I was thinking the same thing. W/O looking up the dimensions of this carrier ur post basically confirmed my suspicions that it will run nicely as a 3aa D-sized serial cell carrier.
Thanks!
EDIT - Oops! should have read further down the thread. Apparently this carrier will be closer to C celled size.
That depends if you trust the specs. Remember that until yesterday it was listed as a parallel battery holder. More than likely it's exactly the same as the battery holder that comes with the X3 from IOS. That battery holder is 30mm in diameter, and the body is a little over 61mm long, and roughly 67mm long if the (used) spring is counted.
Looks to be a nice light. I just recently bought an Olight i3s Eos for my wife to carry. I like the style of this Tank007 ES12 as well, and the size really is great for carrying in a pocket (or purse). This light also has a higher lumens rating than the Olight. But the Olight comes with both a belt clip (or hat clip, since it’s reversible) and a key chain with a nice clip on the end. And both lights work with 10400 cells for better performance!
Now the Cofly KX-D010 2 x AAa light is showing on your site as “in stock”??
( button is orange)
Did you find more of this “out-of-production” light, or is this a mistake?
