I want to keep it with the original arrangement and use the reflector for white only. You’re right that the beams won’t be great, but 99% of the use will be on white so I put much more importance on that beam being perfect. I’m hoping I can find some optics that will fit in the space between reflector and outside wall so I can get something halfway decent on the color emitters. It will also help that for R, G, and B I can have 2 emitters opposite each other so at least it won’t be off-center.
Yes, I chose a new buck-only CV regulator for this one that can supply up to 3A, and each color emitter will use a resistor to set current.
In my experience 405 and 380 act very different, but maybe I haven’t seen other options. Do you know of any emitters that go much shorter than 380?
The buck regulator for the white channel is fairly devoid of details because I happen to have a bunch of boards in my scrap bin that have a complete MAX16820 setup, and I plan to salvage all the components. I think the values are 0.068 which gives about 3A.
For the 405nm, I’ll use the Luxeon UV. For the 380, I have a LED Engin LZ1 that I think is 380 (it may be slightly lower). I would prefer to use the Lux UV for both because its package is more convenient, but I think the LZ1 I have is shorter wavelength than Luxeon offers. I’m not 100% sure which I’ll use. For IR I have an Osram Golden Dragon—unfortunately large package but the best high-power IR emitter I’ve used.
started the main & daughter boards. got the outlines set and basic component arrangement established. here’s the current challenge: locating the 4 pins that pass from main up to daughter while avoiding impeding on the space for battery contacts and the shelf (exposed case material, must be unmasked copper) regions.
Woohoo, finally got the shipping notice for mine (added stuff holding the shipment up). Should be here Wednesday. Think I’ll go ahead and do a review on mine before I tear it apart.
Got everything fully routed. The daughter board looks like it’s ready to order. The main board has everything connected, but I still don’t like the look of it… may need more work
“Ratsnest: nothing to do”. Beautiful, I bet it even passes DRC huh.
I really like all the extra copper pour on the daughter board. I’ve started doing that too, I like the finished look better plus the extra heat sinking it provides.
The trick is to do a big polygon around everything that’s not any particular shape. Then when you have a circular board edge, the pour will automatically isolate from it by whatever distance you set in DRC and it matches the shape exactly
