The disease is getting worse. I thought I could hold out for the BLF Edition GB light. But, in a moment of weakness, I bought this light. You guys talked me into it! That’s my excuse when the wife asks! Anyway, I’ve just made my first purchase from GB. I paid the $1.99 extra for tracking, as per the advice given in another thread. :bigsmile:
I thought Courui releases another new thrower by reading the title… this is actually the one some of us have bought previously, but not at the price as good as this of course. Thanks tatasal for bringing this deal up.
Driver
The simplest way to bump up the current of this light is by removing the R120 resistor and bridge across it. This way it gives you near direct drive on high mode. But I have an issue by bridging the resistor, when the light is turned off the LED still glow dimly. I used a crappy soldering iron to do this and I suspect the driver was damaged so do it with care and good soldering iron guys.
LED
Since there is 26mm Maxtoch DTP board available it is advisable to use them so that the soldering joint won’t interfere with the big flat reflector bottom. I used 20mm Noctigon back then and it is a pain to make the solder joint really flat, and still not ideal.
Noctigon and Maxtoch boards are thinner than the stock aluminium board, so you should add additional copper sheet under the DTP board to increase its thickness, otherwise the reflector will be too loose inside and cannot be screwed down tight later. If you don’t want to reflow additiong copper sheet underneath, the alternative way is by unscrewing the pill by a few turns to raise the position of the LED, but this will leave questionable heat transitiveness to the flashlight body, not sure about this and it’s up to you. You may add copper sheet under the pill to solve this though.
Lockout
Since it is electronic switch some people may want to find a way to make it able to lockout. It is doable with janko.hrasko’s method .
Since I wasn’t familiar with this light before I have spent a lot of time trying things and kind of mess the light up. I have lost interest in it already and I might want to let it go to somebody else.
Just wanted to let people know I’ve so done a few of these for customers and am more than happy to do others.
I have 2 on the way (unfortunately only one from GB, I ordered another @ full price about 2 weeks ago from AE).
What’s with the half drilled hole under the button? Needs drilled out for an indicator.
+1 The HD2010 is a beast to focus properly with a dedomed LED.
Thanks guys for sharing your comments/experiences with this light.
@ cereal_killer: If you have a link, you may post it here.
Again, that’s true BLF spirit right there.
Thanks a lot, I waited forever for a good price on this. :bigsmile:
I like this one but I don’t really like electronic switches.
XP-L wouldn’t change anything because it has the same beam profile as XM-L2.
I liked my first one so much, I immediately bought a second! The size and overall shape just fits the hand nicely, and with 3 18650’s the run time is superior with less sag when hot rodding. And, uh, well, they’re both hot rodded.
The e-switch is great with a reversing UI in a FET driver. This lets you go directly to Turbo or moon, as you wish. Love that!
I’ve got one with an XM-L2 de-domed and working far better than my 2 HD2010’s (369.25Kcd with an UCLp lens), the other has an MT-G2 utilizing 6 Efest Purple 18350’s. I limited that one to 3000 lumens in the firmware as it was wanting to make over 4000 at 100% and making more heat than I wanted in this light. I wasn’t feeling up to making a copper heat sink for it, so I used an ounce of silver instead. Works all right, would have preferred the copper with more mass.
I highly recommend this light. These immediately became personal favorites. :bigsmile:
Argh!!! Trying to resist . . . must resist . . . c'mon self, you can do it! :)
-Garry
This is a better HD2010 with 7500mAh cell capacity (or more!) Resistance is Futile!
Think of the CHILDREN!!! Ah, go ahead and buy one. I gave in, you should too! J)
WHY, WHY, I’m asking WHY You all are doing this to me??!!
I didn’t wanted to order more lights before EEX6 GB, but You did it to me, and had to order one of this J)
Hope it’s gona be another great light for mod :bigsmile:
FYI - I contacted vestureofblood about a copper pill - he has ordered a sample and will be looking into it
Bucket is already making one as well, he’s had a Courui for a while now, since before he got onto the Damascus build for Matt.
Count me in! I’ll be very interested in a nice, thick copper pill for this!
Yeah, same thing I said above. I want one!
I knew that I should have waited before clicking ‘buy’ for one of these lights from another vendor…….could have saved almost $10 !
Ho-hum
Yep, I bought one a day/or two ago, for $32.07, oh well, I didn’t pay 38.
