I don't think it matters much which blue you choose, there's some nice info on colour mixing in this Philips video (btw clearly promoting their lime led):
Another philips video I found even more interesting is how to combine a cool white led with a lime led and a red led to mix white light with a whole range of colour temperatures and high CRI:
If you build that into a flashlight and design the correct (very fancy) firmware for it, you can adjust the light to all colour temperatures white light in high CRI.
BTW, fish tank lovers are way ahead of us in colour mixing. One example, just follow this discussion :
It may not be a good source for you (EU-based) but I recently bought some colour leds here, and guess what: they aim at aquarium lovers:
Hmmm, anyone thought of a triple with three little thumbwheel/rheostat “volume” controls, one for each emitter?
Align the wheels along the length of the light, up against the head … heck, there are even ‘clickable’ wheels that have a clicky switch, like a middle-button for clicking/scrolling on a computer mouse.
There’s probably a touchscreen equivalent by now, or a way to do all the adjustments with a “joystick” button ….
I like it too, and I'm really pleased that CK is developing so many new things with colour leds. With the time, space and means that I have for this hobby there's no way I could even start doing the things that he does.
Mine are drawing 1.6 amps. in PC Amber, and about 1 amp. each in Lime and Deep Red. I don’t think that is pushing them hard. They are not on direct stars, as I don’t know where to get ones that fit. One has a flattened old penny behind the star, because it has a hollow pill. Did you find Sinkpads that fit or are you modifying them?
I have a lime Rebel and a Sinkpad for it, is there any interest in an output test?
BTW Fritz, in case you are interested, vestureofblood has recently obtained a batch of Rebel Sinkpads, I'm sure he has some left. And if he is out of them, I'd be happy to send you one or two of mine.
Luxeonstar has triple Rebel 20mm sinkpad’s for the carlco optic’s.
Thanks DJozz. To bad this quit being my hobby about 6 months ago… The full spectrum HCRI tint mixing sounds pretty cool, to bad I just spent hundreds of bucks developing a WW/CW highly advanced tint mixing FW & driver for a light I’m building based off the nitecore Cx6 series (because of their really good optic setup for mixing 2 emitters)
and they have optics to fit the spacing on those triples.
I’d guess the Sinkpad and Sinkpad 2 emitter positions are the same, but I don’t know for sure.
I know there are other spacings out there — the “Endor Star” triple Rebel from LEDSupply is different (LEDSupply sells the usual variety of optics to fit that, of course.
And there’s the whatever-the-heck in the DQG Tiny 26650 — different spacing yet again, and no idea who makes the different optic to fit that much bigger diameter.
The optic’s that fit the sP2 mounted triple rebels are the exact same carlco 105xx series as used with the XP Noctigon’s! Easy to get in about any beam you want and about about $2.25 a piece (tighter is always better for color/tint mixing, l’ll probably try the 10507 scuffed up or the 10511). The rebel emitters are positioned correctly so their domes are in the same position as cree xp domes in a Noctigon.
I may have a go at it some time then. A brute way to drive it is with individual ramping of the three (or four) channels, with memory. Without going through your many great driver posts again (my memory is like a sieve), wasn't that something you already had build by any chance??
I think that your way with two different white emitters is easier and works just as well. The three-led set-up that Philips suggests is probably a bit more efficient because less phosfor conversion is taking place and in the 'real world' that is pretty important, for a flashlight that is hardly interesting.
The link goes to the deep red XP-E, not to the an amber led. And still, however attractive, up to date and of latest bins your selection of leds is, 33 dollar shipping kills any small order attempt from outside Australia :-(
Is there a source somewhere for the PC Rebel on something small and round, like a 12, 14, or 16mm base?
(I know I can get them on a 10mm square (Luxeonstar) or 20mm star (LEDTech))
Or, what empty base do they fit on and where might I find it? I can warm up the heat gun
I have not seen anything other than 20mm and a 10x10mm square board for the Rebel. A 16mm base can probably be made by filing/sanding down a 20mm one.
Actually I have quite a stash of 20mm Rebel Sinkpads and I'm not at all going to use them all. If you are interested I can sell you some for what I paid for them (if I remember well 0.70 cents/piece) plus shipping (2.20 dollar to the US).
