For the moonlight special driver, which AMC7135 should I not stack extra ones on?
I'm trying to dig up a picture (here at school)but can't fine one, but the positions on that side are the same as a standard 7135:
I am going to have to apologize to those of you who have received replies to your messages 3+ days after you sent them. On the weekends especially I try to focus on building as many lights and drivers as I can, so I don't stop and look at my messages often. This morning I opened up my e-mail and my unread messages + PMs was well over 30 , so I am digging through them little by little. Has anyone figured out how I can make a clone of myself yet?
[quote=RMM]
Anniversary Sale. Starting later this week, we are going to have our “First Anniversary Sale”. All of the details are still TBA, but there will be some great deals on lots of great products. You will hear about it here and through the newsletter as soon as things are ready to go.
<span style=“text-decoration: underline;”
This sale will most likely be like a new .99 cent store opening where they give away things like free t.v.s to those first in line, etc. Is everyone foaming at the mouth already? Quality merchandise at discounted prices = feeding frenzy!
On your marks…… get set……
Richard, $4.90 for a IMR is pretty tempting. As HKJ has not reviewed the cell yet, what does it do in a single XM-L2 light with a DD driver?
It was pretty good, but I'll do a comparison with it direct drive in the same light vs an NCR18650B, 20R, and 25R and let you know. I don't expect anywhere near a 20R since it only has a 7A maximum continuous discharge, but we'll see. The capacity is good, I know that. I have been playing with one for about a week now trying it out before listing it because I wanted to make sure that at least the capacity claim was real.
OK, so I did a quick and dirty test of the ENOVA 2600mAh cell.
Last weekend, the cell averaged about 2660mAh reported on the Opus at 0.5A discharge. I'm not sure how accurate it is, except it seems to be in the ballpark on the cells I've tested.
I tested it direct drive to an XM-L (not XM-L2) I had on my large heat sink. The XM-L usually reads a bit higher direct drive compared to XM-L2s. 4.2v starting voltage for all cells. 4" 24 AWG leads + meter leads.
Sanyo FJ 2200mAh: 4.7A
Enova 2600mAh: 5.7A
Samsung 25R 2500mAh: 6.4A
Average of 3 internal resistance readings on Opus (do not compare with readings from other sources:
Sanyo FJ: 128 mOhm
Enova 2600: 85 mOhm
Sam. 25R: 45 mOhm
It isn't a 25R replacement, but it is a decent enough performer for the price.
Decent enough that, assuming the supply lasts, I might want to start replacing my Sanyo USGR’s with them. Thanks for sussing out this option, Richard.
Richard;
Have you done any night hunting/special purpose lights with the most powerful red LEDs available yet? Thinking that a SRK or M6 with your 7 level firmware and the red LEDs would make an interesting light for those who want both night sight preserving low red light output and high output red for hunting or night animal observation seeing as how most wild animals are blind to red light.
Nothing I know of on the market that quite fills that bill other than a DIY light possibly. Closest might be the Nitecore Chameleon CR6 but it’s red output is weak compared to what I expect could be done.
I actually have done a few of them for friends and family, but I'm afraid that I just don't have time to reach out to any new markets right now. I am maxxed out as it is.
Richwouldnt, you might be able to at least stick your foot in the water. It’s not terribly difficult to put a red LED into an existing host, as long as you make sure to keep the current at appropriate levels. The XP-E2 won’t deal with the same amount of power we give to XM-L2s.
The brightest one I’ve made goes up to about 170 lumens of pure red (driven very conservatively), with 1x16340 as the power source:
This is a rather small light, nowhere near the output you seem to have in mind, but on the highest mode it kind of makes my eyes want to bug out. It’s just soooo red!
I’m only doing 700mA on mine in order to make it more efficient, but you can probably safely get 300lm per emitter at ~2A each. And since it’s so small, it should have pretty good throw. You might want to use LiFePO4 3V batteries instead of the common Li-Ion cells we use though, to keep the voltage down closer to what the red XP-E2 wants and reduce unnecessary heat.
Or of course there’s the CR6. Much easier than building one.
Actually I have another member who has volunteered to do a build if I order the LEDs and the SRK 7135 board and have Richard send the parts direct to him. I figure I will send him my level 1 modded M6 that RMM did as it has the wanted firmware already in it. He seems to think it will be a fun project and volunteered to do it via a PM.
Thanks for the fast delivery of the BLF 20DD driver Richard, but could you make the leads longer? They don't reach the the LED on the Defiant 3D/3C lights, I'll have to splice extensions onto them.
I was wondering, could you program the moonlight special driver to drive the single 7135 at 100% and just have two modes. 380mA and 3.04A? I think that would be cool for an Ultrafire 602. You could have a fairly bright little light running efficiently at 380mA most of the time but be able to light up a quarter acre for short bursts. It would be great i fit could also have Qlite's beacon mode, 2 flashes at 4 second intervals. I'd buy a few of those!
I’m curious if anyone has suggestions for a small, cheap Li-Ion charger which reliably charges pretty close to 4.20V.
I have a Nitecore i4 which terminates at 4.22V, and three Xtar MC1 chargers which terminate at 4.24/4.25V, 4.12/4.13V, and 4.15/4.16V respectively. Mostly, I’m looking for something to include with gifts.
I’ll probably use the ~4.12V charger myself, since I don’t mind the lower voltage and potentially getting more cycles per battery, but the 4.25V one seems like it might significantly reduce cell life due to overcharging.
Anniversary sale on Friday I guess.
Also, what about that ‘special’ project in the works? I’m not forgetting.
any ETA on the M6s?
thanks
I’m throwing some chips down on the Miller ML-102 v7. I have not used any Miller chargers yet. For a long time I was put off because the Miller chargers look so generic and seemed like a prime target for clones even if they were any good. At this point it’s pretty clear that Miller mostly has his/her crap together and that FT has the real ones, so I’m picking up 3. Note that protected cells don’t fit and you’ll need spacers for smaller cells. Stock charge rate with the latest ones is 1.25A so it won’t be appropriate for many tiny cells.
FWIW I looked inside the cheap SupFire charger and with my limited knowledge I do not think that it will be satisfactory.
EDIT: I forgot to post links to all the data will34 posted:
http://www.fasttech.com/forums/1137904/t/1415318/ordered-16-9-version-7-1
and here just in case, spread out over the thread starting with post #158 - Review: ML-102 Charger
The sale was going to start next Monday, but it might be delayed because we are still waiting on some shipments (including M6s) that were supposed to be here already but are still stuck in customs. You will receive a newsletter notice when we have everything pinned down.
I usually get complaints that I make them too long. The Defiant is a longer reach than most lights, so if you need extra long leads please let me know in the checkout comments.
Yes, but I'm afraid that the single 7135 might get overheated running at 100% with a good cell behind it. I do run the single 7135 for the moonlight and 2%/5% modes, but not for the higher modes. I can put in a beacon mode.
I guess we’d be looking at something like 1/2W for a single 7135 in that situation (100%)?
EDIT:
- vs more like 1/4W [each] in normal use with an 8*7135 driver operating at 100% on a strong cell to run an XM-L2… I think.
- I think driving red emitters at 2A to 2.5A the 7135s should be getting closer to 1/3W each, but that’s still not 1/2W.
I still rely on my XTAR WP2 charger. 4.20V dead on every time. I also have the MC0 for small cells and it too is dead on. My choice for gifting a good flashlight kit would include the WP2 and a set of the 3400mah 18650 from Mtn Electronics. Maybe not the cheapest package, but if you’re going to give something, give the best you can.
