they raised their price ? ( i see $7.27 on the OP page links.)
You have to apply the coupon GBSF348
oddly it took a few tries, but the code finally worked.
Just received my two lights today - about 15 day ship time. Not bad! However, one of the lights came in slightly cross threaded. I had to wiggle the tail cap some to get the end off to install the battery. Its like when it was installed at the factory the cap wasn’t put on straight and the tips of the threads were taken off. HOWEVER, the other light is perfect, awesomely bright on an Efest 10440. CSGearBest can you help me out with this? Can’t give it as a gift in this condition…
Hi roll_tide, I’m really sorry about that, could you please PM me with your order number and the pictures about this problem, so I can check it for you.
1 neutral white.
I ordered one.
Too bad it doesn’t have some sort of shape to it. But their dimension is 1.2 cm., the only light I have seen thinner (though longer) than the Maglight Solitaire. Looks like they used the advantage of the steel’s strength.
bummer, protected led lenser 10440 does not fit on it
Will buy!
How do you know the Led Lenser 10440’s are protected?
!http://tapatalk.imageshack.com/v2/14/11/06/423e00b1d08cc42e338cbe8229ea61d2.jpg!
!http://tapatalk.imageshack.com/v2/14/11/06/975d67c876f7389d5ae6271c08efbbc1.jpg!
im not sure if you can see it bit there is a strip
like bulge in it’s side.
hmm, are you thinking protected 10440 never existed
edit: posting pic in opera mini is really a chore. anyone care to help?
Sure. Here we go..
Wow.
Protected 10440’s you don’t see everyday. I guess Led Lenser’s are torches for non flashaholics though.
Any ‘reviews’ on this flashlight?
I just ordered 8. Xmas gifts are going to be bright this year.
Agree, just got my second order of 7 lights in for just that purpose.
Review-
Works well, nice looking body. Stick a cell in the end, screw tail on, press button and you have light, its single mode only with about 35Lm on NiMH.
Sorry, couldnt resist. Not trying to be a dick or anything just joking around a little. There just isnt a lot to review for a $5 flashlight, it works well and based off the number’s sold in the GB its well liked. Also a reasonable mod host if you want to do a tiny 10440 build (better than the original S1 in that regard- solid pill and screw on bezel). My ONLY complaint is the reverse clicky, a single mode light like this should have a forward clicky.
That ‘review’ was perfect. Not many budget reviews going on BLF nowadays. Losing its soul
I got 3 more CW. Unfortunately, 2/3 have logos… :_(
I don’t want to gift the ones with logos so I will probably be giving them away here on BLF.
Looks like FastTech is selling a very similar light but with higher output and Romisen brand: https://www.fasttech.com/products/1601/10000622/1946201-romisen-rc-3007-1-cree-xp-g-r5-148lm-1-mode-pure
All visible parts look identical with the exception of the metal cap on the button, which looks slightly longer than the SingFire. The brass-colored insert is deeper in the tailcap, which would give a bit more room for making a hole to mount a ring, as Romisen did with the 3008 UV
