Hello all,
I have 1000's of C to D adapters available. I am selling them on eBay. I would much rather sell them outside eBay because of the eBay and PayPal fees, which means the cost to you would be cheaper.
If interested, please contact me at: geovel56@yahoo.com
Battery Buddy™ product description and instructions are below:
The product is called “Battery Buddy™,” which adapts the size of ANY “AA” battery (heavy duty, alkaline, rechargeable, etc.) to a “C”and/or “D” size battery. Battery Buddy™ provides the convenience of buying/storing one size battery only, and NEVER worrying about what size battery your electronic devices require. In essence, with Battery Buddy™, you NEVER need to buy the much more expensive C and/or D batteries again!
1 package contains two (2) "AA" to "C" adapters and two (2) "C" to "D" adapters (total of 4 pieces)
Also available are: Box - contains 12 packages
Case - contains four (4) boxes (total of 48 packages)
1000+ packages are available.
Simple as 1, 2, 3
Battery Buddy™ has a 3-In-1 application:
- “AA” to “C”
- “AA” to “D” and
- “C” to “D”
The expected use duration of a “AA” battery is approximately one-fifth of a“D” size battery. The expected use duration of a “AA” battery is approximately one-third of a “C” size battery, however the cost of operating the same device using one "AA" battery vs. one “C”battery or "D" battery is substantial. This means YOU SAVE MONEY in addition to convenience!
Battery Buddy™ is ideal for use in electronic devices which require batteries such as:
- Flashlights
- Clocks
- Toys
- Portable Stereos/Radios
- Small Appliances, and so much more!
- Great in EMERGENCY situations – If the “C” or “D” batteries in a device (such as a flashlight) are “dead” simply use “AA” batteries from another device you have available which uses "AA" batteries, and Battery Buddy™ for “C” and/or “D” size battery required devices, OR “C” batteries from another device and Battery Buddy™ for devices which require “D” size batteries.
- The uses are endless!
Instructions for using Battery Buddy™ are as simple as One, Two, Three!
3-in-1 uses
ONE
For use in devices which require “C” size batteries:
- Insert any “AA” battery into the Battery Buddy™ “C” size adapter.
- Insert combined assembly into your device.
(Note: One (1) Battery Buddy™ “C” adapter is required for each battery your device requires.)
TWO
For use in devices which require “D” size batteries:
- Insert the Battery Buddy™ “C” size adapter into the Battery Buddy™ “D” size adapter.
- Insert any “AA” battery into this assembly, negative (-) end in first such that the (+) end is
showing.
(Note: One (1) Battery Buddy™ “C” adapter and one (1) Battery Buddy™ “D”adapter is required for each battery your device requires.)
THREE
- Insert any “C” battery into the Battery Buddy™ “D” size adapter.
(Note: One (1) Battery Buddy™ “D” adapter is required for each battery your device requires.)
©Copyright 2008, Ellengie, Inc. All rights reserved.
