Led Lenser P7.2
Hi my friends!
today i want to show you one of my first “real” LED flashlights: the Led Lenser P7.2
(i compared it with my Zeusray $7.99 light)
since i used it a lot it has some signs of wear – but due to its superb quality not much of them!
( it survived a 50m roll/jump down a cave )
it has a pretty red circled tailswitch with a simple UI:
half press for turbo (320lm)
1st klick HIGH (250lm)
2nd klick LOW (40lm)
the size is very nice to operate the zoom with one hand – but geting to the switch is another story (like ALL tailswitch lights!)
you have to use the “tactical grip” or both hands (which is PITA if you want to use the turbo)
lets have a look into the bright end: (P7.2 on the right)
flood:
zoom:
the Zeusray uses a plastic aspheric lens (cheap²) while the P7.2 has a TIR Lens…
the TIR has less loss in brightness – but is more expensive.
a gif from the zooming…
beamshots taken 1m from the wall:
(P7.2 left on “my” high ;))
Led Lenser always “miss”adjusts the focus so it stays blurry – i tweaked it a bit to get a sharp image of the emitter (Cree XP-G2)
okay – lets open the beauty!
the battery carrier carries 4 AAA batteries:
one plus / two minus – batteries are in series
i love to disassemble things!
the spring loaded contact-”pins”
PCB Contact side
PCB Swich side
the switch – it only circles direct drive / left and right set of limiting resistors
veery “simple” for a “high end” light
there is NO! regulation at all! just direct drive with resistors in Series to the batteries to limit current which resuts in different brightness levels.
lets open the head:
removing the plastic ad carrier gives free vision of the LED on a custom copper PCB
that ARE flat contacted wires…
the pill:
the contact side of the pill:
the inner side of the contact PCB with one of the two current limiters
I DO NOT LIKE limits…
i hardly remember the numbers – but turbo went from 0,8 A to around 2A
all new deals are also posted here: deals.m4dm4x.com
if you do not find what you are looking for :
ask MARTIN@M4DM4X.COM - i will save you money!
Nice breakdown. You see, with such simple circuitry modding is easy, I kind of like this mechanical mode switching
link to djozz tests
To be fair, Lenser don’t claim regulation with this model. So not exactly unexpected. Also many other lights are direct drive.
Curious though, what exactly do the resistors in the pill do vs the ones in the switch? Would it be easy to fit a Qlite 3.0amp driver in there?
My Torch & Flashlight Reviews
My YouTube channel
Notable Reviews:
Convoy S2+ | Zeusray Domed & De-Domed Comparison | Maglite XL200 | Rofis TR18 XP-L HI angle and tube flashlight | H4 (HB2/9003) Car headlight XM-L2 | A8 BLF Edition
Thanks for sharing. Very nice to see the teardown.
Chicken D, to me it seems like this:
Turbo: Current goes through resistors in pill
Mode 1: Current goes through resistors in pill and one set in the tail
Mode 2: Current goes through resistors in pill and the other set in the tail
Im assuming the body is plastic, the emitter is an XP-E2(?), and the 4 batteries are AAA. None of which are good for 3A.
BLF LED database – collaboration spreadsheet and latest news about where to buy LEDs
http://budgetlightforum.com/node/19342
Body is aluminium…
how can i be sure about the LED Type?
i get 2A DD… 3A seems far away
( and i don´t wanna try to use a LiIon cell )
Love how your $8 light smashes this $70 light.
God I hate Led Lenser…seriously, a light that big with only a single XPG2 emitter, just wow…
Nice tear down, cheers mate.
Walking past the flea market where some guy is selling these lights for $80 – “breathe man, breathe. Just keep walking…….”
What are the chances of them being fake at a flea market? lol
mod this with a copper pill, an imr 26650 and driver
and this will outthrow flashlights twice its size
and price?
I have the first P7 version, and also the P5. Despite them being unregulated, I really like them. P7 has a very good throw, and I love the zoom feature.
But nothing beats my Powerlite XRE in throw. I throws better than C8 XPE, and it has variable brightness. Push & hold the tail switch, it will starts dimming progressively to the lowest level and going back up to the brightest level. It can shine a building approx 250m away although it’s quite dimmed. The spot is too tight for close-range use though, so I hardly use it.
I’d say that unless the LED measures 5mm long on one side it’s an XP-G2. The die size appears to be too large for an XP-E2 and the little mark in the corner is a square, not a circle like the XM-L2 has.
Still fine, still on a break. One day I’ll catch up with you folks! previous wight catchup
list of my drivers & variants (A17DD, FET+1 stuff, WIP stuff, etc)
Thanks for sharing that! I am a flashaholic but have never really been mechanically inclined like my Uncle/Cousin/Brother[engineers] and like a lot guys on here who can take these lights apart and modify them!
I can take many of my lights apart[smaller/midsize ones]…then have no clue as to how to improve them! :~
Solitude breeds contemplation which creates clarity.
Environment molds a person. Perseverance changes them.
WOLFDOG
Why does it seem to me visually that the guts of this led lenser appears to be like a garbage $2 flashlight? So unesthetic when compared to flashlights like sunwayman, fenix etc let alone the spik sk68/clones.
Disclaimer: I have no knowledge in circuitry/electronics.
Never ever forget and forgive. Niwal**er new kid on the block trying to act tough.
http://budgetlightforum.com/node/24847
Do not support this brand.
DINODIRECT – SCAM COMPANY. DO NOT BUY
http://budgetlightforum.com/node/11324?page=2#comment-254983
From what I’ve seen and heard the build quality is around or above the level of a good Convoy, consistency is very high, and engineering is superior. Fit and finish should be in the “very good” range. Take a closer look at the pictures – the battery carrier appears to be in a whole separate league from the stuff you are comparing the light to. The switch is a 3-stage or 2.5-stage or whatever forward clicky! Limiting resistors at the tailcap seem to be something “big,” like 1210 – especially considering how low current this thing is. Very conservative (eg safe/reliable) component sizing! I can’t see what size those 2R4’s are but I think they are even bigger. The MCPCB is copper, although who knows whether it’s DTP. Maybe M4D M4X could do a quick electrical test for us – probe for continuity from the overflow pad on the side of the LED VS the copper portion of the MCPCB. Also + and – connections to the MCPCB are done with tabs so that they can get the blanking plate really low.
Aesthetics are a matter of perspective, but LED Lenser’s style is not my favorite one either.
If you get a chance to hold one of these things in hand you’ll probably feel a little bit embarrassed for some of your other lights. I know that’s how it works for me. Don’t worry: turning it on and seeing the conservative output will help ameliorate those feelings.
it’s a simple light but imho very good made!
I measured 3,4mm in square at the LED
and Amps :
LOW 0,087 A
HIGH 0,95 A
TURBO 1,86 A
with good used eneloop
Can you measure electrical resistance between the exposed copper of the MCPCB and the little overflow pad next to the LED? I’m talking about the pad between “2012523” and the LED, not the + or – pad.
Nice review. Judging by the die size in the pictures, the led does indeed look like XP-G2.
These are available from Fasttech for ~$33, but I do not know if they are genuine or not. Fasttech has photoshopped branding off the pictures for some reason.
nvm
sorry – I forgot to write it above (had to bath the baby)
yes – it’s DTP!all new deals are also posted here: deals.m4dm4x.com
i fully charged my white eneloops and meassured again:
LOW 0,22 A
HIGH 1,4 A
TURBO 2,6 A
my meter gives 30 kLux @1m 8)
the zeusray reads ~10 kLux
What is the lux output of one of these?
do you mean Lumens?
since I have no light box I could only ceilingbounce…
but with which light to compare?
No – lux or kcd measurement. This records degree of lumen concentration, or its beam hotspot intensity. Tells us how good a thrower it is.
How does its long distance throw compare with the $8 cheapie you have?
http://budgetlightforum.com/node/34815#comment-661239
what’s wrong with that post?
That is quite a lux increase for something off the shelf, stock and runs on AAA batteries that you could give to anybody to use safely. And it’s still pocket friendly too.
And I can vouch, the tactile quality, fit & finish on Lensers is superb.
Retail price I agree is a tad high, although in the UK a new genuine P7.2 is slightly cheaper than an 2AA EagleTac D25 so isn’t so uncompetative as some make out.
My YouTube channel
Notable Reviews:
I’d love to see how this light handles a 26650
I don’t think a 26650 is possible. I have a similar light at home (POP lite T34), which is very similar to the original Led Lenser P7, but runs an XP-E instead of the XR-E found in the Lenser.
It uses the same 4AAA carrier and same size body. And it’s just a mm or so too narrow to accept a 26650. I think you’d also struggle with length too. And if I recall correctly, the battery carrier has the + and – terminals on it, it doesn’t pass the – through the body. So you’d need a li-ion in a carrier too.
My YouTube channel
Notable Reviews:
26650 is to large for the body, a 25500 will fit perfectly
Im about to mod mine, i’m looking at installing a clicky button into the bottom along with a proper driver pill in the head, something like this gear from FF
http://www.fasttech.com/products/1420/10000432/1046602-25500-37v-5500mah...
http://www.fasttech.com/products/1610/10007065/1576100-clicky-switch-for...
http://www.fasttech.com/products/1612/10001686/1122401-4-amc7135-2-group...
How is the heat with that resister bypass, does the light get really hot at 2600mah? I might rip mine apart now and do this myself
Also I tested the battery carriage and that outputs 5v, changing the resister in the pill wouldn’t that over volt the LED, would be safer to alter the battery carriage so boost mode was on constantly
EDIT: I just ripped mine apart then, pill is 21.5mm, one could easily fit a regulated booster power supply to this thing, bypass the resisters in the tail, alter the carrier to run series and parallel giving you 3v with long run time, there is many possibilities even when using the AAA setup.
A friend just bought a Lenser P7.2 for his bike and asked me to bring some of my cheapie lights for a comparison. Funny enough it was one the same as the Zeusray that impressed him as it has a similar flood pattern but outlasted it in run time when left on side by side. He can’t believe the performance for the price so I can see him buying a couple. Of course the Lenser is in a different league when it comes to build quality.
I loved my P7 then I gave it away to my friend, then within to weeks it got stolen which made me quite sad.
The lenser is a funny torch. It divides people. What I found was exactly like the comments above, some people love it and those who don’t, really hate it. However most of them have never even held one.
Personally I liked it a lot. Quality was superb. It was also a proper zoomer with no loss of lumens when zoomed out. They are a bit expensive but so are a lot of lights.
I have so say though shortly after buying my p7 I bought a Klarus p2a which I liked much more, but I still miss the Lenser.
Eagles may soar, but weasels don't get sucked into jet engines!
