Or 7135*8. You know you want it!
0.46€ 90% OFF|Taschenlampe taille clip, edelstahl clip, für neue C8,M2,S3|s3...
Smarter Shopping, Better Living! Aliexpress.com
yes ,but the first batch S2+ can not
ok ,note
i can make it ,but i think big current will damage the battery
Sorry, which question are you answering here?
please include pocket clip
nice one ,will you sell hosts ?
the #5
here is the link of clip
yes ,will
7135*8 will not damage a high quality imr18350 or imr16340.
What is the prurpose of the CR123 version, since the body is not thiner ?
If you can make a host with a short body that takes an 18350 I'm in. Since I started vaping I've collected some good IMR 18350 cells that could drive a nice triple LED hot rod shorty. 16340's just don't cut it any longer.
It probably incorporates a boost driver instead of the 7135 linear driver due to the lower voltage of the CR123.
~~X3~~:What is the prurpose of the CR123 version, since the body is not thiner ?
Yeah I imagine so, but if I chose a CR123/16340 battery format it’s not for the capacity…but for the smaller diameter
Simon, could you tell us what driver do you use in CR123 version, please?
More than likely using a buck driver (same ones that use the 1AA/2AA, which means people that can get CR123’s on the cheap have ready made battery supply on hand
Oh and thanks for the AWESOME customer service Simon!
7135*3 single mode driver
Those work w/ a 3vdc CR123?
WarHawk...I'm guessing you meant to say boost driver, not buck driver.
A 7135 will work with a single CR123, but it is very weak.
