Does anyone know if removing the pickup sensor for strobe would cause any more parasitic drain with the ring in the strobe location than it would in the standby location?
Sir m4d m4x, how do you turn the brass retaining ring in the tail cap? Clockwise or counter clockwise… im trying to open it but no success. Its too hard to open… tia
I tried opening the tail cap again but i cannot open it at all…the retaining ring is kinda stuck… so it means i cannot replace the tail cap… i emailed acebeam but the reply only says to have it check to whom i bought it… i thought acebeam support international warranty
Just turn harder, often the aluminium threads when they aren’t lubricated grab onto the brass retaining rings. I had to pull a brass pill out of an aluminium host the other day and it needed two people to do it. One holding the body with a rubber gripping cloth and one with the circlip pliers with a bar going through the handle for leverage. Once it came out it was fine, but there was no lubricant, no threadlocker etc, it was just really tight and had stuck in there.
hmm I’m not sure then. Try heating the whole thing up by putting it in a ziplock bag in boiling water. Aluminium expands more than brass does so it might loosen up.
