PP send for 8 drivers. Thanks
Just got my beautiful drivers this morning. I’m very impressed with the professional package.
Thanks.
Drivers are as expected, package was great, and that was the FASTEST regular shipping i ever had: shipped on 3.11, recieved on 4.11.
Out of stock,so please don't send me any payments.
Any idea at this stage when you might have more of them ready?
2-3 weeks.
No worries, I will check back then. Thanks.
Subscribed
You’re turning down MONEY just because you don’t have the drivers in hand? Man, you need to talk to the Chinese companies…
:bigsmile:
I get my drivers today
Thank you!!!
Hmm, I forgot to actually post here that I ordered some. Did I make it in time? I placed my order about a week ago.
- Matt
Yes.
I found a final home for my last LD-1 today. Picked up my first Sunwayman light, got it yesterday, the little Tomahawk C20C. While it’s UI wasn’t really bad and it had a nice feature or two, it was also only able to do 1.8A. So, I pulled it’s thin aluminum star with XM-L2 emitter and fitted a 20mm Noctigon equipped with an XP-G2 emitter. Now it has a tighter hot spot and runs 4.45A making 811 lumens out the front.
Love it when a plan comes together! :bigsmile: And it’s the size of a AA light, somehow it takes an 18650. I’ve got it stuffed with a 3200mAh Panasonic BD cell for the above numbers. Should last a good long while especially in the lower modes.
Driver is solidly grounded, has a bit of a brass sink soldered in to ground as well, and is potted in a good protective layer of Arctic Alumina Thermal Adhesive.
Small package, big light, nice modes. Sweet!
I coudnt fit ld 1 in Yezl, the main issue is crossing from the original board to the LD 1-its just too much wiring and not solic contacts, but in c12 it shines, 5.02 amps!
Now i have to find a nice hd 2010, its default driver diameter is 17mm
LD 1 driver is realy nice, i would need 2 more, nice work Neven, watching the awailability like a hawk :bigsmile:
On the road X6M has potential too, but again its default driver is 30.5mm…
Thanks for support,parts for next batch are on the way.
Hy,
i put one LD-1 into a HD2010 instead of the Fasttech V10+ and changed LED from XM-L U2 to XM-L2 U3 dedomed. KLux/Kcd got up from 125 KLux/Kcd to 212 KLux/Kcd. Focussing the LED into the reflector is a pain but it´s worth it
Greetings
Kenjii
Well, finaly i was able to got ld-1 up to 3.5 amps in Y3, but the problem is there is too much wiring and crossings from the original driver to the ld1- i like it that way, yet, i will try hd2010 anyway
Whats your hd2010 version btw? There are soooo many of those…
You should start offering other parts you know, EU ppl would be interested, at least i think so
The Tangsfire TS2010 is one of the nicer variants I've seen. Can't remember where I got it..oh yeah...Old_Lumens did a group buy on it a while back. :) Still can't remember where it came from exactly. But it's nice. :)
Edit: Why don't you try it in a Eagle Eye X6? Should be an easy swap and make that little light very impressive, especially if you de-dome an XP-G2 for it. :)
True, I found that a thrower with a Y3 style and one battery fits most in my Ak103
I ordered Ultrafire hd2010 and Tangsfire HD2010 ( pretty cheap), will see whitch one has a better reflector and finnish
Sure i will try it on X6! I have one ordinary x6, i will mod it eventyaly, but i am out of drivers, i put one on my c12, the other in the y3 that i sold already, will need 2-3 ld1 , maybe more in future, its hell of a nice driver
BLF x6 i will keep intact, i like it alot
Since i became an active member here, i bought like 15 flashlights Good!, hehe
When is restock expected?
