The one i built above took a bit of time to build, not sure if there is any profit in it for the time and parts used.
I have it calibrated very well now though.
Nice work DBSAR! It looks very handy with all the mounting options around it.
The accurateness of professional spheres has much less to do with the actual sphere, much more with the better measuring equipment and calibrated sources, a home made sphere like we make already has excellent integrating properties.
Good point. for most of us the only way to âcalibrateâ our Integrating Spheres is calculations based on testing our stock known ANSI measured Lights, in my case is a few fenixes, Nitecores, Olights, thrunites, etc.
For the purpose of consolidating information regarding IS's here are a couple of links for those who may be interested in a source for Barium Sulfate products for the inside coating if one were to choose that method.
This is just one supplier that was mentioned in another forum. It is not known if they are more or less expensive than any others.
Labsphere, Inc.
A Halma Company
P.O. Box 70
231 Shaker Street
North Sutton NH US 03260
+ 1.603.927.4266 (ph)
+ 1.603.927.4694 (fax) labsphere@labsphere.com
Welcome to BLF!
Matchâs coating was plain flat white paint without BaSO4 what I remember, but his sphere was made many years ago and Match is not around here anymore.
A BaSO4 coating can indeed be 0.96 if done well, but I doubt that DIY formulations containing BaSO4 will be anything close to that, and even if someone did a good job at it, the experiment for testing the reflective value is difficult without proper laboratory equipment. And then you also want to measure the reflectivity across the spectrumâŠ
I donât really understand the concepts behind an integrating sphere, I wish there were an affordable one just because Iâd like to test my mods. This would certainly be reflective, but aside from putting a hole in it ruining the structural integrity/shape I assume there are many other reasons it wouldnât work that Iâm unaware of. https://www.amazon.com/TONIFUL-Hangable-Aluminum-Metallic-Decoration/dp/B07X655671
Seems like there is a decent market for this and data logging light meters, Iâm mildly surprised we donât see some package deal priced well out of China.
If you are willing to pay loads of money for shipping from EU, you can get a 50 CM (around 20â) eps ball that makes a fantastic sphere. Theyâre about $40 US, but shipping will easily be that much. That will handle reflectors up tp 110 mm and many tens of thousands of lumens. I have a 30 cm one I use for testing and itâs great. You need a calibrated light or one of verified outout to set the multiplier for getting your relative lumen values, but once calibrated, you can get very close (5-10%) to the actual output. Djozz has a great tutorial for it on here to where you donât need a baffle, ND filter or diffuserâŠyou measure the light through the wall of the sphere and that works. Mine is only good for reflectors up to 65mm, so I built a lumen tube. Point is, there are options for integrating devices that donât cost hundreds or thousands of dollars.
I see people referencing calibrations. I am sure it would take me a long time to catch up on the people and their methods, but would a sphere like that get me at least 5% precision?
If under a couple hundred total cost, time tweaking and learning is my concern, though I can totally see enjoying that process.
