It appears you have a bonus werner.
With my very limited testing you may well get a slightly higher output on on battery using the higher voltage cell.
Tons of tiny scratches on mine :-/ Got it today. Package looked fine, so I assume scratched before transportation.
It looks like you need to get out the white king and turn your light naked. I had the same mark on one tailcap but thats all I could see without putting them under the microscope. Mine are definitely not as bright as my HD2010 running at 5 amps. I have a large star coming for the MTG-2 so will wait for it to come in before I mod it. Now to go and find Tom E thread on how to strip these.
white king? What is that? I never de-anodized a light or any outside parts before.
I could not find greased lightning here in Australia so went looking for an alternative. White King had the same active ingredient. Its a clothes bleach. I dont know how it compares to anything else but has worked on everything I've used it on for de-anodising.
On a separate note did the driver pull out straight past the switch boot? Mine seems to be stuck there for some reason and dont want to break anything which l am quite adept at.
I have the same idea, got a noctigon with mt-g2, then off to CK to put in his new driver.
Which driver?
I was reading a thread the other day where the driver had the tabs like the standard one or maybe that was the standard board with this piggybacked on?
Do you have a link to the thread perhaps?
Got the R090s today from mouser. The light is pretty sick dedomed. I can only run it one cell right now cause it trips the protection on the batteries with 2 or 3 cells
I might take off the protection just to see what it can do on 3 cells. But from what I seen one cell is pretty damn good. Have the sense at .045 wight (you smart bastard heheh)
I had the other light come in from gearbest too the other day. I just took parts off both to make a perfect yezl. I noticed the one from gearbest had a cheaper eswitch on it that stuck out. Not like the one from cnqualitygoods which is flush with the light and looks slick.
Anyways good deal. I’ll have a mt-g2 in the other one when that led comes in from rmms shop. I have a copper noctigon coming too but I’m not sure if I even need it. It seems to be getting good sink action from the reflector and pill as it is. I de-domed the other one for practice too. It’s actually really easy using the lights own heat, peel it off one side at a time…
Thanks for the help though, I couldn’t have done it without you guys. Really happy with just one cell, seems out of control bright with 3 but cuts out in a second or so. I’m not sure why it cuts out on 2 and 3 cells but not one. Let me do a reading on the cap.
Edit
Read 3.2a tail with 2 cells bypassed… I guess gonna have to get some good cells and then I can be like that kid in the ad to the left
This is not the one I was thinking of. I'm not sure where to look for the other. Maybe its in this thread somewhere.
Update 10/04/14: some highlights found in this thread: Post #96 is ROD911's impressions of a simple emitter swap to MT-G2 using stock driver, stock amps (post #114 is beamshots I can't view?) Post #118 - some useful info on resistors Post #126 - R100 result with a MT-G2, UCLp lens Post #144 - details on DMM wire leads used to measure amps Post #145 - aoeu's impressions/results on MT-G2, and grinding down the head (pic posted at post #184) Post #166 - details on the MaxToch 26 MCPCB used in a Y…
Hhmm - I don't recall having any problems with that. Dunno, really wondering if the earlier ones I bought from WallBuys were a better quality batch, and better quality in the assembling. They seemed to perform better, no nicks/scratch's to speak of, etc. I'm sure though the recent one I did from RIC was fine - don't recall any probs pulling it out and resistor modding it.
Ohhh - I got a bunch of the super copper stars (MaxToch) on order from BangGood. Both the XML and MT-G2 26 mm's sound perfect for this light!!
I did not order a bunch but did order a couple due to budget constraints.
I'm a suka for qty discounts , plus the BLF discount still applies with the qty discount, unlike FastTech.
Just to update. The noctigon came in the mail today so I took out the stock led again and tried it out. The thing was too thin though so I had to put in a copper shim to focus it- my fault I’m sure as it’s obviously not the right size. :bigsmile: But I’m onto the mt-g2 and was wondering how far do you push yours in the Y3? The driver seems to handle 2 R090 resistors just fine through the u2, went and ordered some crazy batteries for it though so see if it makes a difference
Centering was difficult when you have to shim… I can see why you guys charge the big bucks. I must have shifted the mcpcb around 20 times and finally got the bezel to close on it just right lol Anyways the light throws way better than stock as you can see here. The mt-g2 is next but I’ll do it tomorrow
Had a play around with mine last night. Really great thrower for the money, slightly deeper reflector then a ZY-T08. Strange how there is some slight PWM on high, but the driver isn’t going to be in there for long anyways. Thanks Ric & MRsDNF! :bigsmile:
Fell awaiting beamshots I have parts on order for a Y3 with G2 as well!
I’ll do that… Still waiting on the ar lens but I’ll take some with the stock
Sweet looking hot spot there fell. Congrats on the mod.
