my thoughts as well ⌠perhaps better build quality?
Sad that the review is missing a taking apartâŚwe need some pictures of the innards to determine if it is worth the price.
If it has a solid emittershelf it is worth the price and could be a super bright flooder.
Well, the solution would be to have GearBest send a review sample to JohnnyMac.
Yeah especially if you consider they send one for review to collinsdad in CPFâŚ.
The Yetzl extension tube coupon seems not to work anymore, are you going to extend it?
Hi B42, we have extended it, welcome you to use it!
Hi Gearbest, just put an order for a Yezl 3 + 5 extension tubes
A question: in this link Ultrafire 14500
if a put it in the cart, it give me 3.80$ for 2 piece, not 2,85$ (66% discount). It is correct? Which is the price? Thank you!
Hi Manx,
Iâm sorry this issue bother you! In fact, Ultrafire 14500 is battery product which be regard as a special product, the courier told us that the battery product must be shipped with the tracking number, or they will not accept our battery product orders, please kindly understand! So when you buy a battery product , its price will include the tracking fees $1.99 by our system.
Best Regards,
GearBest.com.
Thank you for adding the coupon code for the X3 battery holder.
I have an XinTD V5. Will this battery carrier work in my light?
thanksâŚ
patrick
The video title says parallel battery holderâŚ.I guess that is a typo it should be serial.
It is like a 3AA to 1D battery? So it fit in a Maglite 4D? Thank you very much
Yes, Iâve correct my post, was wrong, sorry
GB's web page for that battery carrier originally said it was parallel. They fixed that pretty quick. Unfortunately I don't think Youtube allows titles to be changed without reuploading the video. Since they fixed their title on their website, I think the Youtube title mistake is acceptable to leave up.
And yes, it should be series. It definitely looks like it's series, and the version sold by another vendor is series. It'd have to be series for it to work in the X3.
I am afraid it wonât fit in every 26650 lightâŚ
the diameter is 28 mm
That is true. The X3 rattles a little with a 26650, presumably because it's bored a little wider to fit the 3AA holder, which is a funny because the 3AA holder rattles a little too!
It donât will fit in a 26650 light because itâs more a D cell thickness which is around 32mm. The xintd has a inner diameter of around 31mm if I am correct.
A AA is 14mm so two next to each other are 28mm minimum, which is always more than 26mmâŚ
I am unsure if the length will be a direct exchange for a D Cell but I will order two if these are still available in ten days or so, because 3$ is a reasonable price for a ready build adapter of good quality and will come in handy former or later.
Perfect, will wait for your experience and evaluation
A D cell is about as wide as the outer diameter of the tailcap threads on the X3. The length of the carrier that came with the IOS version is close though, so you might be able to use it in a D/32650 light like the Lumintop SD10 or Maglites. I'm assuming the GB carrier is exactly the same, and now I have one ordered too.
Thanks Gearbest for sourcing the battery carrier, much needed and a good price too!
