They seem to be rated very good here.
Just buy 2 good AW or Redilast cells instead of buying a bunch of ultracrap that might blow up. Heck I even use unprotected Sanyo 2400 cells I got from laptops.
Why bother with hit or miss, how many cells do you really need?
Well that's my opinion anyway.
Thank you "undercover" poster. ;) lol
Well buy what you want. I like these for the money. And I plan on buying some more.
I'd definitely avoid the fake crap on eBay, but the "good" 18650's like AW and Callie's are amazingly expensive compared to decent cells (not some of the garbage ones) on DX, etc. Will your lights really know the difference? Most of the testing I've seen says No.
The Xtars we had here weren't all that much. They're good.
One battery that hasn't been mentioned is the Hi-Max at about $6ea. My tests show they come in at about 2500+ mah. This is the cheapest battery I would recommend to a friend.
I have opened up a lot of fake / recycled batteries. One of the sellers had a 99.5% feedback so you cant gauge battery quality by feedback ratings. Most battery buyers are not on message boards and dont actually test their batteries.
If you buy the cheapest 18650 batteries your almost guaranteed garbage. Even the "real" Fire batteries seem to suffer from high internal resistance and much shorter than average lifespans, 1-2 years? (vs name brand batteries sanyo samsung ect)
Ultrafire Grey vs. TF black (mouse over)
black line: 0.3A discharge, red: 1A, green: 3A
Well I had a red ultrafire junker battery do better than the Trustfire flame battery. Now I don't recommend those batteries, but I'm still using them. Those Ultrafire grey batteries in my opinion are a lot better battery than you guys are reporting in my opinion. These I got are dang good batteries so far. For the money they are very good batteries.
If you are like me, having only a couple of 18650 in circulation, get for example Xtars.
I have tf flames, got Xtars now. They perform well and have good capacity/quality yet quite low price
And I agree with you. The Xtars are good batteries. But I can buy 8 of the grey Ultrafire protected batteries for about the price of 2Xtars. Now to me the Ultrafires are the better deal. They may not be as good either. But when I go through a set of them and even if they won't last as long I still have 3 more sets to use. I don't think 2 Xtars are going to out last 8 Ultrafire grey protected batteries. But like I said use what you like and pay what you want. I'll take these batteries and do just fine.
That's the rub right there : The cheaper cells may test out well to begin with , but 2 years down the track may have seriously degraded ..
If you buy new cells every year to maintain mAh ...
Then buying batteries that cost twice as much , maintain good capacity for 3 years , is not so economically irrational after all .
I'm not disagreeing with you at all. But again if I can buy 4 sets of the Ultrafire grey protected 2400MAH batteries for about the same exact cost of the Xtar 2600MAH batteries I believe the 8 Ultrafires will out last 2 of the Xtars. I just ordered 6 more of the Ultrafires. So far I like these batteries. I don't need the Rolls Royce of batteries to keep my lights a working.
You'll also need to deal with variations between the batches from various sellers (they themselves would not know, so some blame DX but that is simply untrue).
Just tested my stuff out to give a larger sample (in addition to what mitro or old4570 has done). TF Flames will come soon.
Actually if want to test with flashlights, one needs to note the runtimes with a regulated light that cuts off. Like what i did with the Sky Ray 3800. Eg I got Panasonic 2900 60-61 mins, XTAR 2600 53-54 min, Solarforce 50 min, TF Flames 43-44 mins. The lousier cells like PAlight/Ultrafires lose so much power/capacity due to heating up that they did not go for more than 5- 10 mins.
Disclaimer, i gunned the SR3800 till the point of failure with such runtimes. So don't try this yourself.
Ultrafires :
Been testing some of my older batteries , and about to test some more ..
So be interesting ...
The crap grey ultrafire are like $8/pair, the xtars about twice that or less. The ultrafires are crap to start with, and what's even worse is that they're not consistently crap so it's probably not very safe to use in multi-cell lights. Frankly half-way decent unprotected cell are better.
Ok, here's the TF Flames, 2208mAh down to 2.6V @ 1A constant draw. Same as what old4570 got i believe. I got the later batch as his....so not too bad. From dealextreme.
Of course those Ultrafire cells are usable for some apps, like XR-E lights or even XP-G. The 783mAh one can still be used for stuff like laser pointers etc. I use them for my greenie, they only draw 0.7A. And that means i can switch on the laser for about 1hr and 1.3hrs respectively (!!). And seriously you don't use them for 1hr at a time, so no worries.
What the...it's only $4.80 for 5pcs of the Ultrafire 2400mAh shipped!! Re-claimed cells sure are cheap like nothing (cost is gonna be much lower).
I'd advise getting the TF-Flames, and from DX only. At least we know that's a good source. Other sources, it's like lottery. The "best" thing that can happen to anyone, is getting getting a 2208mAh cell, and another at 1356mAh, the user has no measurement equipment, and then you use this in a triple XM-L with no LV protection...like the TF-3T6. heh....
Wrong. Again, I can buy about 8 of them for about the same price as 2 Xtars and I got money that 8 of them will in fact out last 2 Xtar 2600MAH batteries.
I can buy 2 of these for $4.38 factory sealed and delivered to my door. These again are good batteries regardless of what you Xtar promoters are saying. I will run them in more of my lights and compare them to the Trustfire flames. But I doubt I will see any big difference than what I have seen so far. Again, for the money they are the better deal.
So you're buy something that has a catastrophic failure mode at half the price that DX sells them for. And let's be fair here, it's not really half the price since it costly around $2 to ship them to you, so more like 1/3 the price. Good luck.
