Sorry, thatās not the correct answer.
My daughter is 11 years old. She has lots of Tagalog riddles but does not sound good once translated :zipper_mouth_face:
Maryās father has 5 daughters ā Nana, Nene, Nini, Nono. What is the fifth daughterās name?
Mary
Sure you guys would know this one but Iāll change it around a bit
This fat guy bumps into this circus clown. Thereās 3 walnut shells on a table and he shows a bead under one. He tells the guy if he can pick the one with the bead after the shuffle he gets $100. The kicker is he shuffles them behind a cardboard box so the fat guy canāt see. After the shuffle the clown knows where the bead is. The fat guy then picks one of the 3 shells.
The clown, knowing which of the 3 has the bead under it, takes one of the empty shells off the table and offers the fat guy to switch his choice between the 2 that are left, or stay with what heās already picked.
Should he switch or does it matter? :bigsmile:
According to MythBusters, he should switch. ;)
Depends on how well he trusts the clown. I think the clown has the bead elsewhere. J)
Heheh maybe he wants the bead as a consolation prize. Yeah raccoon I didnāt even see that on Mythbusters. When first heard of it I couldnāt believe it myself, but that lady with the high iq explained it well.
He picks, and his chances are 33.3. But if you were to make it 100 shells, his chances are 1. She went on to say 100 or 3 shells itās still the same idea. If he takes away 98 empty shells your better off switching, just as if he takes away 1 out of 3. Really interesting stuff cause you wouldnāt believe it unless they ran a computer simulation to prove itās true.
edit
Ayeā¦ I got thinking about it though. Thatās right the only way to get true 50/50 odds is to switch. The odds become 50/50 after the shell is taken away, but not for you until you switch shellsā¦ Man I always thought it was one of those things that is what it is lol
All running late tooā¦ catch you guys later
Easier way to understand it is to have 100 shells and the person picks one shell ...1 out of 100
then the clown takes away 94 shells and offers you another pick ..should you take it ?
easy answer is yes
which do you like better your 1 out of a hundred chance or one out of 5 ?
don't trust clowns
The clown and shell riddle reminded me of another classic.
A clever man in ancient times was due to be tried for murder. He was given the opportunity to be tried by āChanceā. There would be 50 black beads and 50 white beads placed in a bowl. He would then be blindfolded and asked to pick. If the bead was white he would live. If it was black he would die.
He asked the court if he could distribute the beads into two bowls. He would then be blindfolded and the bowls shuffled around. He would then have to pick a bowl, without touching it, reach in and take a bead from it. There would still be 50 black beads and 50 white beads in total and he would still be blindfolded. The court decided they would grant his wish as they could not see how it would make any difference.
This clever man was delighted. He managed to increase his chances of survival to almost 75%. How did he do it?
BTW this is supposed to be a true story from ancient texts and in the original this guy was still very unlucky because despite shifting the odds very heavily in his favor he still ended up picking a black bead.
Well, it sounds good, but upon analysis, he still really had a 50% chance of losing. The idea, I guess, is that he had a 50% chance of a 50% chance of picking a black bead, for a total of 25% probability. The problem with this logic is that he also had a 50% chance of a 50% chance of picking a white bead, which means that he had equal probability either way. The only way he could increase his odds of living would be to pick twice. Of course, even a 50% probability of living, strictly by chance, in a murder trial, is already quite generous.
Iām not sure what you are saying it was that he did?
He puts one white ball in the one bowl
and 99 mixed up balls in the other
giving him a slightly less than 50/50 chance in the mixed bowl
and a 100% chance in the bowl with one white ball
74+ % chance of being white
don't trust murderers
I donāt know if youāre directing this to me, or not. Here is what Iām saying. The man had asked for the beads to be divided into two bowls. The riddle didnāt specify how the beads were divided, but there are two ways that would make sense.
1) Equal amounts of both black and white beads in each bowl.
2) One bowl with all black beads and the other with all white beads.
If the idea was to increase the chance of survival, dividing into an all-black-beads bowl and all-white-beads bowl would not have helped because his āchoosingā action would still yield exactly 50% statistical chance of picking the right bowl, then 100% chance of getting whichever color was in that bowl.
So, that leaves the method of dividing black and white beads evenly into two bowls. Going by the earlier comparison to the other bead riddle, I assumed this is what was meant. And looking at the supposed statistical benefit of changing oneās choice after a known bad choice is removed from the equation, it would seem the same benefit could be gained here. The idea is that he is now choosing twice - once for the bowl, and again for the bead, but not so. The choice of which bowl to pick from will statistically yield 100% chance of getting an equal amount of each color of beads, so it is effectively a non-change. Then, you are still left with a 50% chance of getting the right (or wrong) color of bead from whichever bowl you pick from.
Thinking even further into it, the man may have actually decreased his luck by dividing the beads. Even though in pure statistical chance, his odds are the same, in reality, he had fewer beads to draw from. If you think of polls that are done, or any sampling that is performed, the desire is always to have a larger percentage of the whole to be sampled. And, the larger your sample, the more accurate your results are considered to be. Same thing with star ratings of products we buy online. If five people out of five say the product is good, do you trust that? What about 9995 out of 10,000? Even though 5 out of 5 is a ābetterā rating, it is less reliable because you know there are billions of people in the world and a lot of them may just be not buying it because they already āknowā itās not worth having. So, back to the beads in the bowls. The guy could have had twice as many opportunities to grab a white bead. Although statistically he would have still had an equal chance at getting a black bead, in reality he may have fared better had he kept them all!
total being like 74% chance of being white
donāt trust murderers
Hmmmā¦ didnāt think of that one.
Clever!
Throw away the outside and cook the inside, then eat the outside and throw away the inside. What is it?
sweet corn
sweet corn
Yep!
Eskimos are excellent hunters, but they never hunt penguins. Why not?
For the same reason that Polar Bears donātā¦ā¦ā¦ā¦ā¦
