HA! Twenty one XM-L’s.
if that could really put out 25000 Lumens, it would melt the Aluminum head after it set fire to all the LEDs, requiring Two RV DeepCycle 800-CCA Marine batteries, and Booser Cables for wires to provide the Amps required to push all those LEDs to 1190 Lumens each. At least is a bright as my supper.
It’s rated at 54 watts and can only be run on 4x 18650 or 4x 26650’s. I’m sure it’s very under-driven, so I doubt heat would be to bad. But I have no interest in purchasing this one. My next light will be the Trustfire TR-J20, expecially if I can get one with XM-L2 NW.
i would guess thats about right. Its not likely much more than 3000 OTF lumens stock if lucky. I just noticed in the Item Specifics on that page it says “Lumen: 3800” , - though the title says 25000LM.
I wonder how many un-educated people are seeing that and buying it, ( along with some cheap Ultrafire cells) after reading 25000 LM and expecting something that will light up a Ball Stadium.
It’s actually a more efficient way to run a light. Also it really just depends on what kind of driver they have used and how it’s wired. Not that I am too interested in it but with the right driver and wiring it could be interesting. Run a single amp to each emitter and you are looking at about 4,500 lumens. (4,000OTF) It wouldn’t get very hot at only an amp per emitter and with four good 26650’s you would actually have decent run-time for a 4,000 lumen light. Or stick a FET driver in and drop one emitter, wire it 4P5S, 4 mode with a turbo stepdown.
Of course the $125 price tag is a joke but if they have them on sale for 50% off plus a $10 coupon I would pick one up just to play with it. But then again I love playing with these plunger lights. Half the fun is seeing just how messed up they have it right now.
Personally, I’m waiting for the release of the to-be-very-much-coveted 105 x xm-l T6 cannon that promises 168,000 lumens and uses 20 x 26650s. Included in the price will be a forklift to carry it around (hopefully).
False advertising is false advertising, this I don’t agree with.
That said, in anybody’s book, 3000+ lumens is still a lot of light. So ok, this might not be the most compact way to achieve it. But it does probably offer good runtime (and likely regulation) and manageable heat vs the price.
