…or the Cree measurement error in binning. One the datasheet they state “Cree maintains a tolerance of ±7% on flux and power measurements.” That’s an error in binning basically the size of a one bin step. Even before any errors produced in testing by an end user that nominal T6 could be putting out low T5 or high U2 output when it shipped.
"Cree maintains a tolerance of ±7% on flux and power measurements." - this is so CYA all the way. If you were CREE and dominant a market as they do, you can get away with pretty much anything. This reminds me of our touch screen vendor at work. Get the things out in the field for a few months, and customers have to touch the displays harder and harder. Send back a bunch of returned pieces to the vendor for testing, and they say all are within spec -- duh, the spec's tolerance is so big, it's useless! So, field service tells the customer to roll your finger - make contact with the finger nail and it works fine... This is not a solution, so aggravating...
All data recalculated from Cree XM-L2 and XP-L data sheets.Minimum lumens from CW with 85°c junction temp and Cree 7% + or - tolerance.T and U bin are XM-L2,V bin are XP-L.
The XP-L V3 bin sits between XM-L2 T6 and U2.The U3 and V5 bin are effectively the same.
The V6 bin is ahead on it's own,one bin higher than the highest,and still rare,XM-L2 U2 bin.
What's not to shout about,it's the new highest bin emitterfrom Cree.
I'm still practicing formats,sorry it is not easier on the eye.
Billy X, I already posted the images from PCT.CREE.COM for comparing the same current on XP-L V6 vs XM-L2 U3, XP-L V5 vs XM-L2 U2, XP-L V4 vs XM-L2 T6 all at 25C, check the previous pages on this thread.
I got a little motivated by Selfbuilt’s excellent analysis of the L3 Illuminations L10 on CPF so I brushed off some old and very basic statistics.
The graph we have only shows means for the two types of emitters tested. Without the standard deviation for the XM-L2 and XP-L a t-test isn’t possible. I decided to make up SD for both to redresh myself on a t-test and now I am sharing. My absolutely wild as guess for SD was based on 1.5% of the mean for each tested emitter. I took the lowest SD from selfbuilt’s analysis as a percentage of it’s mean (XP-G2 on high) and just divided it by two. I believe it’s a very conservative assumption. Still I want to say this is a giant assumption given the lack of raw data to compute the variance.
I used the mean for each emitter type at 30 seconds, the assumptions for SD, and samples sizes of 2 and did a simple t-test computation (alpha=.05, 2 degrees of freedom, two tail test). More information on what I did is in selfbuilt’s CPF review and all around the net. I leave the rest to the reader who wants to torture themselves. What I found…
There is not a statistically significant difference between the output of the XM-L2 U2 1D and the XP-L V5 2A in the data from these tests (again given my SWAG assumption about variance.) Standard deviation would need to be even lower than I assumed (given that all the other data need is known) to find a likely difference.
No proven difference may be flattering, but when one must take “Wild as guesses” and “giant assumptions” then the truth is, you just don’t know. And that, my friend, is usually a good time to stay silent.
A lot of people read these threads, and a great many of those are trying to learn. So wild guesses and assumptions to base a theory of standard deviation is just blatantly wrong and misleading. No offense intended, but without a series of tests to establish facts it’s truly just guesswork.
Ever since the XP-L came out, people have been trying to prove that it’s better (or worse) than the XM-L2. It’s different. And the same. It does pretty much the same thing, with the ability to fit more dies in the same area, thereby achieving Cree’s target goal for array’s and such use. For us? (flashaholics) This small footprint allows us to put the big die where it previously wouldn’t fit. And in that instance, it’s very much appreciated.
The XP-L V5 2A has enabled 3129 lumens in my new Sinner Ti XC with the use of one 18650. And 2960 lumens from a small all copper Sinner Cypreus, from a single 18350 cell. They’ve enabled a AA MiniMag to make 1663 lumens with 3.7A from a Qlite. 921 lumens from a single 10440 cell in a 3” custom Ti light. As far as I’m concerned, this is a win all the way around. Not one of these lights can use the bigger substrate of the XM-L2. Not in the configuration that yields these results. Standard Deviation be danged.
Edit: The Ti XC is using a Carclo 10511 TIR Optics, polished. The Cypreus a 10507. The AA MiniMag is using a quad. All these utilized de-domed XP-L emitters.
The output of statistics more often than not is the same as what we thought already, but it really is a valid way to be more certain about uncertainties. The problem is that people are notoriously bad in dealing with uncertainties, and therefore with the outcome of statistics.
That said, if statistics is applied to unsufficient data, it does not magically make it good data. it can only make it look good :bigsmile:
Offhand I would not assume that these reflectors will fit Solarforces’s drop-ins. IIRC the dropins they use are slightly special. You might have to build a new dropin. If you tear the SF dropin down, be careful to remove the retaining ring, the driver is soldered into it from the inside. Pressing it out from the top through the wire holes will almost certainly destroy the driver.
Thanks for this data. Solarforce just released their XP-L drop in with an OP reflector. I have been considering getting one except if there is little difference in Lux or throw then I will stick with the slightly cheaper XM-L2. I also prefer a well defined hot spot. If there is no difference between the two except for the reflector that again tells me to stick with the XM-L2. I originally thought the XP-L was a stronger replacement for the XP-G2 so it would have dramatically more lumens and much more throw, ie a tighter hotspot and greater distance. So from your data I have to ask Cree why did you make the XP-L? if it is just a slightly stronger XM-L2?
Yes but the Solarforce have two great features even if they are not the strongest bin. One, they have a great voltage spread (2.7V - 9.0V) so I can use a variety of battery configuratioons, and two, they are relatively cheap $16.99.
Solarforce is one of the few host makers that allow me to chose different battery configurations. Most drop in/flashlight makers see their products used with only one battery configuration so their voltage input spread is quite narrow. I wish more companies would make a larger input voltage spread.
[/quote]
[/quote]
I agree each reflector has to be measured. I want to ask RMM @ Mountain to measure his SMO reflectors except they are out of stock so I have to wait until he get a new batch in stock.
I like that UI of these Solarforce drop-ins. Resets back to high after beeing off for longer than 2 seconds. Best UI for mechanical clicky if you ask me.
STAR off-time set to no memory can do that. That's how I set up a lot of lights for guys who always want the light to turn on in either high or low first.
