Project EMERALD log! (SWM F30R mod)
61 posts / 0 new
tterev3
Last seen: 1 day 23 hours ago
I spent a really long time looking at the ring of LEDs, trying to come up with some way to put TIRs or small reflectors in there and still get heatsinking and still make the light possible to assemble, and I couldn’t come up with anything. So I gave up on having nice beams and made this LED board that will fit right inside the aluminum ring with the 12 holes in it. The ring will provide heatsinking and keep assembly easy, and it has cone shapes machined in that will form very rudimentary reflectors. The beams will be very wide unfortunately, but they shouldn’t be ugly. There are 3 of each of the primary colors (spaced evenly so they won’t be off center) and single emitters for 380nm, 405nm, and 850nm. I used XQ-sized components for all so that they’d fit easily into the existing holes. Colors are XQ-E, UV are Lux UV, and the IR is an Osram SFH 4710 which appears to be almost the same package as the Lux UV
Cereal_killer
Cereal_killer's picture
Last seen: 1 year 9 months ago
What if I turned a spacer to fill the gap between the bottom of this board and the pill / light engine housing then polished each individual “reflector” or better yet (tho expenses) had it electroplated?
tterev3
Yeah I thought about something like a spacer for quite some time. In the end it seemed like it was more trouble than it’s worth:
-complicates assembly since you’d have to grease it down to the locking ring
-very tough to get the height just right because the locking ring is threaded in
-XQ parts are designed to heat sink to the top surface of the board
-not really an advantage for optics
Now polishing and/or reshaping the reflectors is probably something to pursue. There’s a pretty large vertical section before the conical section which should be removed. We could do it by milling forward from the back of the ring to move the PCB mounting surface towards the front of the light, but I think the best option would be to keep the depth and reshape the reflectors somehow. I have a weird dremel bit that’s a rounded cone shape that might work for that. Any ideas on drilling in reflector shapes?
Cereal_killer
Since you’re pretty ok with it not being an ideal beam what if you gave up the idea of individual “reflectors”, its going to be almost impossible to machine 12 of them perfectly even, even with a mill (which I have access to) but what if we cut the separation between the “reflectors” out with a ball mill, something high flute count so the finish came out really smoothly (like a 6 flute) so the “reflector” was a polished U-channel. After cutting it I could tumble polish them.
I’ll also look into EP’ing, I’m just guessing to do our two reflectors is going to be way to much $$, that leaves hand polishing or something I’ve never tried before, chrome powder coat.
What angles do all the emitters project?
Thinking about all the work to an unknown alloy, it might be easier just to turn a new “reflector” with the same idea (it could be done only on a lathe). Same size, same bottom but just turn a U groove into the top Scratch that, then you’d have to drill 12 holes and that’s take the mill anyway. I think the best bet it to either simply try to only polish / coat each of the unmodified cup’s, or to machine then into a single channel and polish that.
edit: What about the possibility of making, or having made a single round ring TIR? I wonder if there is a version if PMMA that would offer decent optical properties that could be 3D printed.
rjorge
rjorge's picture
Too bad we can’t get these….
tterev3
Actually I have a couple of those, but they don’t help here since we need a tiny optic to fit in the ~6mm space between housing and reflector
rjorge
rjorge's picture
I was thinking about these, but they are 8mm.
Edit: Head OD looks to be <45mm, so the above wont work.
Cereal_killer
Ok I’ve been studying the .sch for 2 days now, I was going to ask this in email but I figure I’ll put it here for everyone…
It’s the TPS562200 that does the bucking for the color / UV / IR emitters correct? And it looks like either R12 or R14 is the sense resistor for that (tho the values seem high for a sense resistor). So what if multiple emitters are on at the same time, they would get current split like if they were simply paralleled or the chip will increase current to compensate? What’s the max current?
The other question is about what’s going on with the FET and what I assume to be a BJT up top powering the MAXUM chip, this is obviously to shut it down cause of its standby current, what exactly does this circuit do tho? Specifically what does Q1 do (and R9 is just a gate resistor right)?
tterev3
Right
these two form a voltage divider which sets the output voltage by making a 3.5v output produce a 0.765v level at the feedback pin, which is the setpoint the chip is regulating to. The chip has no specific output voltage, and in fact it doesn’t know or care what the real output is, it just regulates to 0.765v on the fb pin. The manufacturer does this so that the same chip can be used to produce any voltage you want.
You’re thinking of constant current regulators, but this is constant voltage for exactly this reason. The led currents are individually set by their resistors next to the FETs, so you can have any number on simultaneously and their currents won’t change. The regulator will supply whatever current it needs to in order to maintain 3.5V, so yes it will compensate automatically. The buck regulator is set at 3.5v because from this voltage I can easily set led currents with resistors while minimizing the wasted power because the voltage overhead is low.
It can supply up to 3A total for the color leds
Q1 is necessary to protect the microcontroller from high voltage and to allow the FET to completely shut off. If you connected directly to the FET gate, when you tried to turn it off by setting the uC pin high, the FET would still see (Vin – Vcc) which could be as high as 12.2-3.3= 9.3V, so it wouldn’t turn off. You could then try setting the uC pin to high impedance and let the FET gate pull-up resistor turn it off, but then your uC would see as much as 12.6V on the pin, which would waste current at best and destroy the microcontroller at worst.
R9 limits base current into the BJT. BJTs are current-controlled unlike FETs so you must regulate base current to keep from destroying them
Cereal_killer
Ok one more Q,
The 3A total to the colors, that’s limited by the TPS regulator or the FET’s?
tterev3
Ok one more Q,
That’s the regulator’s limit, I set the individual current limiting resistors so that total current draw can’t exceed that. I plan to set most of the colors around 700mA
Cereal_killer
Ok well looked up the datasheet and turns out I have a few more Q’s still…
It states 2A max, I’m assuming you’ve used this chip before and already know it can do 3A? You must be using the TPS563200?
What’s the reason for having the sets of 2 parallel cap’s (C11/C12 & C13/C14) instead of just one at each location? To keep them from getting saturated? Also I notice you’re using quite a bit less total capacitance on each of the pin’s. I believe I remember you saying this is the exact chip you use on your MELD driver, so I assume your way works fine, why the difference from spec?
tterev3
Actually you’re right, I had 3A in my head but I’m using the lower power version. The firmware only allows ~1.4A maximum at one time with all colors set at 700mA so it won’t be an issue.
You’re right that the amount is low, I generally just put the 0603 package on there and then fit as much capacitance as I can. I’ll probably get more than 20uF total on the actual board. The reason to have multiple caps is to layer them for better filtering—a 10uF in parallel with a 0.1uF will filter out high frequency crap much better than a single 10.1 cap. The reasons for this get into much more science than we should include here I think…
Here’s the final version of the schematic with a few updates:
Cereal_killer
So today I’m looking at the voltage regulator for the MCU and I see it’s polarity protected which effectively protects the MCU, are any other components susceptible to batteries being inserted (regardless if any one, two or three are inserted) wrong?
tterev3
I’m not sure how the TPS562200 or the MAX16820 would handle reverse voltage. Both would be fully exposed to it if the batteries were put in backwards.
Mixing up the directions is another matter—you’d be applying reverse voltage to one of the cells which could get dangerous.
I have polarity markings and springs/contact plates which both differentiate the cell direction, I’m not too worried about them getting mixed up.
Ledsmoke
Ledsmoke's picture
Last seen: 1 year 3 months ago
tterev3 wrote:
<snip> Mixing up the directions is another matter--you'd be applying reverse voltage to one of the cells which could get dangerous. I have polarity markings and springs/contact plates which both differentiate the cell direction, I'm not too worried about them getting mixed up.
Do not underestimate the resourcefulness of idiots! LOL
That was not to rain on you parade or degrade your great work at all. Nor your thinking. But I am reminded every day that common sense is fairly uncommon!
Keep it up. It looks like this will be the do-all end all light. Love to read these threads and all the Q&A/R&D that goes on in them though some of it is lost on me Big Smile
~ Ledsmoke ~
Dutch humor:
[quote=djozz]
 I do not think that the BLF-community ben
tterev3
Yesterday I found a countersink bit at the store that looked like it was the right size, so I reamed out the holes in the aluminum ring:
I couldn’t go down far enough to remove the vertical section, but the height should be ok. Here’s how high the XQ sits:
and OSHPark shipped all the boards to me today!
tterev3
IT WORKS! I’ll get the pictures up tonight
Ledsmoke
Ledsmoke's picture
NICE! Looking forward to them Big Smile (  <- add Drool)
~ Ledsmoke ~
Dutch humor:
[quote=djozz]
tterev3
Sneak preview:
ImA4Wheelr
Last seen: 1 month 5 days ago
^ That is a thing of beauty.  Congrats tterev3 Smile
Cereal_killer
Wow nice!
M4D M4X
M4D M4X's picture
looks great!
PLEASE NOTE
i do not work in "reviews, deals and codes" for the time being
maybe M4D M4X will return one day, but until then:
THANK YOU FOR YEARS OF YOUR SUPPORT AND FRIENDLY CONTACTS!
MRsDNF
MRsDNF's picture
Last seen: 2 months 4 days ago
Well done. I love the words it works. Better than cursing.Smile
tterev3
I was so excited about this project that the timeline looked like this: opened OSHPark packages 5pm Wednesday, LED board and main board populated by 8pm, woke up at 5am to build daughter board and assemble, light finished by 7:45am when I had to leave for work. Yes I’m insane
The build went very smoothly. Here are all my bare boards compared to the stock boards:
My measurements were good and the LED board fit right into the ring:
I populated the LED board first. Here’s a shot of the reds under test:
Checking the fit of the LEDs in the “reflectors” formed by drilling out the holes with a countersink bit:
To prevent any shorts against the aluminum, I put kapton over all exposed holes on the top of the LED board:
And then very carefully epoxied it to the ring with arctic silver. It gets pretty good thermal contact since the entire top surface is a fill plane connected to the anode of all the LEDs, and then that top surface is thermal epoxied to the aluminum ring.
On to the real boards. The only parts I transplanted from the stock boards were the battery contacts:
Here are my two boards front and back after assembly:
Before mating the two I added all the wires in for everything that connects straight to the main board:
And then I attached the daugher board via its four interconnects (Vin, Gnd, Dim, Enable):
I preserved the original wires, LED, and star board from the stock light, and connected it up to my white channel buck driver on the daughter board:
I kept the original switch board and wired it in, and started feeding all my wires up to the LED area:
The thermistor I used for temperature monitoring is an 0603; I tweaked the wires until it sat down on the LED star:
And then tacked it down with arctic alumina:
Then came the fun step of connecting all the wires up to the LED ring:
And done!
I’ll do a writeup of the software updates soon. Suffice to say the up/down button configuration makes the user interface so much better
Cereal_killer
I wondered what you were doing online at 5am lol, saw your name listed before I went to bed.
So do you have other plans for the driver, or more work on this? Noticed it in the sch- the unpopulated pads…
MRsDNF
MRsDNF's picture
Not only that you took pictures at the same time and it worked. That in itself is amazing to me. Smile
Ledsmoke
Ledsmoke's picture
You are amazing! That would take me for ever to do I think. And the code and the hardware and... I should shut up now. Not really making any contribution. Just amazed and intrigued. Well done.
~ Ledsmoke ~
Dutch humor:
[quote=djozz]
tterev3
This project has been finished for a while but I’ve been terribly lazy about putting up a video! Here’s a quick demo of the finished project. I didn’t go into any detail about the modes since most things function the same as MELD (which you can see here: http://youtu.be/B09tLW9JaXI), so this mostly discusses the things that are different for this two-button version of the firmware:
Cutchya
Last seen: 2 years 5 months ago
Love this thing !
