Olight Factory Dedomed Light?
111 posts / 0 new
CalvinIS
CalvinIS's picture
Last seen: 2 years 2 weeks ago
USA based seller of flashlights, batteries, and chargers.
Illumn Webstore
 /// Instagram /// BLF DEAL THREAD
Edited by: CalvinIS on 11/07/2014 - 00:20
BIGBLOCKMOPAR
BIGBLOCKMOPAR's picture
Last seen: 10 months 3 weeks ago
Very interesting, it does look like a factory dedome!
sinner
sinner's picture
Last seen: 1 day 14 hours ago
someones reading blf for their market research.
contact(at)sinnercustoms.com
Ruke
Last seen: 6 years 11 months ago
hmmm, looks kind of familiar
Cereal_killer
Cereal_killer's picture
Nice. I wonder what process they use.
wolfdog1226
wolfdog1226's picture
Last seen: 2 years 7 months ago
Very interesting! Some competition for the modders!!!
Solitude breeds contemplation which creates clarity.
Environment molds a person. Perseverance changes them.
        WOLFDOG
Bort
Bort's picture
Last seen: 9 hours 26 min ago
Agreed, if they are coming from Cree dedomed i would be very interested in someone comparing it to a gasoline dedome, to see if the solvent is reducing output or damaging the LED phosphor somehow.
The Journal of Alternative Facts TM
"It is critical that there is a credible academic source for the growing and important discipline of alternative facts. This field of study will just keep winning, and we knew that all the best people would want to be on board. There is a real risk in the world today that people might be getting their information about science from actual scientists"
DBSAR
DBSAR's picture
Last seen: 3 hours 15 min ago
Interersting. Maybe they are getting these XM-L2s from Cree without the domes ? ( as Bort mentioned the phosphor would be clean and un-damaged by gasoline.
CalvinIS
CalvinIS's picture
From my information Olight did some research into the dedome process and do it themselves.
Illumn Webstore
AlexGT
AlexGT's picture
Last seen: 1 day 49 min ago
This is what baidu says about it, google translate
M2X Javelot Ultra Thrower, OLIGHT for paranoia to build long-range portable LED flashlight, the flashlight range up to 800 m level. M2X-UT use节2 CR123A or one 18650 battery, through the transformation CREE XM-L2 LED, with the large-diameter optical glass with high transmittance lens coating, so that the light close to the ideal output effect. M2X inherited OLIGHT M series flashlight tactical operation interface to achieve on and off, or short-lit and quickly achieve the highest degree or strobe preset mode, the tail button by rotating the head. Possession of a frightened mind, having left another try again, imitation eagle pecking seeking regeneration broken, bent just to explore the distance. M2X-UT is a long-range paranoia in the hands of the killer. M2X-UT has a wealth of tactical accessories such as gun clip, filters, remote control switches, etc., suitable for hunting, law enforcement, rescue hand, outdoor, etc.
a) XM-L2 core flat light neutral white (5000K ~ 6000K) (M2X- UT)
b) 1020 lumens / 1 hour, 250 stream / 3 hours, 20 lumens / 30 hours, 10 Hz strobe (M2X-UT)
c) use a 18650 (must be with a protective plate) or Section 2 CR123A batteries
d ) wide voltage design, install the battery to extend the tube, you can use two 18650
e) pre-boot brightness rotating head, tail switches enable switch and dimming operation.
f) diameter 57 mm large-diameter aluminum smooth reflector cup
g) hardened tempered glass, double-sided antireflective film coating, light transmission rate of 99%
h) active thermal control based on running time, limit 5 and a half钟高亮subsequent gently down to within one minute of the initial luminance of 60%
i) the battery polarity anti-anti-
j) can be inverted to place
k) IP-X8 grade waterproof
material 6061-T6 aluminum body structure,
surface III hard anodizing treatment volume
length 162/230 mm,
diameter 63.00 mm
Weight (without battery) 235 g
Color Black
emitting diode Cree XM-L2 Core Battery 2 x CR123A or 1×18650 (with protection board)
output brightness level of 1020 lumens and dynamic line time / 1 hour 250 lm / 3 hours 20 lumens / 30 hours strobe 10HZ 1020 lumens / 2 hours central light intensity of 164,000 candela correlated color temperature of 5000K ~ 6000K
maximum range of 810 meters waterproof IPX8 impact one meter below the lake Hohai images from a flashlight we talk about people we talk flashlight
Reviews link http://www.shoudian.org/forum.php?mod=viewthread&tid=411917&extra=page%3D1
Someone in the shoudian forum says its a 3-4C tint
They also comment on a 5 minute to step down to 60% brightness
AlexGT
AlexGT's picture
M2X UT (This light) on the left, Fenix TK61 on the right
AlexGT
AlexGT's picture
Bort
Bort's picture
I’ll bet they read Tom E’s thread :bigsmile:
Cereal_killer
So what your saying is: it’s a jacob A60 with a higher build quality and driver?
DB Custom
DB Custom's picture
Last seen: 2 weeks 1 day ago
Me Like! And from Olight no less! Oh Saaaaaaannnnntttaaaaaaaaa……..
FlashPilot
FlashPilot's picture
Last seen: 31 min 21 sec ago
A factory dedome was bound to happen sooner or later. Too bad I couldnt get Acebeam to attempt it a few months ago.
Big Smile Big Smile “Possession of a frightened mind, having left another try again, imitation eagle pecking seeking regeneration broken, bent just to explore the distance.”
Thanks AlexGT. That has got to take the prize for the chinglish translation funnies…
18sixfifty
18sixfifty's picture
Last seen: 2 years 2 months ago
That is very cool and the description deserves a song.
I’m a junky, I mod lights so I can sell lights so I can buy more light to mod so I can sell lights to buy more lights to mod.
eebowler
eebowler's picture
Last seen: 1 week 2 days ago
Wow. Strange world this is where a popular manufacturer is designing a light out of spec by using a dedomed LED. Damit Alex. I really want a Jacob now.. Love
My gratitude to those who are willing and able to help others (in whatever way you can)! Being human is more than just existing for yourself. Smile
ohaya
Last seen: 3 weeks 13 hours ago
That’s almost exactly what I was thinking when I saw AlexGT’s pic in post #11. Looks kind of like an A60?
DBSAR
DBSAR's picture
AlexGT wrote:
!http://s30.postimg.org/ht62nsvj5/max_warrior.png!
Nice Smile that reminds me of a refined & improved Jacobs A60.
CalvinIS
CalvinIS's picture
More photos:
Illumn Webstore
Banggood
Banggood's picture
Last seen: 3 days 16 hours ago
this light will be out about next Wednesday or Thursday.
if some one are interested in making a review, pls contack me, we can get one or two sample tomorrow.
Neal
9% discount for all flashlight & Lasers
coupon code: 4BLF
Warehouse:CN
Link: https://www.banggood.com/Wholesale-Flashlight-c-1057.html?
Business inquiry
E-mail: chendongling@banggood.com
Skype: swiling88
After Sales Problems:
E-mail: cservice@banggood.com
Calmaja
Last seen: 2 years 5 months ago
Thanks for the information Calvin, at last more choice for dome / dedome version of led.
Cereal_killer
Neal
I’ve only got a handful of reviews under my belt but I have a new blog im trying to get more stuff posted on and on top of that, this particular format (1×18650 thrower) is my personal favorite, I have many conpariable lights in the class to put it up against. Please consider me for a review.
DBSAR
DBSAR's picture
Neal
Sent you a note. I have a large number of lights in this class i could to a review and comparison to, including a jacobs A60, a dedomed C8, stock C8, and other single 18650 / XM-L lights.
djozz
djozz's picture
Last seen: 3 hours 20 min ago
That took long for the manufacturers to pick up!
BTW, the various dedoming techniques are not 'BLF-originals', but Tom's dedoming thread did very thoroughly sort out for the first time which techniques are good and no good.
WarHawk-AVG
WarHawk-AVG's picture
Wonder if they are using the protective coating over the dedomed emitter, or left it bare
Xandre
Xandre's picture
Last seen: 15 hours 5 min ago
I asked Olight if it possible to take an SR 95S UT Head
dedomed XM-L2
5A driver
and a 3 18650 battery carrier
and fit it together.
That would be nice Beer
how2
Last seen: 1 month 4 days ago
Won't De-doomed led last less than Doomed leds?
If so what's the life span. Some of you guys are crazy
Mike C
Mike C's picture
Last seen: 4 min 41 sec ago
A doomed LED should die quicker than one that is not doomed…
Sorry, I couldn’t help myself… Can’t help about life span with dome or no dome though.
LSX
LSX's picture
Last seen: 1 month 2 days ago
I want to know how they are getting it sooo clean!
