Thanks to those who have participated so far. 12 responses. Continue the effort. The more the better!
Graphical view + stats of votes so farā¦
Done
Done.
One thing, I chose AA only, not because it is cheap or because I do not want 14500 compatibility, but because that makes it possible to make a nice current controlled modes driver. Drivers that are (also) 14500 compatible (with modes still working) always have PWM controlled modes.
(with the only little understanding that I have of drivers).
Done
Weāre at 22 people chiming in. Keep em coming guys. Thanks.
done
Done.
I noticed near the bottom under misc options you have āsquare threadsā listed twice.
participatedā¦
Filled it out :bigsmile:
Done. One thing extra I mentioned is that it would be sweet to have this:
tighten the head to go to turbo,
loose the head for moon,
then no memory needed, and we can have moon or turbo. Just like what fenix LD20 has.
Thanks for the nice form, MK! We sure can use this for lots of things in the future.
I like them "purdy colors" you got there on that there flashlight!
-Garry
I think I prefer electronic sideswitches. They allow more sophisticated UIs. Something like:
Click and hold from off: moonlight
Short press from off: turn-on in last mode used
Click and hold from on: cycle modes up
Click and hold from on again after previosly cycling modes up: cycle modes down.
Double-click (from on or off): shortcut to max power
Single click from on after light has been on at least 3/4 of a second: turn off
Thanks for pointing out Iām new to this stuff. I donāt know if it will affect something. So, Iāll leave it
Itās ok. The least I could do!
50 responses so far!
āPurdy colors (ano.)ā
pretty colors (anodization) aka. anything other than normal black or grey.
better than my form, thanks.
Done 8)
The options create a selection bias making the results largely useless, but nice try.
65 responses so far.
Thanks for your insight. I wish to point out I have no statistics background or ābias freeā form creation skills. I used responses already put forward by people and added some stuffs I think people might be interested in.
If it is slightly useful, then it served its goal. Else, all good its the intention that counts
done
Iām done.
And why donāt you consider Nichia NVSL219B-V1 high CRI and high output?
75 replies so far. Thanks guys. While making the form I was not only dead tired (really) but ill. To be honest I tried so hard to remember that high CRI emitter called ānichiaā but could only manage luxeon :S I thus added an āotherā option.
Nichia and high output seems like not realistic or with crap runtimes from all the posts Iāve read here and there. I could be wrong though. You could add it in the last open ended question though.
