> everybody I show it to wants one, they really like the flood the mostâŚ.
> but there not Savvy about batteries and chargers
That would be people who donât know how to safely use lithium-ion cells.
Would a 3v lithium primary drive this light, if it were given a shorter battery tube?f
(actually that would be good with the cheap hollow-pill version, since it would run cooler)
That would be ideal for giving as a gift to people who you wouldnât trust with li-ions.
There all professional people, you know Doctorâs, Lawyerâs Engineers,Cops, Firefighterâs real dummies, too stupid to figure it out, probably Blow them selfâs up?
Donât have any high drain battery on me now, but will it get âboilingâ on HIGH using those ? I was thinking put some artic silver between the sliding surfaces to increase heat transfer, but it probably nasty (white, and will âslideâ out). (is there any black thermal compound? XD)
However, I donât have my unit. I have been robbed by my friendâŚâŚ I have no more zeusray in my hand⌠damn itâŚ
Ooops, mine is modded with a current limiting Nanjg driver so I don't have to worry. But, in stock form the light has a lot of resistance and with a higher Vf of the XM-L2, probably will be constrained - maybe not more than 4-4.5A or so with absolute fresh best cells.
Looking at the stock driver in the pill, I see a little wedge of what might be springy metal in the gap between the board and the pill; wondering how easy it is to swap a driver into this particular light.
(Iâm still new at this, done half a dozen driver swaps on SK68-ish lights, with some struggles getting good connection to the pills)
hank - too many threads on this - thought I posted mod details - maybe not everything:
This is what I did/used. Nanjg at 3.85, custom programmed modes. I took a metal chisel and notched the edges - working well so far. I've done this a few times. Another method is using copper sheet metal shims in the gap, press fit the driver in, then solder the copper shims to the driver edge - also works. Lots of variations of this theme have been done. This is always a problem/issue for these all-alum pills... I like leaving a notch on the top edge, shown on right in the pic above to allow you to easily pry up the driver later. If not there, drill/dremel one out.
If you use the copper shim/tab method, be sure not to create any shorts by having loose ends get onto the driver electronics.
Best solution I've seen for the driver mount issue is the 2014 model of the Convoy M2 - thin brass retaining ring that clears the 7135's !! Wish they all were like that - first time I've seen it, but of course the Convoy's are designed for Nanjg style drivers.
Yeah, A god using thunder bolt, I guess that is the ray. so I guess we all steal portion of his thunder
orâŚâŚ zeus is behind the production ? well for me it is still not quite a thunderbolt, unless v2 is going to be pocket rocket with narrow focus. (the focused beam still quite wide in long distant)
Yikes, XRE's are dated and can't handle high amps. Better for an XP-G2 on copper, maybe de-domed with the standard aspheric. Thinking for the high amps, de-domed XP-G2 would be your best throw out of this light.
The throw is quite good for what it is in my opinion its not going to compete with a big reflector but I think you would be hard pushed to find a better thrower for $8 mine seems to be in the same ball park as a C8
I like the torch a lot only thing that I could complain about is the âlowâ is still quite bright, making me wonder just if the BLF Eagle will be 2.5 times as good, as it costs(expected) are 2.5 times as much?
I measured the stock ZeusRay at 15 kcd (3.6A at tail), and measured a stock Eagle Eye X6 at the same - 15 kcd, but the BLF X6 will be more powerful. Better C8's do about 25-30 kcd stock, but sure others do as low as 15 kcd as well -- all depends.
Agree - it's ok but would do better with a throwy LED.
You should get double the kcd on de-doming, XM-L2 or XP-G2 in zoomies - same as reflector lights, as long as amps and focusing stays the same. Of course doubling kcd does not double distance.
Iâve used my two a lot and theyâre starting to show shiny through the black in places.
I think itâs paint, not anodization. Curious what others are noticing about wear and tear.
I wasnât expecting an anodized light â neither version of this claims to be on the website â so havenât been surprised.
