I am in, a convoy host maybe a s2 or c8…
i am in ,i will use them in C10. thanks for the giveaway
I’m in!
I would probably place it in my C78 AA zooming flashlight to improve efficiency.
A second option would be my Ultrafire 502B.
I can test it and review the differences with the old LED it will replace.
I’m in, thanks! S2+, c8 or c10 are good.
I would upgrade my edc, the olight I3S.
Higher efficacy means more light for me, and almost the same voltage curve as a XP-G2 at low (<.5a) drive currents means it will be a direct swap.
Thanks, count me in. I would probably swap it into a smaller light so that the smaller size is utilized. Maybe my weird sipik SK51 lantern thingy that has an XP-E in it now. Or upgrade one of my ultrafire M5’s.
Thanks for the opportunity.
I use the Xp-l to mod the Sipik sk 68 AA.
I'd put it in a solarstorm sc 01 Thanks
Count me in, host convoy m2.
I’m in!
I would put it in a convoy S2.
Sure I will try it, I want the 16mm, 2A
I would use 3D in a Convoj S2+ host I just purchase from BG.
i am in
i will use it with Small Sun ZY-T08
Thanks for the giveaway
I’d put it into a 602c host.
C8 or p60 host
Thanks for the GA
thank you
maybe a c8 or convoy m1
- I would put this XP-L emitter in my Nitecore EA4, to compare/test it to the original XM-L that i remove.
Thanks for the giveaway.
Thanks bangood!
Count me too!
I would like to use in a C8, or copper in a host of shinner!
thanks and happy holidays!
Either a Convoy C8 or S2+.
