Clear 18650 shrink wrap from FT works great.
Oh yeah, al my TP4056 charger modules get that treatment now
WarHawk, you might want to think about selling a couple!
What about a JB Weld case, of course it would not show the pretty parts so it wouldn’t be perfect…
So do you have to flash the pertinent data to that mcu? I’m not sure I’m understanding how it’s “Automatic” unless the various codes are put in there.
Like the idea, slow on figuring out just how it works. lol
Get Richard to sell em and I’ll just pick up a few, don’t have to know how to build it just have to know how to plug it in… :bigsmile:
Go look at data sheet, it’s a resistance/volts signature on the data pins, there is nothing to flash, the IC does it all
Rather than being programmable such as attiny13 or other mcu, chips like this USB charging controller are hardwired at manufacture.
Warhark, remember data sheets are klingon if one doesn’t normally deal with them. :davie:
Ah, sorry my nerd was showing again: p
They are klingon to me too when they get to The maths… my brain catches on fire
It’s that thing in your earlobe…causes static electricity and ignites anything filled with combustible vapor.
It’s my recharge port
Then what’s that cable coming out of your shorts?
Gotta have a ground
You stood still near OL to long. Something like this was going to happen eventually. Looks like he has perfected the application perfectly.
This... [image] Just finished dipping, drying and clear coat. [Hydrographics Maglite] Here's a rather long video, Again! About the dipping process and my experiences trying to dip. It's been a real challenge, but I did make something that sort of looks like a dipped part. Just an FYI. I will take a photo of the finished light when it is done. Without the support of a certain member here, none of this would ever have happened. I will let him remain unknown, unless he …
Maybe this is related to the ideas in this thread. I just noticed that my iPad will not charge at the 2A rate when a Charger Doctor is inserted in it’s path. Charges at a maximum of 1A. Would there be an easy mod for this or a whole new design?
I have ordered a couple of other “Charger Doctor” type devices to see if they will allow a 2A pass thru.
If the charge doctor passes data thru it, then the iPad is charging from the signature coming from the device it’s plugged in, if not the charge doctor might have the data pins shorted…that is the one signature that should charge at a max of 1A on most devices but won’t ever charge more than that.
You can actually take a regular “data” USB cable, open it up, then short the D+ and D- wires (the green and white wires inside the cable) going to the connector that plugs into the devices needing charging (usually the USB micro male plug) it will charge at up to 1A and NOT ever pass data [It becomes a dedicated charging cable]
My module I made, and the IC on it will send the iPad signature back (it has 6 different charge signatures it can send out) to the device and as long as the charging port it’s plugged into can deliver 2A or more, the device will charge at that (with losses thru the cables of course) [the chip autoranges and will change because it senses the input voltage, if it sags because the charging device pulls to much, it will change to a little slower rate until the input voltage comes back up to within tolerances of the approx 5vdc charge level]
Maybe this is related to the ideas in this thread. I just noticed that my iPad will not charge at the 2A rate when a Charger Doctor is inserted in it’s path. Charges at a maximum of 1A. Would there be an easy mod for this or a whole new design? I have ordered a couple of other “Charger Doctor” type devices to see if they will allow a 2A pass thru.
Probably because the voltage it to low, i.e. the "Charge Doctor" has to high internal resistance compare to the voltage from your charger.
This is something I test in my reviews of usb meters.
The Charger Doctor will pass 2A to non Apple devices but only 1A to an iPad. This with an official Apple 2A wall charger.
So would this device inserted after the Charger Doctor and before the iPad allow a 2A charge rate?
Sweet,! I hadn’t picked up that particular detail from the datasheet.
Ok, got boards in, got em put together, tested, on a data downstream port get .45A, thru the charge booster on the cable, first off computer doesn’t see device, and it pulls .75A, (correction, moved to another port, seeing .94A) the cord I have has alot of loss
Updated OP, will more than likely do a giveaway for one of em, with only 2 small SMD items on board, it’s a really easy and cheap DIY anyway
I will say this, the pads on the female USB part are very narrow, I might fix the component library file for the board even though it’s in the sparkfun repository
It should, the tablet my wife uses pulls 1.67A out of the dual port DCP board I made a while back
