For anyone who thinks "moon" mode has no purpose...
68 posts / 0 new
texaspyro
Last seen: 3 years 5 months ago
You should always keep a light where the sun don’t shine…
WarHawk-AVG
WarHawk-AVG's picture
Last seen: 2 years 6 months ago
Big Smile
DavidEF
DavidEF's picture
Last seen: 10 months 4 weeks ago
jmpaul320 wrote:
ToyKeeper wrote:
with a clothing-optional-after-dark policy, with one’s Significant Other
yep… been there.
AGREED Smile
So…you’re the Significant Other? Or were you one of the passers-by? Shocked
- The YKK Philosophy
Boaz
Boaz's picture
Last seen: 8 hours 3 min ago
ToyKeeper wrote:
Haha, the light was mostly to get to the water and find a comfy spot therein without getting injured. Also occasionally to ward off others for a bit of privacy. I can't say I was paying much attention to the flashlight after finding a good spot though... Also, kind of important, not bright enough to see anything I would later want to unsee. ;P
 finding the right spot without injury is important ..
Moon mode might help but so would a beacon
                 υμεις εστε το φως του κοσμου ου δυναται πολις κρυβηναι επανω ορους κειμενη
Windsurf
Windsurf's picture
Last seen: 11 months 2 weeks ago
After you arrived at the springs did you place the light on moon mode and put it about 1 foot under water on a ledge to give the springs and eerie glow?
ToyKeeper
ToyKeeper's picture
Last seen: 2 weeks 4 days ago
Location: (469219) 2016 HO3 // I get way more privmsgs than I can respond to, so please ask in a public thread if possible, for a faster answer.
Nope, the water was too murky for that to work. However, I did swim around a bit with the light on a ~20lm level underwater, and I heard a few people remark about it. “Whoa, is that an underwater flashlight?!”
Really, it’s not remarkable. They sell waterproof flashlights at walmart. The interesting things about this light were traits that nobody seemed to notice, like the nice Nichia 219B tint.
breinrules
breinrules's picture
Last seen: 4 years 5 months ago
shouldn’t we use waterproof gear in hot
spring due to nature of thermal expansion?
water might seep in and kill your light
ToyKeeper
ToyKeeper's picture
It wasn’t as hot as my showers… and I haven’t had any issues with water leaking into lights there.
breinrules
redundant, deleted
breinrules
ToyKeeper wrote:
breinrules wrote:
shouldn’t we use waterproof gear in hot spring due to nature of thermal expansion? water might seep in and kill your light
hmmmm, dunno but a friend of mine has her watch
died because of using it in the hot spring. (rated at
50 m or so). the glass might not expand as
much as the metal and water might come in.
maybe the spring there is not that hot?
ToyKeeper
ToyKeeper's picture
I’ve never had any trouble with water leaking into a watch, either… even cheap ones, and even in really hot water. However, I’ve had water damage the watch band several times… and I assume the water would eventually dry out and crack the light’s o-rings in the same manner, but this would take repeated exposure over a period of months.
Pregulla
Pregulla's picture
Last seen: 5 days 17 hours ago
There is a “freezer” test described in other thread by one of the members to test if the flashlight is waterproof:
- Take out the battery and unscrew tailcap to let air in
- Put the flashlight in freezer for few minutes
- close the tailcap, take it out and put it in warm water 40…50C
The air inside will expand and if there is a leak you will see bubles going out of the flashlight. This way you can know for sure if your flashlight is waterproof in hot spring. And even if its not the expanding air won’t let water in unless you leave there for too long.
breinrules
can we say that all airtight lights are waterproof but not all waterproof lights are air tight?
fellfromtree
fellfromtree's picture
Last seen: 8 years 3 weeks ago
I like the drop it in a flooded farm row trick lol Then turn it on and see if it still works. I see they advertize these lights as weapons in a lot of sales. If you banged it around while it was hot- I wonder if the led would jump off the pcb xd I was just thinking about that cause that wouldn’t be a weapon- it would be like 60 dollars and you still get shot!
Martini
Martini's picture
I don’t think I’d need a light if my pasty keister is exposed. My bum is so white that it glows in the dark.
scdaf wrote:
It’s important to have your restraints within walking distance, lest someone needs restraining. Wink
ToyKeeper
ToyKeeper's picture
It was a moonless night.
Joat
Last seen: 2 years 19 hours ago
I thought you said it was clothing optional, did everyone go with the option of clothing?
ToyKeeper
ToyKeeper's picture
The moon is only visible when it’s reflecting light from another source. Hence part of why I didn’t want to use a bright light. ;P
The moon mode on my torch helped me keep the night “moonless”.
DavidEF
DavidEF's picture
I don’t think I wanna know… Okay, here goes: What use do you have for a flashlight in the shower? I know I’m gonna regret this. :~
ToyKeeper
ToyKeeper's picture
It’s for cleaning, silly!
Allll… the… things…
But no, seriously, light + water = win. Haven’t you ever taken a candle-lit bath? Marvelled at the way a fountain looks under a strobe light? Reflected light off the waves from just above the surface to amplify them up onto a wall like a giant watery sunset? Watched the source-reflective water droplets dance around the floor like a thousand little spheres of ball lightning?
Stop and smell the photons once in a while. Smile
DavidEF
DavidEF's picture
Allll… the… things…
Oh, just mood lighting? Phew! The way this thread was going, I was worried there for a while! :bigsmile:
Bort
Bort's picture
Last seen: 1 hour 40 min ago
Allll… the… things…
not sure if sentimentalness or synesthesia (i kid) :bigsmile:
The Journal of Alternative Facts
"It is critical that there is a credible academic source for the growing and important discipline of Alternative Facts. This field of study will just keep winning, and we knew that all the best people would want to be on board. There is a real risk in the world today that people might be getting their information about science from actual scientists."
B42
B42's picture
One kind of interesting thing I did after experiencing the PWM can make rain look different and surreal, especially bad PWM in a light. I turned off the bathroom light and leave the room lit only by the PWM light…some modes make the water look kind of neat, some modes make shower streams look like sparse droplets or broken lines of water. Of course I’ve only done this once with high lumen lights, I’m not sure moon mode would work to give enough contrast …except to show you your moon maybe.
Windsurf
Windsurf's picture
OK I wondered how long it would take before someone followed up on the flashlight in the shower comment. My mind certainly wandered until someone finally asked the question and it was answered.
I consider my flashlights as tools and expect them to work under adverse conditions. And if I were about to have my life depend on the ability of my light to work under adverse conditions I would be testing them in heat, cold and water. But since I’m not in the armed services or a mountain climber I would never take my flashlight into the shower or a hot springs. My experience with water is that one really can’t tell when water will have a negative effect today and not tomorrow so why take the risk. That said, I would bend my rule if the shower contained the right person.
WarHawk-AVG
Allll… the… things…
Do you name your lights Silly
WarHawk-AVG
ok…Googling Silly
Danglerb
Last seen: 2 months 5 days ago
I like moonlight mode for walking around casually, but what is best is a red light so you don’t lose night vision.
Still a bit dim
Bort
Bort's picture
WarHawk-AVG wrote:
ok…Googling Silly
Big Smile
Cereal_killer
Cereal_killer's picture
Last seen: 2 years 11 months ago
WarHawk-AVG wrote:
Do you name your lights Silly !http://www.rgbstock.com/cache1nyygg/users/b/br/brainloc/300/mfXiBLQ.jpg!
Hey some of us name our lights, not every one I build but some of the most special ones, I know I’m not alone either, right off the top of my head Dale has “Texas poker”.
hank
hank's picture
Last seen: 4 weeks 1 day ago
