Diffusion Techniques Testing - Various Methods
52 posts / 0 new
Boaz
Boaz's picture
Last seen: 4 hours 18 min ago
[quote=siata94]I'd found the post by Selfbuilt on CPF, his test showed 3.2% loss with DC Fix Sand. I saw Stripes (not the movie), I'm curious to try it either on its own or combined w/ Sand to see what it does. http://www.berlinwallpaper.com/dcfix/images/stripes.jpg[/quote]
Lighten up    Francis  !!!
garrybunk
garrybunk's picture
Last seen: 3 weeks 1 day ago
Boaz]</p><p>[quote=siata94]I'd found the post by Selfbuilt on CPF, his test showed 3.2% loss with DC Fix Sand. I saw Stripes (not the movie), I'm curious to try it either on its own or combined w/ Sand to see what it does. <a href="http://www.berlinwallpaper.com/dcfix/images/stripes.jpg[/quote">http://www.berlinwallpaper.com/dcfix/images/stripes.jpg[/quote</a> wrote:
This?
1
-Garry
My Bike Lights Thread, Optics (TIR) Comparison Beamshots, Diffusion Techniques
, MTBR’s Lights & Night Riding Forum
NOTE: Now hosting my photos from my Google account. Post up if you can’t see them. Older photos hosted on Photobucket or Flickr may disappear (PM me if you want access to them).
ToyKeeper
ToyKeeper's picture
Last seen: 4 hours 21 min ago
My favorite diffuser is a frosted lens. Not spray-on frosting, but a genuinely frosted piece of glass like what the Zebralight ‘F’ models use. It provides a basically flawless beam. DC-Fix, OTOH, has lots of little artifacts in the beam. It’s not very noticeable most of the time, but if you rotate the light along its beam axis the artifacts will be visible while they’re spinning.
DanielM
DanielM's picture
Last seen: 7 months 2 days ago
This thread inspired me to do something I’ve been postponing for a good while: diffuse a headlamp, the $7 one that was a big hit here on the forum. I’ve seen the threads on CPF of someone selling by the sheet and shipping to me killed it. It so happens that my local Dedeman has DC Fix in stock and I picked up a square meter for about 5$, that should suffice for now. I’ve cut it to dimensions and stuck it on the inside of the glass lens to keep a minimum of waterproofing. Below is a beamshot with one headlamp in its original state and one with dc fix applied. Much nicer light to work with in close proximity.
Old-Lumens wrote:
I love modding, but I don't have much use at all for flashlights in general.
ToyKeeper
ToyKeeper's picture
FWIW, I took some comparison shots of two ZL SC52 lights, one stock and the other with DC-Fix Sand on the lens. It’s hard to show the different well in photos due to lack of sufficient color depth, but with a few exposures it seems okay. Here are the results:
I also compared my “brass beauty” light with DC-Fix against a wide-beam SK68, to show why I prefer the brass light for biking. It’s much wider and smoother, and the center of the beam is still brighter than the edges so it does a better job providing even illumination out into the distance. Plus, the 1×18650 light can go much brighter and lasts longer per charge. I had to turn it down pretty far to make a fair comparison in the photo.
Bucket
Bucket's picture
I'm very interested in this, but can't see  the pictures Sad
I recently bought an expensive aspheric lens from Thorlabs that had been treated with 1500 grit to act as a diffuser.  It is really a nice beam, but does not throw as far as I had hoped with the diffuser treatment.  I just got a couple of cheaper aspherics from china and plan to try to lightly treat it with some 2000 grit to see how that does.
“If you don’t read the newspaper, you are uninformed; if you do read the newspaper, you are misinformed.”
—Mark Twain
wight
Bucket wrote:
I’m very interested in this, but can’t see  the pictures Sad
Just curious, but can you post a link(s) to beamshots which approximate what you are trying to do? I’m just not familiar with the whole diffused aspheric concept at all.
Still fine, still on a break. One day I’ll catch up with you folks! previous wight catchup Wink
list of my drivers & variants (A17DD, FET+1 stuff, WIP stuff, etc)
garrybunk
garrybunk's picture
Sorry, pics will be back on the 24th. Until then there is a link in the OP to the photo gallery.
-Garry
dchomak
Last seen: 3 years 3 months ago
-Garry
This happened to me too last week.
Bucket
Bucket's picture
[/quote] Just curious, but can you post a link(s) to beamshots which approximate what you are trying to do? I'm just not familiar with the whole diffused aspheric concept at all.[/quote]
I don't have any beam shots and the light is at work right now.  I'll try to remember to get some soon.
The concept is simple though.  Thor Labs just took 1500 grit sandpaper and roughened up the flat surface of the aspheric.  They went a little too far or rough for what I wanted, but it makes for a very nice beam profile.
—Mark Twain
garrybunk
garrybunk's picture
Hmm . . . Can I do that with a regular glass lens? Another technique to test? I'm going to have to order more lenses!
-Garry
Bucket
Bucket's picture
I believe so.  I'm going to try it out with one of the two aspherics that I just got in the mail.  I'll let you know how it goes.  I'm just going to use plain super fine grit sand paper on a granite surface
It may even be possible to do a hybrid lens using a fine grit and a small media blaster.  For instance you could treat the outer portion of the lens with the grit and leave the center clear.  That's the best way I've come up with to get rid of the square LED die image for aspheric lenses while retaining most of their throw.
—Mark Twain
NightSpy
NightSpy's picture
Last seen: 4 years 6 months ago
Etching Cream.
Serifus
If you want to keep the hot spot and just have wider spill leave a narrow ring clean right at the edge near the bezil, that is where the hotspot is created, and everything else will get diffused
garrybunk
garrybunk's picture
Interesting! I'll see if I can try that with DC Fix. I'm pretty sure I'm going to order new lenses though and that means I'll have snow on the ground by the time I'm ready for beamshots!
-Garry
lee-t
Last seen: 6 years 10 months ago
just joined up. hobby cyclist needs lights and cant pay top dollar so happy going diy!
since I also bought a pair of ebay china magicshine clone and then decided to look how to improve the beam pattern, I also sourced and fitted the wide angle lens to my 2 bar mount and a google of frosting lens found me here, at an active thread, not something 3-10 years old haha
greetings to all, Smile
Bucket
Bucket's picture
Welcome!
—Mark Twain
garrybunk
garrybunk's picture
Welcome to BLF!  Glad we could help!
-Garry
DavidEF
DavidEF's picture
Last seen: 2 weeks 6 days ago
Beware, there is a disease called “flashaholism” that is running rampant here. If you stick around, you will be infected by the disease. Then, you will not be able to stop buying more and more flashlights until you learn to build them yourself. Then you won’t be able to stop buying parts for flashlights! You have been warned! Welcome to BLF! :bigsmile:
- The YKK Philosophy
wight
I’m a little late to the party, but sometimes the symptoms to manifest differently: Once infected you may start purchasing parts before learning to build lights. You’ll still have an empty wallet, but in that case you don’t even get any fancy lights (until the disease progresses to stage 2).
WWW
Great experimente indeed, thanks for taking the time and sharing it with us.
