Wow. I was thinking it might just be whether or not there’s a ‘button’ underneath the green plastic — I looked at mine — which both tailstand — and neither has the little green plastic cylinder molded onto the underside, or they were cut off flush.
I swapped a different colored cover on — after cutting the cylinder piece off — and that still tailstands. But if I hadn’t trimmed that bit out it would have fallen right over.
Waiting a bit nervously for my next flashlight to arrive. What else could be different?
Dang, think I got that variation too - need to look more closely. See how the one of the left is polished up and the one on right isn't? Some minor differences... Hope the one on the left is the new batch.
Just a speculation: they sold many many torches of the first run, the better one, they have finished them and now are being replaced with a similar model but poorer. Could it be?
Well, we are always talking about a 7,99$ flashlight, with solid pill + Xml2, right…
“Nice Well Enterprise” is DealMetic —
—-EDITED
Yes, their web page address is dealmetic.com (in some of their other light ads under Contact)
Dang, now should we suspect the better quality lights got diverted? Hm?
I just got a $3 eBay “Ultrafire” zoomie that’s much like the cheap version of the DealMetic light
— smaller emitter, so smaller spot at full zoom
— narrower flood at its widest, because the lens doesn’t get as close to the emitter at flood extreme
— almost the same tailcap as the second picture above, white plastic around the button, though it can’t be pressed down into the aluminum part of the tailcap
— bezel is flat, not crenelated (and rather orange-peelish, needs the opening smoothed out, it could cut you if you put your finger where the lens comes through it)
— Came without any O-rings and no flat round gasket between the bezel and the lens, and some scrapes/ less polished metal
— hi/lo/strobe.
— Emitter buried deep visible through both a thick white plastic washer and a shiny thin metal foil ‘reflector’ over that
The specific risks involving Li-ion IN SERIES are much greater than the typical risks associated with Li-ion in general. Mainly the cells in series MUST be perfectly matched- both current charge state as well as capacity, as little as 100mAh difference could cause a “vent with flame” (the industry term for an explosion) and the stated capacity of a cheap chineese dealer can not be trusted, you never know what your getting from them as they often rewrap recycled cells.
If you don’t own equipment to test the individual capacities of each cell you plan to use in series the only option is to source your cells from 100% stand up vendors so you know you’re getting new genuine cells. You should make sure you’re using matched pairs, even of the same exact brand / type of cell that may have different numbers of charge cycles or be in different conditions, especially when wearing them on your head!
Recived any new PMs from Vince other than thanks, he explained quite candidately that he know nothing about lights and asked if brighter is better or less bright on top of that were fighting a the language barrier.Just an update I haven’t blown of this post just no new developments.
I don't think so... Only ZeusRay branded, only from the one source of DealMetic.com. freeme - you got a link? Also note the design of most of these SK73 clones is different than the ZeusRay - the ZeusRay has a wider flood mode due to it's closer position of the lens to the LED. I sanded down the crenelation of the bezel on my ZeusRay.
I got my first batch of XM-L2 U3 1A's from Hank at IOS, and replaced the XM-L2 U2 1A I had in the ZeusRay last night. Results are outstanding.
With a fresh Samsung 25R, build is Nanjg with 11 7135's, total of 3.85A, XM-L2 U3 1A on Noctigon, screwed down to pill, 22 AWG wires, replaced the tail switch with an Omten, wired both springs:
3.92A tail reading, lumens (full flood): 1,370 @start, 1,306 @30 secs, throw (zoomed out): 21 kcd (measured at 5 m)
This is the best #'s I've gotten from any zoomie, and it's a 21% boost from the XM-L2 U2 1A I had in there, but, that XM-L2 U2 1A may have been suspect since it had something wrong with the dye (doggie icon showed in zoomed out beam pattern).
Edit: It was just noticed the U3 1A silicone dome touch's the lens at full flood position, just barely. Don't think it's a problem - the silicone softens up when heated with the LED on. Just a matter how hot it gets and if long runtimes in hi will cause damage to the lens. I could pop off the MCPCB and sand it down a little - it's at about 1.53 mm now at the pads, about 1.50 mm where there's no tracing or pads.
Guys, can you give me some advices?
I’m not a really fans of zoomie light…I got an Ultrafire Z5 clone, 2x 18650, about 600/700 real lumens (they sell for 1600 :bigsmile: ) when use 2 good cells like Eagletac…Z5 Trustfire very good flood and nice throw (I have paid it only 9$ shipped)
…and I know that we are talking just about 7,99$ shippend, and seem they are bucks well spend…but, I got to buy others light (my list is long ), and maybe this Zeusray it’s just a copy of Z5 ( just a little more lumens and only 1x18650), and at the moment can save 7,99$ for something else.
Get a Zeusray, you really can’t go wrong. You will probably prefer it over your Z5, as it will be twice as bright, half the weight, and you will begin to feel like Zeus himself once you use it.
Also it works great attached to a hat using the included clip. For me this is the best feature, and it is secure enough for walking jogging or biking.
The number isn’t quite realistic. I order when the back-order number is about –7, but the item arrive just around same time as first batch. THEN the back-order number still same.
Order another unit, haven’t arrive (longer period than last time, forgot what no. am I in the queue though) it aren’t that bad as it seems.
