CREE T6 LED 5 Mode 1000 Lumens 8.4V 18650 Flashlight $28.04 - airsoftpeak
Thanks and very much looking forward to receiving my first order from you guys!
Expire on October 4th, 2014.
Item ID:13396 http://www.airsoftpeak.com/-p-13396.html
Item ID:13231 http://www.airsoftpeak.com/-p-13231.html
Item ID:13233 http://www.airsoftpeak.com/-p-13233.html
Buy any of the flashlights above, you can get any of the flashlights below for free.
http://www.airsoftpeak.com/advanced_search_result.php?keywords=flashlight&inc_subcat=1&pfrom=2.99&pto=4.99&page=2
Besides, you can get a $5 cash coupon. You can use the coupon next time when your order is over $10.
If you’re interested, free feel to pm me or email me at activity@airsoftpeak.com. If you don’t like the three flashlights I list above, tell me the one you want. I’ll help you.
If you don’t like this promo, feel free to share you idea.
Abby
09/26/2014 - 10/15/2014: 40% off on LED 100 Lumens 1xAA Flashlight Silver delivered with coupon code 123walker
http://www.airsoftpeak.com/walker-diary-frosted-lumens-1xaa-flashlight-silver-p-13344.html
There are some interesting gear there i may be interested in depending on the deal. :slight_smile:
Buy One, Get One For Free? Where is the deal?
Why not tell me which are the interesting gear?
Just leave a message when you place an order, we’ll add the free flashlight you choose to your order. :slight_smile:
Some of the tactical gear i’m interested in, like the Tactical Gun Lights, the credit-card knife, and more.
Hi,
For the gun lights, I’m sorry to tell you that you just missed our anniversary sale: 15% off sitewide. But 8% newmember or 10% birthday discount may help.
For the credit card knife, we can send it to you as a gift if your order is over $20 or 40% off on promo day.
10% off
coupon code:14550a
http://www.airsoftpeak.com/-p-14550.html
10% off
coupon code:14551b
http://www.airsoftpeak.com/-p-14551.html
If you check out directly, you won’t be able to use the coupon code.
So don’t ,
please to use the coupon code.
UltraFire 501B CREE U2 LED 5 Mode 900 Lumens 4.2V 1x18650 Flashlight Black
Price:$20.99
Now: $16.79 (20% OFF+ Free Shipping), save $4.20
Coupon code: 13231a
Number available: 15
nice sharing .
501b can easily be had for around $8 or even cheaper. $16 is grossly overpriced
Not the same one, I guess. Parts are diffrerent.
http://www.banggood.com/Ultrafire-CREE-XML-U2-OP-WF-501B-1200LM-5modes-LED-Flashlight-p-912658.html XML U2, same five modes.
Also: U2 is the bin (=index number for lumen output ratings at certain currents), the emitter (LED) itself is an XML. This is important since some LEDs share bins.
18650 Li-Ion cells run at 3.6 V, they hold 4.2 V directly after charging but that drops to 3.6 very fast when in use. It’s the ‘working voltage’ of most Li-Ion cells, similar to how NiMHs is 1.2 V (~1.4 after charging) or alcaline cells 1.5 V
:slight_smile:
The bulb of this flashlight. It can be found here.
4.2V 900 Lumens.
And I don’t know if the bulbs have the same beads.
Begin: 11/05/2014(mm/dd/yy)
Expire: 11/17/2014(mm/dd/yy)
Soshine Li-ion 18650 Rechargeable Battery 3.2V 1800mAh 20% OFF
price now: $12.79 (20% OFF + Free Shipping)
Coupon Code:14599a
Soshine Li-ion 18650 Rechargeable Battery 3.7V 2800mAh 18% OFF
price now: $13.93 (18% OFF + Free Shipping)
Coupon Code:14600a
I see. That is most likely the max. voltage at which this module can operate. Drivers have a range of voltages they can work with, like 3.0 to 4.2 for lithium cells. If that voltage is exceeded the components on the driver may take damage, if it’s too low the flashlight may not turn on at all due to low charge protection for Li-Ion. The LED itself wouldn’t benefit from a higher voltage either as it has a typical forward voltage of 2.9 to 3.35 (max 3.5 at 700 mA), i.e. the driver down-regulates its output voltage to that level anyways.
Authentic xtar cr123as? A nd if so what is average shipping time to West coast of US? please reply to me by pm thanks.
XTAR D06 CREE XM-L2 900 Lumens 2.75V-4.2V 18650/18700 Diving Flashlight Set Black
http://www.airsoftpeak.com/-p-14790.html
$13.99 OFF
coupon code:14790
Number Available:5
Expire:12/01/2014 (mm/dd/yy)
Free Shipping Worldwide!
*Water resistant to a depth of up to 100 meters
Expire: 11/24/2014(mm/dd/yy)
No coupon code is required.
LC-XML CREE U2 LED 3 Mode 550 lumens 2.7V-9V Bulb
LC-UV Ultra-violet LED 380nm-450nm 3V-6V Bulb
LC-XML CREE U2 LED 550 lumens 2.7V-9V Bulb
LC-XML CREE U2 LED 5 Mode 550 lumens 2.7V-9V Bulb
