I wonder if you could swap an SSX2 driver into this light and then get L-M-H modes with both LED's lit at the same time. The drivers seem to be the same exact shape. Or do you think the modes as is are better (being able to have flood only, throw only, or both)?
I didn't think of it. Good idea Garry. Will take a look if the dimensions fits. About using, both can be convinient. It depends on cycling style and personal preferences.
When you do MTB during ascending all you need on the bars is wide beam and you can see further away with narrow beam from your helmet light. When descending you have much more speed and you would like to have all the lights on full. Long beam only can be suitable for horizontal mid speed.
When commuting you mostly run at even speed. You can have both lights on all the time and only adjust brigtnes according to surrounding. High on rural and low/mid in urban where you already have some street lights. In case of commuting one light on the bar with two beams will cover the whole vision. Light on the helmet is not necessary.
I'm not telling those preferences are suitable for everybody, it's just my opinion.
EDIT: Measured the size of SSX2 driver back plate and it is same size like HD-016. So I think they can be interchanged w/o problems. Good to know if anyone would prefer different type of operating
Thanks ledoman! That's awesome, though now I'd have to buy a cheap SSX2 just for the driver. I do like the ability to run the HD016 on 4.2v though (per Lagman).
The last cheap SSX2 one I've got hands on few days ago had leds in paralell. The light was powered by usual 2S2P packet. So be aware what you might get.
Interesting light really. I don’t like the 18650 format too much though. I would prefer AA powered lights. One thing, for trailing, I think a neutral light is better.
Garry, no. I've said it is powered by 2S2P (ie. 8.4V) pack, but normaly in SS2X leds are connected in series The last one was not.
Selle was bonlighting2014 at ebay. Must say it si not good. I pulls only 0.9A from battery pack A had to add R500 sense resistor to improve output a bit.
Well, you can build your own AA 6S battery pack. I'm working a lot with Li-Ion 18650 and they are very good regarding energy density. They are also safe enough if you treat them right. AA is of course even safer.
As posted over at MTBR, I just ordered the "SecurityIng" version of this light from Amazon ($32.99). Then the next thing I knew my finger slipped and I also ordered an SSX2 (due to ledoman confirming that the SSX2 driver will mount in this HD-016). This would give both LED's on (wide & narrow) at the same time with Low-Med-High modes and a hidden strobe. Lagman's review confirmed that the original driver also runs on 4.2v input, which really appeals to me (to use unprotected cells in parallel), so I am torn between keeping the original driver or swapping the SSX2's driver. (I really just bought the X2 for the driver.) I will post back with my findings.
I really think this HD-016 will be the perfect light for me! I can finally stop accumulating all these lights! (Yeah right! ).
You might be able to run the X2 driver on 1S cells if you wire the LED's 2P.
I tried to run my X2 with 1S cells while is still had the stock 2S LED wiring. I didn't expect it run, but was curious if it might possibly had a booster circuit in it. It didn't run. It would flash once every time I hit the momentary switch though.
Just received my HD-016 "SecurityIng" version from Amazon. Battery had enough juice to run through the modes one time before it died. Will test it out later. First impressions is that it looks good!
(That's my SSX2 package on the left.)
The box is just a generic bike light box. It says "XM-L" and "Natural White" which are both lies. It came with cool white XM-L2's.
BTW - I also received my SolarStorm X2 from Amazon. It did come branded as an X2 and not blank (I know that doesn't mean much, but I like to see it branded). First impressions on it - doesn't seem very bright on high. More testing and teardown on that one to come too, though I won't post it in this thread. In fact, I will just post further details on both lights in "My Bike Lights Thread" linked for your convenience in my signature :) . No promises though on when I'll get to tear downs.
I have three different versions of the SolarStorm X2 from three sellers of eBay. One has 720 mA tailcap reading on high, one has 860 mA and one has 2190 mA (obviously the brightest). They all have SolarStorm X2 marks but when I opened them, they have different drivers (though the 860 mA and the 2190 mA are somewhat similar).
I added 2x R100 resistors to the sense resistors of the 720 mA and changed its lead wires to AWG 22 and it now does 1567 mA. Added an R100 resistor to the sense resistors of the 860 mA and it now does 2883 mA.
BTW, after reading your thread on diffusing bike lights, all my three X2s now have DCFix on their left lenses.
Don't want to go too far off topic of the HD-016, but I did measure battery pack current to the X2 (@8.24v) - 0.855A on high :( . I haven't opened it up yet though.
I just received my SecurtyIng version from Amazon.
I haven't torn it apart yet, but I've taken current readings and got some beamshots.
Current pulled from 2-cell battery pack at 8.24v:
Off: 0.020A
Flood: 0.663A
Throw: 0.665A
Flood & Throw: 1.410A (Steady, not dropping)
(BTW - I am confident current readings I make are accurate.)
Flood is VERY wide! However the "flood" mode doesn't throw out far at all. I can't imagine "flood" alone being enough to ride with (except commuting where it is used more for "be seen" use. I think I would prefer the reflector be just a tad deeper in order to get a little more throw out of it.
Here are some beamshots. Pics taken with my same manual camera settings at roughly the same location so that my beamshots can be compared one to another. In the first set of pics, the distance to the trees I aimed between is approx. 185 feet (garage is beyond the trees at an undetermined distance - I really need to determine that). Approx. 275 feet to the house off to the left of the trees. (Note: you can barely see the trees or garage in the "throw" pic.)
Next is a full teardown and mod to XM-L2 T5 5B1's and a resistor modded SSX2 driver to run Flood & Throw LEDs at all times in a High-Med-Low (or Low-Med-High) arrangement.
Wow. Thanks for the teardown and time to take those really awesome pics garry. Just want to make me grab my bike and go out here! I think a neutral tint would have been just gorgeous
