is similar in size to two cr123 batteries. But it is a little fatter than two cr123.
This is an ok light, they say 450 lumens, but its probably about 250 lumens, if you can find it in stock anywhere, it might be discontinued (i’m wishing i had not bought it)
http://www.md-lightsource.com/Crelant-V21-A-450-Lumen-2X-AA-flashlight-XML-U3-V21A.htm
This light seems to be similar, maybe you can find better prices elsewhere, it seems to be a direct competitor to the crelant
This is a great light, they seem to be selling whats left so its unlikely they will make more but it uses 4AA (which is actually even better)
super low 2 lumens (450-500 hours - 2000mA batteries)
low 20 lumens (50 hours - 2000mA batteries)
medium 200 lumens (4 hours - 2000mA batteries)
high 600 lumens (1 hour - 2000mA batteries)
http://cnqualitygoods.com/goods.php?id=1980
Use NiMH rechargeables, alkaline will perform poorly and you will think its the lights fault, and keep in mind lithium will not do well in high temps, so don’t leave them in the car (in the house is fine)
I quite like my Solarforce T2. It’s a decent 2xAA for $ 23.
According to their site, the modes are:
100% (300 lumens): 60 mins
33% (105 lumens): 2.5 hrs
10% (30 lumens): 15 hrs
Shop: http://www.solarforceflashlight-sales.com/product_detail.php?t=LF&s=26&id=570
08CivicSi’s Review: https://budgetlightforum.com/t/-/18717
Thanks hanshanshans! That one is definitely a good contender at that price. I like that there is no strobe!
A few more impressions of my Solarforce T2:
+ Seems very sturdy
  • Been using it for half a year now - no problems so far
+/- A bit heavier and bigger than other 2xAA lights like the C3 with extension tube for example.
+/- Doesn’t throw all that far (which is probably to be expected of an XML without a large reflector)
+/- I once accidentally disassembled the head when I just wanted to change batteries. Make sure to only unscrew it near the H - M/L lettering, not where the silver head meets the body.
- According to the website, changing modes works as follows:
“In tightened position: high output mode (100%)
In loosen position: medium output mode (33) → low output mode (10) → repeat (please switch between the medium and low output modes with the tail-cap switch within 3 seconds. After 3 seconds, the flashlight will memorize the medium output mode automatically and will be in that mode after being turned on again)”
This last “memorizing the mode in the loosened position” - bit doesn’t work for me. In the loosened position, my light always starts on medium.
To me, the positives outweigh the negatives and I would absolutely recommend this light (to anyone who doesn’t need it to start on low mode).
"Floody" is probably what a person wants in a "utility" / emergency light. That T2 does sound nice!
-Garry
Sorry, that wasn't clearly written. It's only $0.31 over the $30 limit after the coupon, rather than $2.95.
Oh, okay! I didn’t think of it that way(Obviously).
I was really hoping for some super sweet 30 cent lights!
hanshanshans, I think the description was just a little lost in translation. I think what they meant is that when it was off, it would revert back to medium. That works for me, though. I would rather mode memory, but I can deal with starting in medium.
They aren’t going to be carried on-body, so the weight isn’t a huge problem.
Will any batteries be good for keeping it in the car?
What batteries are good for cold weather? By cold, I mean 20*+F
If 4AA is acceptable, maybe the BLF edition Starry Night? They raised the price a bit, though. Only 8 left.
http://www.cnqualitygoods.com/goods.php?id=1980
Lithium primary cells work well at low temps and have a long shelf life. I using alkaline, I'd store them in a plastic bag outside the light so they don't destroy it when they leak.
Thanks Gj. I wasn’t really looking to use any more than 2, though.
Thanks for the tip on the Lithium cells.
I have ordered from this Store before and received exactly what was described 3 times in the past 4 months.
Crelant V21-A for $21.90
Thanks, bikenber. I’ll put that on the list. Does it say what the low level is?
here is more infomation, the numbers are all wrong though, hihg is maybe 250 lumens at hte most and lasts about an hour
http://www.crelant.com/led-flashlights/v-series/new-v21a-flahslight-2aa-450-lumens-207.html
the medium and low are probably also wrong as are the runtimes
