I’ve seen quite a few people come to this same realization.
Just grab some 10-14 guage wire, pair of banana plugs, and make some leads. I think I spent like $5 on mine and $20 for a DMM and I get very accurate measurements. 2.6A was as close as I could get with the stock leads measuring a 2.8 driver.
I believe that is not a correct statement. Any enthusiast person with the basic knowledge in electronics know Ohm's law and can expect that long and thin leads not to display the correct current on low voltages.
You have to understand that flashlights have many weak point, springs, wires, switches, etc which all add resistance on a low voltage power source (4.15V).
Now, try to measure 3A on 110V power supply, you wont say that a meter rated at 10A is not able to measure 3A with the included equipment. So and establish brand is able to measure what it says, but not in any condition.
14 AWG silicone multi-strand wire works great for me. Very flexible, about 12" or so. I simply solder the ends I use to measure. The other ends are heavily soldered into banana plugs. Once in a while clean-up or re-solder the working ends.
Today i received my convoy c8 xm-l2 u2 1A from banggood. Just one word… wow! With protected cells (both trustfire and panasonic) is brigther than my lightmalls ultrafire c8 xm-l2. Wider hotspot due to the op reflector but also overall more lumes. I think the lightmalls c8 draws no more than 2.5A… bad driver or just bad batch. Much better value than any ultrafire c8 around.
Yes a little . I have a Tenergy in it now and it works fine . I put a 3100 Keeppower and its a tight fit width but length is ok . I would like a little more room.
If for no better reason than USA seller and faster shipping I'm waiting on the xpg2 to be back in stock, unless I break down and buy the xml2 U2 1a too to have it sooner. Pretty curious what the difference is between 3*7135 and 8*7135 (380mA drivers) means in real world application with everything else being equal.
Ordered the Design XML2 U2-1A on BG for a whopping $16 and wow, it’s impressive ! The button is a bit sensitive though so I find I’m changing modes by accident sometimes…I didn’t get the SMO version to have a “smoother” beam but I’m finding that it’s very powerful in the center with a pretty large “halo” around that center beam, is that normal ?
Now on the hunt for some better 18650s as my old “2200mAh” only clocks in at 1750mAh now according to the BT-C3100 I got at the same time.
Thanks for the hint, I hadn’t heard of these two modes but following the instructions here Get the Convoy C8 AK47 from Banggood (8*7135) I managed to move to “Mode 1” without strobe/SOS, cool !
I still find the button a bit sensitive and it’s easy to change by accident.
That center, brightest part, is generally called the ‘hotspot’. The ring of light around the hotspot is generally referred to as the ‘corona’. The outer most ring is typically ‘spill’.
SMO reflector accentuates these rings while giving slightly more throw. Orange peel reflector makes them blend a bit more and is generally more appealing to the eye (slightly less throw).
The prominence, size, intensity, amount of rings, etc tends to vary quite a bit from flashlight to flashlight. What you described is normal on C8’s.
If you’re feeling up to it you can pretty easily take apart the tailcap with sturdy tweezers. The two holes/indents in the retaining ring allow enough purchase to unscrew it and the contents will slide on out. Place a washer in between the top of the switch and the rubber tailcap boot. Experiment with different thicknesses to get your optimal switch sensitivity.
