you should of brought the TrustFire TR-3T6
CNqualitygoods has the TF. usd45. If you combine your orders together it can be much cheaper than MF, and coz it's via DHL you'll get it within 2-3 days. (I usually get my stuff within 2 days, and i got them twice in 1 day).
FryRays. I'll be nucking-futs to ever buy another. I have (had) two.
thats quick shipping but the shipping to australia is about the same $$$ as the torch and i normaly only order 1 at a time, ive used manafont about 10 times now, im happy with there customer service, they are in the same time zone as me so i can use the live help if i need questions answered and the respond quick to emails and the batteries i get from there are gen,s
i have read all the threads i could find on the fry rays lucky as i almost brought me and my old man one each, but i whent for the TrustFire TR-3T6 lucky and the reports comming through on some of the new sky rays tripples are not much better i made a post here so if any one has read the sky ray threads and then read this thread it should be clear witch is better, well i think so.
https://budgetlightforum.com/t/-/3304
Nah... you go ahead. Since mine smoked I used that so I don't need it now.
Correct if I'm wrong, but isn't that TrustFire TR-3T6 advertised at CNQ just the 2-cell version?
I'm looking at the 3-cell TR-3T6, to purchase anywhere but "M".
i would go for the 3 cell version its rated at 0.5 amp more and its more versitile imo, the only place ive seen the 3 cell here
benckie, that's the only place I've seen them as well, but I won't buy any more product from "M".
I've dabbled a bit on flea-bay, but haven't found what I'm looking for yet.
fair call but flea bay has to be the last resort, i never have any luck on ebay with torch stuff unless its clear 18650 battery box,s
I have that light purchased from the same place you mentioned (Manafont). On the lux meter, on 3-cell operation as well as 2-cell operation, the light output is exactly the same. For regulated lights, it's much better to rely on the lux meter.
It's the same thing except w/ an extra metal tube extension.
Also, I'm not sure why we're blaming Sky Ray (or MF) here. They just rebrand the same stuff that Fandyfire does. That means next light from them could be good, or crap.
I have the original version of the skyray. My son loves that light and beats it like rented mule. Can’t tell you how many times it has shut down from getting too hot. It comes back every time after a few minutes. I am actually very impressed with it’s durability. I’m sure there are a lot more out there still kicking like mine, just don’t hear about them.
Luckily i didn't order the skyray, now let's hope the dry doesn't let me down! (ordered 1,5w ago, so probably wil have to wait another week or 2)
im not sure it they are the same thing, the manufacturer claims the 2 cell version is regulated at 2.5 amps and the 3 cell version of the light is regulated at 3 amps
but i gues there is many factor,s in this, the torch its self, the user, the cells used and how its measured and if the ddm leads have been moded to give false higher readings, the lux meter would be the proof as already stated.
but i stand by my comment that the 3 cell is more versitile and it will provide longer run time between charging but the extra two extention tube,s will cost you and extra 30 cents so since its only 30 cents more and it gives you the option of 2 or 3 cell use and a claimed 0.5 amp more regulation i would go for the 3 cell version even if there is no diffrence to the regulation, its 30 cents..
ive been very happy with manafont service over the firt 10 orders
I think if there's one thing we've learned here on this forum, it's that manufacturer specs are largely arbitrary. Here it really makes no sense at all to make two different versions.
i concur but people spend the extra 30 cents
You talking about the SR and TF triples? Definitely they are different, i mean different drivers (if that's what the majority of the concerns are) as someone has taken the guys. Also different drive levels. Eg, SR3800 is 160 lux reflected bounce, TF-3T6 is 130 lux reflected bounce. The trustfire also has a wee bit tighter spot, just a wee wee bit....when i A-B them on a white wall a couple of metres away. Not sure how that translates to throw lux though....never bothered to measure. heh...
Definitely buy the 3-cell trustfire! Then you can use the extension for Direct Driving the SR3800 when the driver Poofs! Hehe... :D (yes, for other's general info, the Trustfire tubes fits the Sky Ray, no issue and that's what i am doing now)
I'm a bit addicted to triple XM-Ls. Luckily the Jetbeam RRT-3 XM-L is like 400 bucks.
I mean the "2cell" and "3cell" Trustfires. For some reason they have different current spec even though we figure it's the same thing but with an extra extension for the latter.
@agent hex, I don't know about we, but I'm blaming skyray for two failed lights, and blaming Manafont for subpar customer service.
Pretty much it, in a nutshell.
The voltage spec is different as well. the 3 cell version is rated at 8.4 to 12.6 volts vs 7.2 to 8.4 volts for the 2 cell version.
