I have one too, very nice knife for the money, I also blunted the edges of the liners with a diamond file, cut the clip a small bit so it doesn’t protrude out and scratch or snag on things, and RIT dyed the brown scales in black color.
Steve and Alex:
Which part of the liners did you find sharp? I’m curious because I haven’t noticed that at mine.
Alex:
Could you post a pic about your shortened pocket clip pls? I’m also planning to mod mine.
Anyway have you seen the all black version with partially serrated blade (Knight)?
The inner edge of the liner, the side not touching the G-10 felt sharper than it should be, no cut fingers, just uncomfortable when playing. 600 wet/dry wrapped around a length of 10 mm dowel and run all round and all is good. This is one that I had to do nothing else to it, it was smooth opening and closing even without a cleaning and oiling, still is as well.
Harnds Black Mamba, I’d have bought one without the serrations.
I’ve bought from runonrock before, he has an on-line store as well as the ebay one, responds to emails rapidly.
The smooth action of my Viper was a pleasent surprise for me too.
Fasttech sells the black version as “CK6016 Knight” although there’s “Black Mamba” on the blade…
Here is my viper, the scales were RIT Dyed black (Used the powder RIT boiled for 1 hour after thorough cleaning to remove grease) the color seems permanent and has held up perfectly after months of use
Here is a closeup of the clip, I just cut about 5 - 7 mm and gave it the same round form with a dremel. It doesn’t protrude much now.
I also put locktite blue on the blade opening metal disk on the top (What’s it called?) so it doesn’t unscrew itself with use.
FastTech are just not very good when describing knives but to get the wrong name is beyond typo’s.
The prices are good though.
That would be the thumb-disc I think.
That looks great, almost makes me want to try it but I have too many black scaled knives and the brown is a nice change. Very nicely done.
Good job.
I’m planning to drill several holes into the liners to save some weight and I’d like to replace the pocket clip with a smaller one.
Bob Lum Large Chinese Folder. I love bobs blades.
And while I have it out, I wanted to show you my pink variant.
The blade is numbered #2. I can't believe I got hold of this.
Me too!
NIce!
That's a BEAUT! Cocobolo / Rosewood ?
What model number is it?
It’s a BM 230-1 Paul Axial. Discontinued.
Cocobolo grips with beautiful checkering.
Blade length is 3.9”
First one I’ve seen…
does anyone know anything about this emerson Hatin
This “Hatin” prototype was introduced at the 2013 Blade Show. Knife features bead blast titanium bolsters and satin finish blade. Blade is V-ground and notched along spine and thumb rest. Wave feature and disc opener. Green canvas micarta scales. Includes original Emerson velvet bag as well as a zippered pouch. Perfect lockup, detent, and seating. Knife is new from maker.
SKU: 139033
Product Specs
Blade Length 4”
Overall Length 9.5”
Classification Custom Knife
Source From Maker
Weight 6.8 oz
Additional Specs
Liners Titanium
Closed 5.75
Thumb Studs Disc Opener and Wave Feature
Bolsters Titanium
Clip Tip Up Carry
Spacer Black G-10
Case Original Emerson Pouch
Knife Type Folding Knife , Liner Lock , Tip Up Clip
Blade Materials Stainless
Blade Details Spear Point , Upswept / Trailing
Handle Materials Titanium and Green Micarta
Kershaw Spec Bump
