Thanks for testing them! I knew they where good but wow! How do you think they feel about them over at CPF?
I’m not sure, but I can’t come up with a reason to buy AWs over these. The AWs i have are now almost 2 years old, but even when they were new they didn’t live up to what I expected from them (neither did the 16340 or 26500 IMR for that matter). These Panasonics are in a whole 'nother league, so I don’t think it should take much convincing over there. They like to spend money.
I'm going to charge and discharge this one like I would any other IMR and see how it is after some use (and likely abuse).
Some buddies here recommended Mitro to be a condidate to review our new updated WP2 charger, and I have sent a message and waiting for confirmation, can I have the honor?
Miles
I didn't see your post until now, Miles. But we've already talked in PMs, so its all good. :)
Here is a Callie's Kustoms HD 18650 vs. my 1+ year old AW IMRs. I actually thought they were older than that. Is this a fair comparison? You decide.
I keep reading words like "reliability", "durability" and "long-term" when talking about reasons to buy AWs. So it stands to reason that the AW should be able to hold is own after a year or so. These 9 runs were all done TODAY (8/23/11).
The Cells
AW IMR 18650 #1 & #2
Purchased: From Lighthound 6/18/2010
Usage: Not much. Occasionally would fill in for a LiCo in a 1.4A light and rarely run a ROP Hi. Most of the time they have been stored. Some of that time was fully charged just sitting on the shelf and the rest of the time was stored @ 3.8v in the fridge.The cells have never sat after being discharged and I followed charging guidelines specified by AW, but almost always charged them at or above 1C.
Callie's Kustoms High-Discharge 18650 #1
Purchased: Was given to test by Jordon @ CK - 8/8/2011
Usage: Limited testing. Now I'm starting to use them the way I would any IMR (discharging to 2.5v and charging at 1C+)
Facing off at 3 Amps discharged to 2.5v:
AW IMR #1: 1272 mAh
AW IMR #2: 1338 mAh
CK HD #1: 2227 mAh (2180 mAh to 3.0v)
(I forgot to put the temp sensor on until the very end)
OK.... how about 5 Amps (to 2.5v):
AW IMR #1: 1219 mAh
AW IMR #2: 1294 mAh
CK HD #1: 2201 mAh (2127 mAh to 3.0v)
Time to put it all on the line - 10 Amps! (to 2.5v)
AW IMR #1: 81 mAh
AW IMR #2: 103 mAh
CK HD #1: 2209 mAh (1967 mAh to 3.0v)
I'd call that a K.O.
If anybody would like to test my cells to verify my results, I'd be happy to send them to you, just please don't return the AWs. :) Likewise, I'd love to test some new AW IMR18650s if anybody wanted to loan them to me. (Unless you are AW, in which case I'm keeping them for repayment of all the underperforming IMRs I've spent hundreds of dollars on.)
Maybe a new pair would hold their voltage better than the CK, but I think that would be tough. There's no guarantee that they are even the same cells underneath. (I know what a CK HD is. :p) Even then, they're going to lose in the capacity department by a wide margin.
The only other areas of concern are longevity and safety. My pair of AWs may last forever and not lose any any more capacity, but they don't have enough to begin with. The main concern with the Panasonics is the "unknown" level of safety. Until somebody shows me what it takes to make both cells explode, and that there is a difference, I'm going to treat both the same.
Yikes! Honestly I'm pretty surprised. I would think the AW's would have the clear advantage at high discharge rates. Honestly I cant help but think the AW cell is damaged to do that poorly at 10A ??
"The main concern with the Panasonics is the "unknown" level of safety. Until somebody shows me what it takes to make both cells explode, and that there is a difference, I'm going to treat both the same."
I'm completely on board with you on this! In fact we are going to be changing some wording on our website so people really understand no battery is safe. I mean really... when I was a child I had it pounded into me about battery not being safe. I think its better to error on the side of safety rather than catch your self on fire or get burnt up with acid.
I agree, but these cells have never been abused. No dead shorts, no overdischarges. no resting after depleted, and the only times they were depleted was for tests. Also, they readily charge to 4.2v and hold their charge. They also has a relatively normal curve under a decent load (5A).
My only guess could be that regularly charging the cells at higher rates (2C), while within specs according to AW, result in degradation. However, I looked at a graph from a test I did 10 months ago and the curve (another 5A graph) was nearly identical to the ones done today.
BTW, the Panasonic is GAINING capacity. :) 2200 mAh @ 10A is unbelievable.
Very nice mitro , though the demand for a 10A test , I think was a bit of a [ hmmmmm ] unreasonable demand , and I thought it insanely funny when posted on CPF ...
But the fact that the two IMR;s fell on there face and the Panasonic performed well , kind of speaks volumes ...
Now when I see the Enemy post [ yes I think enemy ] , a AW review , must remember to demand a 10A discharge ...
But the whole thread unfortunately deteriorated , with some very silly [ Stupid !!! - who am i kidding ] comments and demands ...
Thanks mitro ...
Think you forgot to charge the AWs for 10A.
Thanks for tests mitro, very interesting - very entertaining! :)
Ok, AW´s are old BUT I think you have kept them in better shape than a big deal of users would ever keep.
They seem to perform well on two lower current tests but omg with that last one...
I would have bet my money EVEN on 1yr old AW´s, seriously I´ve had the image of better performance on ridiculous amps...
Panasonic is really gearing up in battery race. Do I remember correctly Panasonic owning Sanyo?
So, they have the NiMh covered pretty damn good I´d say, with Eneloops. Now this. Whew... :o
Thank you... and thanks for all the testing you've done.
I did the 10A discharge on the cell because Panasonic says it can. I had already done it once for my initial tests, but its gotten stronger since then. I'm not here to sell CK cells. Jordon was nice enough to give me one to test and if the results were poor, they'd be in the above graphs. I like cells that perform up to, or beyond, expectations. I think we all do. :)
LOL It looks like that, but I assure you, they were charged to 4.2v.
EDIT: I think I may need to do a 7 or 8 amp discharge to fill in the gap to see where it goes south.
Those guys would cry foul, but i guess if BLFers would want to counter AW, better do another 4.2V discharge @ 10A, and then after that 5A to show that it has not been damaged. "PROVE BEYOND REASONABLE DOUBT".
It's not a damaged cell, the 1A and 5A mAh results confirm that.
Anyway I am charging HKE's NCR18650A, but i can only do 1A. (ouch)
I'm not here to prove anything. If anybody wants my AWs to test they can have them. BUT... they have to test the CK HD too. :)
I think enough people have IMR's , but not everyone has the equipment to test @ 10A , and I think some of the CPF posters were counting on that , almost like a crutch .
I havent checked yet , but I saw mention of getting banned ??? I'll have to check that out ...
Seriously , thank you mitro ,
I think I should test the CK @15A :)
I ran them all at 7.5A today. Everyone have their harnesses fastened? OK... hang on!
WWWWWWHHHHHHEEEEEEEEEEE!!!!! I've never been on a discharge graph rollercoaster before. :) I assume thatis not good. No... I KNOW that is not good. At 7.5A the AWs are on the edge of having useful capacity, but the temperature of them is getting so high that any cracks/nicks in the wrapper are getting bigger because the wrap is shrinking. So the AWs still work... just not well.
appreciate your effort! Keep it up
Ok but if you blow it up i'm not sending a replacement LOL
Wow, that's a crazy discharge graph. Maybe the battery got a second wind. So at 10A, the test lasts about 12 minutes or so? (for the CK's, looks like the AW's won't make a minute).
