STAR Firmware by JonnyC - Source Code and Explanation
Here is the thread of my temperature monitoring driver. Microa's single XP driver board
This was 'solved' by using Atmel Studio 6.2, the problem code now flashes correctly.
FWIW I also tried:
Change to “static uint16_t ticks = 0” with 240 (instead of 600 above) for the turbo timeout.
This result in a timeout near 2 minutes. Not sure why 600 wouldn’t yield 5 minutes…
Thanks Microa.
Heh, :beer:
Sorry, I didn't provide all of the code for you. Try changing...
if (ticks < 255) ticks++;
to...
if (ticks < TURBO_TIMEOUT) ticks++;
Will the following changes give me a single mode setup?
Tried them and received several errors from Armel Studio 6.2:
Add // before a line to have it ignored.
//#define MODE_MOON 8 // Can comment out to remove mode, but should be set through soldering stars
It seems it works as I modify:
#define ADC_LOW 130 (130=56C)
#define ADC_CRIT 140 (140=60C)
Change
if (ADCH < voltage_val) {
if (++lowbatt_cnt > 8)
to
if (ADCH > voltage_val) {
if (—lowbatt_cnt > 8)
In fact, the 140 shut off the light will not happen because the power to LED already has been ramped down when the temperature reach 130.
Better now but still getting this
If you're using MODE_HIGH as your single mode, and not turbo, you also need to comment out #define TURBO_TIMEOUT.
Are you also disabling low voltage monitoring? (if so, why?) When you comment out settings at the top, you have to go hunt for other stuff farther down that refers to the things you disabled. If you re-enable #define VOLTAGE_MON those two errors will go away and it builds correctly.
You saved me once again!
If I have only one mode (turbo), voltage step down will work, since I re-enabled the vol mon?
Cool. Good point, I guess a sudden jump from 55c to 60c would be a huge thermal shock: never going to happen unless you drop it in a volcano. I hadn’t thought of that.
I think for step-down to work some extra stuff has to be done. STAR steps down by lowering the mode index (it changes the mode to a lower one). If you only have one mode defined then the stock STAR ontime or offtime firmware can’t step down. Momentary might be different, I don’t remember.
I think RMM has a post about that subject around here somewhere. I don’t recall how he was working around it.
zeremefico, “MODE_TURBO” (255) mode includes a timed step-down to “MODE_HIGH_W_TURBO” (110). This is independent from the low-voltage-protection step-down. “MODE_HIGH” (255) uses the same brightness but does not include a timed step-down. You do want Turbo?
I had problems with high (set at 255), as only mode, so i chose turbo only.
Johnny - that did it. Thank you very much for your help. It’s certainly appreciated.
I took star off-time memory 1.3 and modified it to add the feature that the longer press (of reverse clicky switch) cycles back the mode. (It’s less than 10 lines of additional code).
Finally I have the perfect driver for me.
Let me start by saying thanks to RMM and to everyone who has contributed to this code.
Let me say next you can put what I know about doing this between these 2 brackets ( ). Not much. With that in mind...
Tom that is awesome.
Am I understanding correctly that this code can be used with a 7135 based driver and ONLY a momentary switch (no dual switch)?
If so how do you wire the switch? Got a picture maybe?
Finally would it be possible to get this code in an elf or hex? I really know nothing a bout writing code, but I do have an avr programmer running AVR studio 4 if that will work.
Thanks again all.
So are you saying you can now use the forward/reverse function with just a reverse clicky? No secondary momentary switch?
JonnyC is the mastermind, I just got the benefit of creating the OP since he was out of town. I've been a beta tester, at best.
  • This FW can be used with 7135 and FET drivers, or as a piggyback to another driver
  • One side of the switch is wired to the switch pin (Pin 3 by default) with the other side to ground
  • There is a "dual switch" version also available, but I'm not sure if Tom E. has added his custom tweaks to this one
In a dual-switch light (momentary side, tail clicky) the tail switch just acts as a lockout, it won't change modes. The driver will behave the same as if you disassemble to swap batteries, meaning the FW will reset back to whatever the default starting mode is after using the tail clicky.
edit: Is the dual-switch specific version able to avoid that, so the tail switch lets it work for signaling/whatever? I haven't looked at that one yet.
Yes. It is basically like the normal momentary version, but with memory.
