What causes the doughnut beam?
Oh man doh… I checked the mtg2 because I knew it should be getting more than 4a. I took out one of the R120 and replaced it. I seem to remember it bending a bit after the solder. Well now I can’t even measure the amps at the tail lol It’s throwing some good light out
@0.036364 runs at 2 and 3 cells…
I’ve taken it apart so many times though there’s kind of some dirt around the reflector thats making it look ghetto (from screwing the reflector in and out). Oh well happy with the tint. I cant see dedoming it and making it look like pee yellow. Think done with this one. Waiting for a new emitter on the other one.
aeou, if you pull the emitter back from the reflector is creates a hole in the middle of the beam close up. Like the old maglites, they had throw but there was always the classic hole in the middle of the light.
I wouldn’t even try to dedome an mt-g2, too much risk in damaging it.
Yeah no good throw either huh. The thing costs to much for experimenting around too :bigsmile:
I heard everytime someone mods their own light in the world. Vinhs ears start burning
Not sure. My guess is that when you go beyond the focal point of the reflector (Bottom of the parabola) the diameter of the dark area where no light hits the reflector spreads out. All I can say is that I have done what you are talking about several time and I get a doughnut hole. It probably disappears at some distance from the light, but I never checked for that.
Sorry I don't have any more info for you about it.
Regarding dedoming MT-G2. The emitter is just too damn big for me with the dome. I have dedomed every single one of mine so far. I have to admit though, they all look ugly up close with the light off. Like fellfromtree alluded to, it does create a yellow corona around the hotspot. I doesn't bother me, but some folks remove the phosphor that is surrounding the die to get rid of it and to make the hot spot cleaner and smaller.
Hm, the switch on my light doesn’t seem to work, the tail works fine but the side switch is intermediate at best.
Have you contacted Ric? Occasionally i have had the same problem with different lights and most of the time it appears to be the contacts in the switch not contacting which is usually fixed with a squirt of 5.56.
Good thing you linked that, reading it I was sure you were meaning I shoud shoot it with my AR lol.
I haven’t contacted him yet, it got here 30 minutes before I went out of town last week and I just got home today, I was probably just going to make a whole new driver board for it anyway (instead of piggybacking mine on) and use a more common switch, this one looks normal but had a 1.45mm pin spacing.
Edit: mine also has a pretty large flaw under the electroplating on the reflector, looks like a grain of sand or something but its under the plate so if I tried anything it’d just flake off. That’s what I get for buying the very last one.
am i the only one who have not received yet the y3 ?
i got my replacement yesterday and it is working flawlessly.
I recived it today
Ciao
The whole point of a paraboloid reflector is to collimate the light striking it into a beam. Look along the axis of the flashlight into the reflector, perpendicular to the face of the light. What do you see at each point of the reflector? It should be the emitter if it's properly focused. What do you see near the center? A hole. There's no collimated light being emitted hence the hole in the beam. The emitter isn't a point source and the reflector isn't a perfect, idealized paraboloid so divergence with distance not only increases spot diameter but also eventually fills in the center.
FYI, the Maxtoch holster from BG fits the Y3 like a glove.
I got tired of waiting for the Niwalker recommended by Tom E(?) to be restocked by FT.
at last arrived today BUT the reflector has a “dirt” spot
any chance i can find a replacement for the reflector ?
I would contact Ric about your reflector.
thanks,send them a message throw the website.
about resistor moding i have resistors writen on them 100 ,101,105 and 121 are in the same range as the r150 and r180 ?
got my answer here : SMD resistor code calculator
Mine came with many scratches and dents. Good packaging. Certainly it had scratches and dents before being packed.
Mine is exactly the same way. After taking 30+ days to get here it’s not worth if to try to get it replaced since its a personal light, if it was for a customer build absolutely but I’ll just live with it.
thats the problem ,its not mine ,i will build it with mtg2 for another guy.
