True, should be in the 3.2 to 4A range, depending on the cell. With the stock 5000 cell they offer, it's pretty good. It's really in the range of a modded light. Two cell lights, like the M24 would be better if you want more runtime - classic tradeoff of runtime vs. size/weight.
” Two cell lights, like the M24 would be better if you want more runtime - classic tradeoff of runtime vs. size/weight.”
True - be interesting to know exact runtime on continuous high of the stock M12. Can someone do a test with their new 26700 batt?
For comparison, the modded M12 vs. my modded XinTD X3 (mod thread here):
Modded M12: fresh KK 26700 5000 ICR 6.10A, lumens: 1,612 @start - 1,455 @30 secs, throw: 130 kcd @5m
Modded XinTD X3: fresh KK 25550 4200 ICR 4.56A, lumens: 1,469 @start - 1,448 @30 secs, throw: 76 kcd @5m
The drop is higher on the M12, but there's more to lose with a DD at much higher amps, while the X3 is using a stacked Nanjg. The X3 has advantages with sheer mass, big chunky pill top, but of course it weighs a ton too, but the smaller width reflector results in the lower throw, but respectable for it's size.
Note: all measurements done on my home brew PVC lightbox and $35 meter, so no guarantees
Ok, you’ve all convinced me: Where can I get the M-12 and perhaps also their Gladiator!
Aliexpress has them for $67.50. A desert rat can appreciate a light like the M12. I use mine out in the Colorado Desert just south of you all the time. You should also get the 26700 battery from Richard at Mountain Eletronics. That batt will give you 5,200+mAh of use with low internal resistance to boot. Quite a pair.
but Richard at mtmelectronics.com says he's going to be carrying/selling these, and his prices are always pretty good.
That Richard is a Genius!
Do they make extension tubes for this—to make it a 2 cell, like the M24?
And the driver probably couldn’t handle 8.4v anyways.
Maybe:
From the OP:
“”If you look at the MaxToch M24, the head is identical in looks and dimensions to the M12, therefore, I’m thinking they are using the same driver. if so, the driver could possibly take 2 cells (8.4v).“”
Well!, if that’s the case, an extension tube would be dandy! Maybe I can find one that will Lego. Hmm…
Recently got one of these lights and have just done runtime test on it. Very surprised….with a fully charged Maxtoch 5000mAh battery it ran for 3 hours on high beam. Not very bright at end but would have still done a little more.
Impressive runtime performance for a single cell XML2. The Maxtoch 26700 batteries must be good.
As far as I know the ANSI method to measure the runtime is when the light output is dropped to 50% of its initial output.
Well in the stock form, amps draw could be close to 4A or less at start. 4A draw would only be roughly 1.4 hours, but the amps draw starts to drop immediately as the battery drains with a current limited driver, not current controlled. You'd expect more that 1.4 hours, and in this case, it doubles. These cells are the KK 26700 sold by Richard at MtnElectronics. I've tested a few on the Opus charger and they show 5300-5400 - some variations cell to cell which is typical for all KK's. If you measured tailcap amps along the way on occasion, it should indicate droppage in amps. At the end, maybe under 1A? I'm thinking average was about 2A for a 3 hour runtime.
These are excellent cells though - low resistance and high capacity.
That's probably the loophole manufacturers take advantage of by dropping amps draw 1-3 minutes into a run. What mudgripz is doing is more practical, but of course with lowering output along the way, a function of the driver, the Vf, and the cell.
The last review I read said ANSI runtime was down to 10%.
Will the latest production run of the M12 be improved, and have a direct thermal path?
I'm thinking yes. I would contact MaxToch, probably Amanda, if I were you before buying. I don't see it specifically mentioned on their product page here:
but I thought they updated all these lights to DTP MCPCB's. Richard doesn't say it explicitly either here: http://www.mtnelectronics.com/index.php?route=product/product&path=80&product_id=359. Hhmm...
I asked richard before ordering my m12 from him. He said it had the direct Thermal mcpcb. If it didn’t I was going to order a direct one from him and reflow it. Not sure if they come stock with it or if Richard is changing them to direct mcpcb.
I wish there was an easy way to take the tail plug out of this light without scratching it up…. if anyone has any ways of removing it safely let me know.
Here is the reply from Amanda.
Hello I was wondering if the newest production runs of m12’s have direct thermal path mcpcb’s or not.
MTAmanda’s picture
New
MTAmanda 12/09/2014 - 00:14 Delete Block
Hello,
Thanks for your inquiry. The latest production hasn’t apply direct thermal path yet. It is copper MCPCB.
RMM does have DTP maxtoch 26mm mcpcb listed on his site: http://www.mtnelectronics.com/index.php?route=product/product&path=63_65&product_id=348
Easily solved!
Chris
