FastTech SolarStorm SC01/02/03 lights
226 posts / 0 new
DBSAR
DBSAR's picture
Last seen: 19 hours 8 min ago
i just recieved my set of these, and all came with the XM-L2 emitters, but different tints. I noticed though the start is different than usual stars, it has three wires connected. a + , -, and a N.
Have anyone modded these yet with regular starts like a copper noctigon ?
leaftye
Last seen: 1 year 1 month ago
Could neutral be a way to pull heat from the mcpcb?  I've talked about doing that, except soldering it to the inside wall of the head, and I might finally give that a shot now that I've figured out how to electroplate copper onto aluminum.
The low mode should be lower.
DBSAR
DBSAR's picture
leaftye wrote:
Could neutral be a way to pull heat from the mcpcb?  I’ve talked about doing that, except soldering it to the inside wall of the head, and I might finally give that a shot now that I’ve figured out how to electroplate copper onto aluminum.
I haven’t torn it down far enoigh yet to see what the N-wire is form or tried a regular star yet.
Serifus
3rd wire is main ground for driver.
DanielM
DanielM's picture
Last seen: 9 months 4 weeks ago
Can you mod these to change the driver and/or emitter?
Old-Lumens wrote:
I love modding, but I don't have much use at all for flashlights in general.
WarHawk-AVG
WarHawk-AVG's picture
Emitter sure (swap out the aluminum star with a sinkpad or noctigon…driver, were workin’ on it Wink
leaftye
How does that work when there's thermal compound under the mcpcb that electrically isolates it?  I can see when it's soldered to the body like in your light, but using the star seems backwards.  Even if the star is held down with screws, it's not guaranteed that the screw will make electrical contact, especially when there's dielectric under the heads of the screws.
spamman
Last seen: 5 years 9 months ago
I got an sc03 and it has not worked properly since I received it. The power button only sometimes turns it on, sometimes it just flashes when I press. Sometimes it works but just turns off after 20 or 30 seconds. I am getting a replacement sent but does anyone have any idea how I might revive it?
DanielM
DanielM's picture
Than that’s all good, they look like great hosts with the Olight styling. The electronic switch might be a problem.
locusto03
Last seen: 14 hours 42 min ago
After using it only a few times (less than 10 minutes of total use), my SC01 has started to flake out on me, flashing and turning itself off.  I need to find something to pop out the pill assembly without destroying the driver.  If I can do so, I may as well do a driver swap.
Also, in case anybody cares, the TIR optic that fits in the Convoy S2+ fits really well in the SC01, as long as you reuse the lens and replace just the reflector.
DBSAR
DBSAR's picture
I had my SC01 apart to swap the emitter once. ( i removed the emiter first then pushed the driver out from the front)
locusto03
Thanks, it was much easier than I expected.  I just used the biggest socket that fit in the battery tube and gave it a couple light taps with a mallet.  Now to troubleshoot the flakiness.
keltex78
keltex78's picture
Has anyone replaced the lens on their SC01 yet? I gifted mine to a friend, but the lens has broken and I want to order a replacement for him... I don't have the light available to measure... Anybody know the diameter so I can order spares?
Keepin’ the “B” in BLF
Don wrote:
It sounds like the XM LEDs won’t really be suitable for flashlight use. Pity…
blueb8llz
Last seen: 8 hours 5 min ago
has anyone done mods to these lights. i really like my sc03 but want a bit more output
locusto03
I don't have a caliper, but I'm measuring about 22mm x 2mm with a ruler.
elsayedhussin
Last seen: 7 years 2 months ago
how it handled a low/drained battery?
Everything about LED ceiling lights types, led bulbs types, control led lights, new collection, prices, offers
http://ledceiling-lights.blogspot.com
keltex78
keltex78's picture
The SC01 I purchased and gifted to a friend in June has died this month, only lasted for three months. The light was operated using NiMH cells only, no 14500s. When he brought it back to me, I tested using both known-good cells and a 14500 but it wouldn't function either way. I completely disassembled the light, which turned out to be much easier than expected.
  • Press the head of the light firmly against a rubber surface, (e.g., old inner tube, shoe sole, etc) and twist CCW to remove bezel.
  • Remove lens/reflector/o-ring
  • Press pill out of body; I used a couple of stacked sockets of the correct diameter to fit the battery tube, then used a large C-clamp to press the pill out through the head.
On removing the driver from the pill, I noted corrosion on the components. It looked similar to what you would see if liquid had entered the light, but it's been kept dry. I cleaned and checked the LED and solder joints, but the driver is definitely dead. I'm fairly disappointed with how long this light worked.
Second note, the lens is an odd 22mm diameter. The light had been dropped once before, and the lens had cracked. The lens size isn't common, and I was unable to find a replacement lens through normal sources. I could have purchased a flat glass watch crystal cut-to-size via an ebay auction I found, but it would have been over $6 after shipping. That's the only option I had found after a cursory search...
Tom E
Tom E's picture
Last seen: 19 hours 17 min ago
flashlightlens has UCLp lens in that size, and close sizes as well. Just have to check the thickness, if it will work out. It's pricey but better than the stock for sure...
I haven't modded mine.. But think the driver can be replaced or piggybacked...
Chicken Drumstick
Last seen: 10 months 1 week ago
Does anyone know where to get spare switch boots from for these? Specifically the SC02 (18650 one).
My SC02 seems to have lost its one, so I can’t turn it on anymore.
M4D M4X
M4D M4X's picture
Last seen: 4 months 4 weeks ago
my sc02 died over night…
used it not longer than 2 hours total.
pill is out – I will have a look when I get some time ( means baby and wife are sleeping when I don’t ;))
PLEASE NOTE
i do not work in "reviews, deals and codes" for the time being
maybe M4D M4X will return one day, but until then:
THANK YOU FOR YEARS OF YOUR SUPPORT AND FRIENDLY CONTACTS!
DBSAR
DBSAR's picture
The switch boot from a Olight S10/15/20 can be made to fit and work.
phantom23
phantom23's picture
Last seen: 1 hour 30 min ago
My SC02 NW from BG died as well. But I don’t think it’s the switch – after pressing for 7 seconds it turns on in strobe mode so switch itself it works. There’s something wrong with the driver.
EDIT. I disassembled it, tightened everything, assembled again and it works! I don’t know what was wrong, driver was 0,5mm our of the pill so I pressed it flat but I don’t know if that was a reason. But I can see beam isn’t perfect now, there’s slight donut hole. And now lowest mode turns on after 2 seconds, not 4!
phsinvent
phsinvent's picture
Last seen: 3 years 2 weeks ago
I have lost some hope in the sc series of lights. I was selling them for a while but i had too many returns. The driver died in a few from heat after they were ran for extended periods. When the light was off. The led would stay faintly lit. All the other bad ones had problems with the side switch. Bad design. The switch solder points are way too close to the pill. Sometimes the switch shorts out on the pill. And you have to press the button super hard to get the light on. It is too bad though because it was a neat little light.
phantom23
phantom23's picture
My SC02 broke down again, symptoms are identical – they only thing that works is a strobe mode after 7 seconds of holding the switch.
DBSAR
DBSAR's picture
So far the three i have been working great & used often. (SC01, 02, 03) i hope they stay working or the manufacturer fixed the issue people have been having as i like the design and form-factors of these. My SC01 with a Nichia 219 get used quite a bit and is my current Jacket EDC.
Werner
Werner's picture
Last seen: 2 years 3 months ago
Anyone tried to get a replacement from fastech/solar storm? It’s obviously a consistent manufacturer mistake…
M4D M4X
M4D M4X's picture
I got the money back and ordered a 1405 Instead Big Smile
PLEASE NOTE
Serville
Serville's picture
Last seen: 7 years 1 month ago
I got my SC02 last week. It worked the first time I tried, but now suddenly not working. I have no clue why it stops working after a week unused. Battery voltage still full.
What could be the problem ? Bad switch ?
From what I’ve read , it seems fixing this is a very delicate process.
This is the worst $15 I spent on a flashlight. Even my cheapest $2 worked for at least 3 weeks.
phantom23
phantom23's picture
Press and hold the switch for 7 seconds. Does it enter stobe mode?
Serville
Serville's picture
nope. the led stays dead.
Too bad I found this thread too late.
RMA will cost me more than half the price of SC02 alone.
This could only mean I just burnt my $15 for nothing.
