I want to show it off as a bike light but I’m not sure I need to do that. My X2 and SF90 combination already makes me the brightest bike at night in my town. Besides, I’m still looking for an appropriate power source for this as the common 2S2P battery packs won’t work. :~
Maybe this would make a good flood/search light for my car?
Great job! I'm very happy for you and that you make it to work with the new driver. I hope you'll examine it's all settings - selecting from 10 intensity levels. Documenting currents/watage on all levels would be nice too. They should be somewhat linear except at the high end.
Mine driver does flickering at lover levels when powered by 3S2P pack. It might be different with 3S1S because of higher voltage drop. Have to try this to see the difference.
Need one small detail. How/where actualy did you trim those white center rings? What effect that has in a beam or brigtness?
I love your mod and what a fantastic read. Thanks for sharing. The machinist doesn't look to happy in the second picture and he must use that four jaw chuck on his lathe for everything he does. I'd hate to have to lift it of manually. Excellent effort.
Just like the old driver, the new DX driver was press fit into the housing. That’s why we had to ensure during the lathe work that the inner diameter of the newly fabricated housing opening is exactly the same as the outer diameter of the DX driver.
Also the driver is not a perfect circle. There is a portion in the PCB where it was supposed to be connected to another PCB during manufacturing so you shouldn’t file/smoothen that up. You’ll need that to ensure that the driver will fit snugly to the housing.
I’ll add the gathered data on the current/wattage readings of all levels in this review. I haven’t tried it yet since I spend most of my time last night setting up then resetting up my equipment at flashlights outside because of the on-and-off shower. That’s why a car was included in the pictures because it was used to secure/hide everything in case rain would suddenly fall. :~
For the centering rings, I simply used a nail file taken from my wife’s manicure set and it did the trick. It can be seen in the foreground in one of the pictures. Actually I also took a nail clipper from that set to nip the DX switch. :bigsmile:
Yes your observations are correct. He’s used to working on large and heavy flanges and the smallest he’s worked on, before working on this light, was 10 inches in diameter and weighing 5 kilograms. This is actually the smallest thing - and the most delicate - he’s worked on so far so he had to make a lot of fine adjustments before starting the Lathe Machine.
Actually he told me afterwards that if it was somebody else who asked him to do this lathe work then he probably won’t. I guess its a good thing to have good friends wherever you go.
Nightbird95, no need to hurryy now. Take your time to discover it's features. Also note when something unusual happens ie. falling back to "safe" mode cause of temperature rise or voltage drop.
Last night I've put together mine 6x light and fix the driver into its final position. Flickering with 3S2P pack has almost gone. Trying before with 3S1P while driver was still hanging out still showed flickering. So it looks its good position of outer ring in the light is curing that.
It is obvious that it takes much more power from the batteries when powered with 3S2P pack comparing to 2S2P (or 2S3P). I'm wondering how long it can actualy run under so much power. I'm bit sceptical.
Tonight it is going on a ride with some other lights. Will try to take some pictures.
Have you done watage calculation based on starting voltage? If so I find it wrong as when the current rise the voltage is dropping. You should read the voltage and current at the same moment. Then you'll get some lower power readings than those you published. If I'm wrong, take my apology.
We should put results in the table and/or graph for easy reading, but take it easy .
Ok. I assume you don't know exactly how to wire it, right? Here we go:
If you want to check charging batteries you just reverse the connectors (assuming you are using tipical 5.5x2.1mm connectors). That way you can check how Li-Ion 8.4V chargers are working. Found one which doesn't stop charging at all. It came with some red letters on the label. Probably sign of red flag ;-)
PS. Voltage reading could be little lower than without it because of voltage drop over this gadget. I've experienced 0.1V difference but this is also the smallest increment when showing figures above 10V, so the exact difference is unknow, but should be below 0.1V. This would result in a error of +/- 0.4W reading at max. No big deal.
Yeah, you’re right. That’s why I’ve programmed mode 2 (mid) to level 5 which is only about 10.7 watts and I’ll be using this most of the time when riding my bike. The high mode (40 watts) will be only used when necessary.
Now it will be necessary to use high when its time to brag my bike light to my friends. That’s one of the perks of being a member of BLF, right? :bigsmile:
I ‘googled’ the instructions of using this gadget last night and ended up with many contradicting instructions. Well I think I finally made it work and one thing I observed was that the voltage of my power source being measured is 11.7 in my DMM but only 11.4 in this gadget.
I’ll try this diagram tonight and see the difference.
Ledoman, my Volmeter/Ammeter seems to be defective. I tried following the diagram you posted and these are the results:
With all the components connected but with the X6 power supply (Shocker Battery Case) still off, volts and amps both read zero
However, when the X6 power supply is turned on, the ‘gadget’ reads the voltage of the power supply which is 11.8 volts, but says 49.7 amps. The Ledoman X6 is still off when this reading is taken. And in fact I cannot turn it on at all.
Here’s a closer view of the connections. Have I done it wrong? :~
