It doesn’t overly bother me, but if I had a choice I would prefer it react how it does on low pwm mode. As I don’t understand what the buzzing is about, and if it is damaging anything, I changed back to high pwm and will be very happy with how it performs.
The flashy modes are “hidden” in the sense that it takes a bunch of clicks to get to them. I doubt a video is really needed… and I’m sick and coughing like crazy so I don’t want to speak today. The modes are:
Click once (or tap once if already on): Moon mode
Tap twice: low
Tap three times: medium
Tap 4X: high
Tap 5X: maximum output
Tap 6X: moon-med beacon (flash med in a quick stutter, then rest at moon, repeat once per second)
Tap 7X: low-high beacon
Tap 8X: med-max beacon
Tap 9X: heartbeat-style beacon — blinkblink, pause, blinkblink, pause
Tap 10X: 10Hz true strobe (1ms on-time, freezes motion)
Tap 11X: 24Hz true strobe (0.3ms on-time, freezes even fast motion)
Tap 12X: 60Hz true strobe (0.3ms on-time)
Tap 13X: ~7Hz to ~18Hz self-ramping strobe (1ms on-time)
Tap 14X: ~16Hz to ~100Hz self-ramping strobe (0.3ms on-time)
Tap 15X: Start over again at moon mode.
It uses short-cycle memory, so whenever it has been on for more than a second it will reset to starting at the first mode. To go from medium to low, for example, is a couple quick taps on the button (like half-pressing a camera shutter).
I find the solid modes are useful for general purposes, the dual-level beacons are useful while biking or signalling for assistance, and the strobes are just fun to play with. For example, point one of the self-ramping strobes at a spinning fan and it’ll gently rock back and forth, spinning one way then the other.
If you really want it to come on in a non-moon mode next time, it can be tricked into doing so. Basically just replace the last ‘tap’ with a full click (to turn it off), and then leave it off. Next time it starts it’ll be in the desired mode.
Guys quick question, does turbo timer not work if the mode order is reversed?
I’ve made my wife a new EDC (an HD2010, even I dont EDC a light that large, good for her!) but she wanted it to come on in turbo and go down but its having some issues, stepping down threw the modes when it shouldnt and just acting bad in general so I was wondering if that just wasnt possible to use the timer if turbo comes first.
Also I’m using the instant start turbo ramp down, not the timed single step.
Of course it’s possible to make it work as desired… just depends on the code used. I can’t say I’ve actually used turbo though. I haven’t even tested the low-voltage stepdown yet.
In any case, I kinda prefer to remove the star-soldering config options and simply build the code with the exact features I want. It provides more room and makes the code more straightforward for debugging.
Hmm, crap, it is definitely supposed to work. Are you using just the latest standard STAR program with the instant turbo ramp down change? PM me and I can give you my email address if you want to email the file you're using for me to debug.
If you keep holding the button, it will cycle on its own (low to high). So, from off, simply press, hold, then release when it hits the desired level.
I tried to measure the output too, and got the following. I don’t trust my light box at the highest two levels though, and I had to estimate the highest level via ceiling bounce:
Mode 1: 1.0 lm
Mode 2: 12 lm
Mode 3: 62 lm
Mode 4: 315 lm
Mode 5: 1148 lm
Mode 6: 3100 lm (turbo)
This setup allows the SRK to go a lot lower than the “SRK Special” firmware RMM is currently using (it started at 43 lm). The slower PWM seems to have helped a lot! It actually emits a useful amount of light with the PWM set to 1. Thanks for implementing the per-mode PWM timings!
#define MODE_PWM 0,PHASE,PHASE,FAST,FAST,FAST,FAST // Define one per mode above, 0 for phase-correct, 1 for fast-PWM
Very slick solution :p
Adding a 0.8 or 1.2uH inductor between the B+ & LED+ pads will drop it even lower (it attenuates the PWMed levels, with greater effect the lower the value - lots of reduction in the lower modes, very little in the upper and nearly none at all on the 100% high). It also smooths out the rising/falling edges of the output sent to the LEDs, without affecting the nice square wave the FET likes.
Richard asked for a feature for STAR_Momentary where a press-and-hold for x number of seconds would put the light into momentary mode, then press and hold to switch back. I made the (pretty simple) change and he's going to test it out. If it works out well I can make whatever tweaks are needed and then push it out in a new version.
Ooh... if the switch is pressed & held continuously, like accidentally in your pocket or the bottom of a bag, it ramps thru all the levels and then turns off. Even if you don't use the ramping that's a neat safety feature.
(I changed the default mode order, and shortened the long press time from 40 to 17) :)
Yes, it only ramps through once. I’m not entirely sure why though, since I didn’t program that behavior on purpose. But it’s a happy accident, so I left it as is.
It's also useful for turning off without doing multiple clicks. With the mode order reversed, no matter what level you're at, hold the button and it ramps down and turns off.
I prefer it with press+hold for low-to-high and tap-tap-tap for high-to-low. It’s what I’m used to because of Zebralights.
In any case, I’m trying to add a voltage readout. However, I’m getting some odd readings. I don’t know what values to expect from the ADC at different voltages.
ADC_CRIT is set to 120, and ADC_LOW to 130. I’m assuming the maximum value 255. But what voltage does 255 represent? And within that range, is it a linear relationship between voltage and ADC value or is there some sort of curve? Any idea what value 4.2V would be?
The plan is, if the user uses rapid short taps to cycle from off through all modes and back to off, the light should blink to indicate the remaining battery charge — zero to four times, for ~0, ~25, ~50, ~75, and ~100% remaining charge.
