Eneloop AA - Is this a new Warning?
21 posts / 0 new
18650
18650's picture
Last seen: 2 years 3 months ago
Is this a new Warning? Is there a reason why? :~
I was planning on purchasing a 4 pack of Eneloop Pro AA (BK-3HCCA4BA) for my new Nitecore EA41 Pioneer but I changed my mind after reading the Caution on the back of the pack: “Do not use in water proof flashlights or any device with an air tight battery compartment”
Same CAUTION is on the back of the Eneloop pack sold at Costco with (10) AA, (4) AAA and Charger (Item#906576)
Edited by: 18650 on 10/03/2014 - 01:50
264
264's picture
Last seen: 2 years 9 months ago
It is a new warning. I had a couple of the eneloops outgas in flashlight recently. Sad
Ricflair
Ricflair's picture
Me too. Of course it wasn’t a stock light. I pulled too hard on them. Melted the battery carrier & gassed out a cell.
Hey, but who cares! I am no expert, but I don’t think there is enough gas in 1 cell to make the light explode. But, I am a idiot, so don’t listen to me.
If you have a Saltytri you want to unload, hit me up. If you don’t know what that is, google it.
Old-Lumens
Old-Lumens's picture
Last seen: 5 years 11 months ago
ANY battery technology can out gas and none of them should be in air tight or water tight containers. YES, that includes all of your flashlights that are water tight to a certain depth, meaning just about all of them. Yes, any of them could allow for cells to create a buildup of gas pressure and yes, bad things can happen to any battery, even alkaline. I've seen that too.
Have you ever noticed most everything else "electronic, with batteries" will allow for water to leak inside, if dropped in water? It's because that means air can escape too, so venting can occur. They design them so batteries can vent, instead of building up gas and exploding from the pressure. Flashlights are basically little pipe bombs and more unsafe than many other battery operated devices.
My PayPal address: oldlumens (insert the @ sign here) gmail.com
My YouTube Flashlight Video Channel
The BLF Modding Links Thread
http://imageshack.com/a/img922/1374/jQ2wdL.jpg
antiparanoico
Because we can make depth charges… We can sink submarines!!! Big Smile
I use them since June (from ChibiM) in a EA4 inside a car, no problem.
If anything can go wrong, it will.
Matter will be damaged in direct proportion to its value.
Richwouldnt
Richwouldnt's picture
Last seen: 1 year 9 months ago
Location: Reno, NV, USA, Terra, Sol, Milky Way, Known Universe
OL said about what I was going to post but said it better. Basically the new warning is lawyer speak, presumably after some incidents of using Eneloops in lights which tried to discharge them faster than designed. IMO not surprising when you consider how fast the new Thrunite Neutron AA light tries to discharge them and lord knows about user modified lights.
Rich Wood
Reno, NV
Bort
Bort's picture
Last seen: 5 hours 42 min ago
do you have links to these?
The Journal of Alternative Facts
"It is critical that there is a credible academic source for the growing and important discipline of Alternative Facts. This field of study will just keep winning, and we knew that all the best people would want to be on board. There is a real risk in the world today that people might be getting their information about science from actual scientists."
flydiver
Last seen: 43 min 58 sec ago
Jeez, and here I’ve been diving for almost 20 years with NiCads, NiMh, alkaline, and now Lion all in WATER tight containers! Kee-rist! I coulda been killed! Shocked Why didn’t anyone tell me? :quest:
The problem arises when you push the battery well beyond it’s specs, then it may out gas. Obviously you do that TOO much and you have a pressure bomb. Know the limitations of your battery and device, use accordingly and you will be fine.
When that water tight light somehow fails to fulfill that specification and saltwater leaks in, the electronics go kinda berserk. The corrosion as those batteries dump is pretty nasty.
To Air is Human, to Respire….Divine.
Ejected Filament
Ejected Filament's picture
The cell contains no gas at all (or very little anyway). Dont view as a container of gas and thus its size being the limit of gas. It has chemicals in it, solids, and they convert to gas. When it starts to gas, there is considerably more gas than the package of the cell would imply.
texaspyro
Last seen: 3 years 4 months ago
Cuz we want you dead so we can inherit your lights… J)
Richwouldnt
Bort;
Note that I said “presumably” about outgassing and as the new Thrunite Neutron claims 480 Lumens on one AA and 800 with two then I am again presuming that the current draw is ridiculous. See the Potential Issues section of Selfbuilt’s review on CPF where he notes issues with single AA operation on one light and too great a current draw from 16340 batteries other than IMR versions for the CR123a/16340/18650 Neutron. Unfortunately he does not give any current readings.
http://www.candlepowerforums.com/vb/showthread.php?389222-Thrunite-Neutr...RCR%29-2014-Review
Sorry but as an ex quality assurance test and specification compliance test engineer I tend to interpolate and combine data from multiple sources and keep asking myself how things can relate. Over the last year or so a combination of increasing light outputs from new relatively small lights and more junk batteries out there has made me more concerned about safety issues. Just a bit surprised that apparently one of the first warnings comes from one of the best batteries available via this outgassing warning. Got a feeling that at the extreme of performance this warning may apply to ALL NiMH chemistry batteries and sealed lights.
Rich Wood
Reno, NV
MountainKing
Last seen: 4 months 1 week ago
I’ve had my my quark aa2 tactical tailcap switch ‘expand’ like 3 times in over 2 years. It became quite hard to press. I knew it was some kind of gas buildup at the time. I figured it was somewhat dangerous and each time, I recall putting the light out and waiting some time before unscrewing the tailcap out….
Never ever forget and forgive. Niwal**er new kid on the block trying to act tough.
http://budgetlightforum.com/node/24847
Do not support this brand.
DINODIRECTSCAM COMPANY. DO NOT BUY
http://budgetlightforum.com/node/11324?page=2#comment-254983
fartybum
Last seen: 8 years 3 weeks ago
Which it does.
Keron
Keron's picture
hope it doesnt become an issue since im running AAA eneloops in Olight O’Pen-
You’re not wining, you’re surviving.
fartybum
Been using them for years, they’re just covering their butts.
WarHawk-AVG
WarHawk-AVG's picture
Last seen: 2 years 5 months ago
What’s that saying? “Remove the warning labels, let the problem sort itself naturally”
:bigsmile:
lagman
lagman's picture
If you are concerned about NiMH being a problem when enclosed, think about your 18650 lithium batteries… Now that’s a nice pipe bomb!
I think it would be a nice protection to include a safety vent in all flashlights. That would be cheap, stop water from coming in but the seal would break if the cell inside vents.
My English isn’t perfect but I’m trying to improve it. If you see something that doesn’t sound right or is just plain wrong, please feel free to point it out! Smile
Keron
Keron's picture
well then i think i should stop worrying about it
Dimbo The Blinky
Dimbo The Blinky's picture
Last seen: 1 hour 47 min ago
You mean a Flapper Valve. I’ve seen such a thing on Safety Flashlights at the chemical factory. They are basically little holes in the flashlight body with a flap over it. I forget who makes them, but I believe they were Streamlight Xenon 3C models…
“There is no darkness but ignorance.”
Bort
Bort's picture
This quote is full of win
Boaz
Boaz's picture
Last seen: 3 hours 39 min ago
If you have problems with eneloops believe it ..it's user error
 they are covering their butts because users are blockheads
                 υμεις εστε το φως του κοσμου ου δυναται πολις κρυβηναι επανω ορους κειμενη
