Under $10, 1x AA/ AAA/ 10440/ 14500 flashlight reference
232 posts / 0 new
g_sintornillos
g_sintornillos's picture
freeme wrote:
It is about the size of Ultrafire 502B, but it supports both 18650 and 3xAAAs. Sealed It cost a few bucks less than your green mini too.
g_sintornillos wrote:
freeme wrote:
I have a couple of these right now. I glued 2 pieces(stack) of Rare-earth Neodymium NIB Disc Magnets at the button and it is still able tailstand well.
freeme wrote:
http://www.gearbest.com/led-flashlights/pp_15287.html
The Green Dwarf!! I have many from DX and EB. I recommend it.
but that is a black giant… Big Smile
I’ve Dwarf and giant… I prefer Dwarf…
Sorry for my bad English (gogole transtorla)
g_sintornillos
Jerommel wrote:
‘Fake i3s’ 1x AAA
$4.71 at Wallbuys
Yes, it’s brown… and only available in brown…
O, I mean “tan”, as they put it..
“Faecal” anyway..
Cute though!
Post #24
I got one last week. It’s golden.
It has some imperfections.
It’s good and cheap option.
WarHawk-AVG
WarHawk-AVG's picture
Last seen: 8 months 3 weeks ago
This just hit the wire at Fasttech
U-520 $5.80
hank
hank's picture
Last seen: 22 hours 34 min ago
NOT _
———below $10 right now at NOT
.. funinbuy.com/Smiling-Shark-SS-8027-Cree-Q5-8W-800LM-1-Mode-Adjustable-LED-Flashlight-Torch-3-AA-p189622. ———_
(says 1xAA in description, it’s the ‘moving pill zoomie’ that Fritz T. mentioned at
http://budgetlightforum.com/node/31780#comment-5915
NEVERMIND, bait and switch, once you register and try to put one in a shopping cart it says
“Sorry, the sales have been overdue.”
Eschew.
antiparanoico
Last seen: 6 months 4 weeks ago
Jerommel wrote:
‘Fake i3s’ 1x AAA
$4.71 at Wallbuys
“Faecal” anyway..
Cute though!
Post #24
Mine is golden too.
It is bigger than I3S.
Imperfections…? A lot.
The biggest, the led have cataract.
Would I buy another? No, while I can buy cheap the SF-348.
If anything can go wrong, it will.
Matter will be damaged in direct proportion to its value.
hank
hank's picture
Well I got one with a hollow pill that’s in the junk drawer, but I got another, the gold one from ebay pointed out in
http://budgetlightforum.com/node/31780#comment-591306
bought that a few months ago.
I got one with a solid pill (lottery or design, I don’t know, but I’m going to buy another and see what I get).
EDIT — that was the lottery. Another from that site, and the next 3 I got, are all hollow pills
_______________
On the one with the solid pill, very nice:
I just swapped in one of the “SK68” 15mm drivers that Cereal_killer is making now — same diameter — and a Luxeon PC Rebel on a 10mm square Sinkpad 2 (which Luxeonstar.com is going to be selling, I got a few before they got them up on their website). Pricey emitter/board and high minimum order for free shipping, I’ve nudged them about some kind of flashaholic discount.
Nice things about this — the 10mm square drops perfectly into the round cutout on the solid pill, leaving the thru holes clear for the wires, and centers itself. I tried both the adhesive sticky square thermal tape and Arctic Ceramique, since the PC Rebels get incredibly hot if not in contact with a good heat sink (as in burn-the fingers on contact — must be robust as the first one I did dedomed itself, probably from the heat, but still perfectly bright, none of the “PC” (phosphor coat” came off and it zooms the same image as before).
And the 15mm driver fits perfectly — exactly the same diameter as the SK68 takes.
I got C_k to give me just 350 mA or a bit over, not pushing the LED, and at high it’s plenty bright; I got a ‘moonlight’ low that’s less bright than an amber 5mm LED, which is also just perfect for night time dark adapted use.
So before I buy more of these #3s, I figured I ought to mention this in hopes someone has a better light-driver-emitter already figured out.
But it’s real nice that everything just fits and works (well once I got my solder in only the places it belongs, everything works …)
WarHawk-AVG
Just hit the wire…a new looking SK68, square, better knurling
http://www.fasttech.com/products/1/10009379/1830007-525-1-cree-xp-e-q5-1...
bikenber73
bikenber73's picture
Last seen: 1 hour 44 min ago
WarHawk-AVG wrote:
This just hit the wire at Fasttech "U-520":http://www.fasttech.com/products/1/10009202/1815003-u-520-1-cree-xp-e-q5... $5.80 !http://fasttechcdn.com/products/181/1815003/1815003-6.jpg! !http://fasttechcdn.com/products/181/1815003/1815003-4.jpg![/quote]
I received mine the other day and ordered 3 more. It is VERY well made for the price. Reminds me of the TANK007 lights.  My protected 14500 do not fit because they are too long. I am using AA's and I am happy with the output.
hank
hank's picture
So given that new Fasttech light is next mode memory, what will it take as an improvement?
Diameter of the pill? What’s behind the LED, air or aluminum?
ImA4Wheelr
Last seen: 7 months 2 weeks ago
# 24 Clone
Pregulla find.  $5 for one, $14 for 3.  Been playing with it stock tonight.  Really good deal.  More info here.
lekvar
Last seen: 4 years 10 months ago
My “Green Dwarf” just arrived from GearBest and the base is indeed magnetic! Pretty strong, too. The over-all build quality is good, better than the pictures suggest, and the light passed the mid-day “bathroom test” just fine.
WarHawk-AVG
hank wrote:
So given that new Fasttech light is next mode memory, what will it take as an improvement? Diameter of the pill? What’s behind the LED, air or aluminum?
Just got my 2 in, the star is sitting on a solid shelf, no thermal compound
Little plastic reflector
I am sure next mode memory pencil lead trick will cure the next mode memory, it is a twisty after all
Modes are H>NOT SO LOW LOW>STROBE
No pill…the shelf is part of the head..I will get pics and measurements asap
overall it feels pretty good, not too bad for the $5~ paid for em
hank
hank's picture
Just bought two more of the same #3
This time, I got the hollow-pill version instead of the good ones with a solid back plane for the emitter to sit on.
Which screws up using the square 10mm boards I’ve been getting that fit the solid ones perfectly centered.
Anyone know a source for the #3s with solid pills?
Werner
Werner's picture
Does your #2 also work with AAs? How is it compared to a zoomy?
Just spotted number two for cheap, but it says 14500 only:
http://de.tmart.com/512-CREE-3W-180LM-300m-White-Strong-Light-LED-Flashlight-Golden-1-14500_p263082.html
Pregulla
Pregulla's picture
Last seen: 9 hours 32 min ago
Nice looking one.
Looks like the seller put some random data in the description Big Smile
hank
hank's picture
http://www.gearbest.com/camping/pp_74052.html
hangs with the lens pointing straight up
Werner
Werner's picture
I have that light, ordered from wallbuys or banggood on a promotion….
It’s a lantern light with a aspheric on top. It is a18650 light which came with a 3xAAA adapter.
There is no heatsinking just a small pill which sits on plastic and because of the design it has no connection to the body. Very dim in stock form, I modded it a bit but it is not much better now.
WarHawk-AVG
I have one similar, very good throw for so small
Don’t like the UI, H>L>STROBE>OFF, must go thru epileptic seizure mode to turn it off…but it IS a bright little booger!
hank
hank's picture
huh, Pregulla’s link is to an AAA zoomie, if the picture showing it with an AAA battery, and part of the text, are to be believed.
http://www.aliexpress.com/item/Ultrafire-cree-C-8-led-flashlight-7W-high...AAA/2027345779.html
Then again it claims it would also use a 14500, and that it’s waterproof.
$2.40
Six impossible things before breakfast?
raccoon city
raccoon city's picture
Last seen: 4 min 59 sec ago
If you've done six impossible things before breakfast, why not round it off with dinner at Milliway's, the restaurant at the end of the universe?   8)
murman
I need to purchase a few SK-68 clones for some coworkers this year. I just need a good quality, single mode torch that runs well on AA batteries. Who selling the best clones these days? There are so many sellers on ebay that I don’t know who is selling crap and who is selling quality torches. Thanks
hank
hank's picture
> sellers on ebay … don’t know who is selling crap and who is selling quality torches.
Fixed that for ya. Welcome to the lottery.
kronological
kronological's picture
Last seen: 3 years 2 months ago
I like the look of this UltraFire AT-007 AA/14500 zoomie from FastTech for $4.77.
Available in this ugly color combo as well…$4.77.
Looks like a nice AA prospect for gifting.
No one, after lighting a lamp, puts it away in a cellar nor under a basket, but on the lampstand, so that those who enter may see the light.
My Reviews: Ma
hank
hank's picture
It occurred to me to buy one of each and swap bezels — blue/black for cool white stock, and red/gold for a neutral white or amber mod …
if these by some wild chance come with a mod-friendly solid pill instead of the expected hollow pill … but no, I can’t be that optimistic.
WarHawk-AVG
kronological
Anybody know about this 1xAA Powerlight B21 side-switch light? I can’t find it anywhere but WB. :~
$3.08-$3.25/ea. Depending on qty.
My Reviews: Ma
Lancman
Lancman's picture
WarHawk-AVG wrote:
Clone (of the SolarStorm), just hit the wire
http://www.fasttech.com/products/1/10010036/1877104-yupard-1-cree-xp-e-q...
I think there’s a group buy for $2.99 on that one at the moment. Smile
WarHawk-AVG
Boom..ordered 4…kids Christmas stocking stuffers if they make it here fast enuff
hank
hank's picture
I bought one of those a while back and got a solid pill that made it easy to modify. Best #3 Zoomie out of many tries.
I (stupid, stupid, stupid!) bought three more recently.
They came in the same nice color-printed Rustu cardboard box.
But they’re crap now, same crap #3s you get for $2.99 on eBay that makes you feel burned when it arrives.
Burned, burned, burned.
Hollow pill, dirty dinged up pill, almost no ledge inside for heat transfer at all, BLUE-white emitter, oil inside on the threads which are pretty chewed up looking.
Oh, and the threads no longer even match the threads on the “3W Police” lights that used to work as extension tube donors.
Even cuter — although no review appears from me on the DX page, they won’t let me review it saying I reviewed it previously.
Okay, it was my turn on the big lottery spin, I had gotten decent products and decent treatment from DX for several years in a row.
They got me this time.
EDIT — and they did give me a refund —
BUT NOTE: I asked several times to change the old review on their site, when I praised the earlier version — and they never let that happen.
Lancman
Lancman's picture
I can’t believe none of the Hugsbys made the list.
The XP-1 and XP-2 are superb quality AAA lights for the price (around $5).
Likewise the P31 for AA.
