I don’t think a whole separate list for the Chinese cells, just a separate entry for them in the existing list and table. Or do you think it really would be too confusing? The added E or A might be codes for the factory they are made in. That should be enough to differentiate them in the list, I’d think.
the A is used in Asia, but also in the US.. and the China made ones use it, as well as the Japan made one
Ah, I see! 8)
BQ-CC11 | BQ-CC21 | BG-CC22 | BQ-CC23 | BQ-CC24 | BQ-CC25 | |
Battery fitment | 4 cells | 4 cells | 4 cells | 2 cells | 2 cells | 4+2*1 |
AAA | 1-4 | 1-4 | 1-4 | 1-2 | 1-2 | 1-4 |
C | - | - | - | - | - | 1-4 |
D | - | - | - | - | - | 1-4 |
9V*1 | - | - | - | - | - | 1-2 |
Smart charge | Smart | Smart | Smart | Smart | -(timer) | - |
Charge time | ||||||
Fast charge*2 1-2 AA | 2 hours | 2 hours | 4 hours | 4 hours | *3 | 6 hours |
normal charge | 4 hours | 4 hours | 8 hours | 8 hours | 7 hours | 6 hours |
Zero Power consumption *4 | yes | - | - | - | - | - |
Voltage | 100-240 | 100-240 | 100-240 | 100-240 | 100-240 | 100-240 |
*1 BQ-C25 is a multi battery charger, and can charge 9V batteries, 2 in total.
*2 Fast charging can only be done with 2 cells. and not with 4 at the same time.
*3 the BQ-CC24 is a timer based charger especially for eneloop Lite, therefore its not recommended to use with standard eneloops.
*4 zero power consumption is that the charger will use less than 0.005 watt when not in use, according to IEC62301 it qualifies for Zero Power Consumption.
Hi do Eneloop do a
D cell rechargeable yet?
Yes, already since 2007.
They are supposedly just 3AA std eneloop batteries in a D wrapper.
I see can I just use 3 eneloops in an appropriate adapter?
For good D cells look at:
Tenergy Centura
Powerex Imedion
And yes, eneloops in a adapter will work as well.
I have found an adapter that takes 2 AA but not 3 can anyone pass on a link for a uk or other supplier? Please thanks for the replys…
Thanks for the links Kloppholz,can anyone tell me where i can get some AA Eneloops in the UK?
ChibiM’s Eneloop Sales, Amazon (I ordered from iCell few times, shipped from Switzerland.), 7dayshop or eu.nkon.nl
The top of my 4th generation Eneloops do not look like the 1st generation. The top is not bright white. Everything else about the fourth generation is correct in appearance and text. Do I have some fakes?
Thanks.
Where did you buy them from?They look the same as mine which I got from I cell media.on the side BK-3MCCE no/ came in a blister pack with battery case and 4 AA batteries
A business in New York city.
On side of battery printed: 3MCCA
14.01 RF
In the second post there are instructions for looking for fakes which I find too complex for me anyone??
My 4th generation made in Japan cells from Costco are also a little off white when compared to 1st gen eneloops. The capacity checks out fine on mine.
Just judging from that pic, I can say that they are NOT fake. But again, just assuming everything else is the same... the colors around the button are always a little different.. don't worry about that!!!
If you looks at post #1, you can see that one is almost grey.. and the special editions have again different colors.
Thanks ChibiM and everyone else.
Does Amazon relabel eneloops?
Made in Japan
Modellnummer: HR-3UTG-AMZN (8P)
70% after 3 years remaining.
Similiar look, capacity and discharge values…
Only big difference they are rated for 1000 cycles…
