I am wondering if there are not any UV lights out on the market that will put out this much UV?
For the uninitiated, what’s some cool things you can do with a UV light?
Keltec (?) used to use UV lights to hunt scorpions. He said the scorpions appeared pale or semi-translucent and showed up easily against the ground. I have yet to go scorpion hunting with one but a garden spider shows up pretty neat.
(maybe keltex? can’t remember, but I bought a P-60 drop-in that he highly recommended some time back and have used it to fluoresce diamonds and other jewels, pretty neat. And it is puny, severely puny, in comparison to the LZ-1)
Edit: keltex78
millipede
UV photography is fun.
Wow! Some insects look crazy awesome under UV
Yeah, most scorpions fluoresce. Only a few millipedes. 365nm is best for photography as it doesn’t paint a blue background around the subject.
Do you have a photo of just the P60 drop in? How does this compare to say the Kaidoman 365UV drop in?
The Kaidomain one is the one I’ve had, still have, and it doesn’t even begin to compare to the LZ-1. Seriously, it’s a toy beside the much better LED ENGIN emitter.
I have no idea how it compares but I’d guess (tho probably a little biased) that it kills it in every possible way lol. They just use some generic no name Chineese emitter right?
Sorry but I don’t have any pic’s of just the drop in but I’m not willing to sell it like that anyway. It looks just about standard, the only real difference is the emitter shelf thickness, the machine marks and the reflector had to be shortened (on the back side) to work with the MP1 pill.
The MP1 pills are fully machined from solid stock where a standard cheap P60 pill is stamped to shape then threaded so the emitter shelves are almost never a consistent thickness or flat (why if you search around people have came up with so many methods for flattening them). They also don’t quite fit stock, the bottom rim has to be beveled just slightly to allow them to seat fully in the head.
Thanks for the creepy crawly pic’s. I’m trying to go to bed here lol.
Just looked closer at those pic’s (don’t know why!). Man I’m glad we don’t have that crap here! There is this one bug that gives me the creepy-crawleys still- Google image “house centipede”. Those things get a few inches long and are faster than people, they bite AND sting (at the same time if you piss ’em off enough). That’s enough for me. I’ll take spiders any day (tho there are lots of spiders that glow in UV too and that makes anything more spooky).
The strobing really makes stuff stand out btw, just incase glowing brightly isnt enough on its own it strobes at 22.5Hz too.
If you can program for me a mode where it blinks once every 2-5 min ill take it.
you have a very specific need ???
Just an idea, no real idea of how well it will work comparatively though. Im looking to do something similar to the muel light that uses leds and gitd bits set in epoxy that was posted here a while ago. But I want it to be more p60 based, the cf host is just a bonus.
I’m not a fan of house centipedes either. Always been glad they apparently don’t bite often and may not be able to break the skin.
I’ll take spiders too over centipedes. Well, as long as they are not too large.
Caught this big spider once. Size of the palm of my hand. Grabbed him with thick leather gloves and damn, I could feel the sob struggling hard through the gloves. Strongest friggin bug I’ve come across. Found it 2 feet from the head of a family member who was laying on the floor watching tv. Just caught sight of its two legs visible under a table and I could tell it was a big spider. Probably still have it in a jar in the basement.
Thanks for the clarifications DBCstm and cereal_killer.
Wow! A huge difference. Thank you for the pics.
Looks like my camera auto-corrected white balance to make white appear white, the LZ-1 is so intense that white paper glows vividly 365nm, so much so that if you’re shining the LZ-1 into a room that has little or no phosphorescent objects the light seems dim, then a single object that reacts actually lights up the room with it’s vivid glow!
I put the camera (Canon G1X) on a tripod in manual mode, 1/4 sec at f/5.6 and ISO1600 on a 2 second timed exposure then took these shots. 28mm equivalent, about 8’ distance to the box with USPS shipping label glowing brightly. The only thing I did in Lightroom 4 is add the watermark and downsize. Then downsized again from Photoshop after making the animated GIF.
I’ve got my LZ-1 set up at 700mA, the Kaidomain drop-in does 310mA off a Sanyo FJ cell, but drops with a 25R to 280mA. It’ll take multiple cells and the amperage drops accordingly.
That pic is actually somewhat misleading, as it makes the Kaidomain look better than what it is. lol If shining at the ground looking for bugs, the Kaidomain barely makes a hot spot…you just about have to bend over and get it closer to the ground. The LZ-1 easily makes an intense area of coverage while standing, even reaching out to the surrounding area so you can find something and then hone in on it.
And in the Solarforce L2m, I have an AHorton aspheric under the bezel such that unscrewing the head about a 1/4” focuses the die into a square pattern…dependent on distance of course. I used one of Mattaus’ copper shells and a copper spacer from RMM in the host. Just saying that my set-up is not the same as Dan’s. And I’m not running my LZ-1 as hard either. I’m using a standard Qlite with 6 chips removed.
How is the output compared to the Nitecore CU6? I note that Nitecore claims 3000mw of UV which seems pretty outrageous if true. The Nitecore looks a little more versatile too with the white mode and the RGB small LEDs.
http://www.nitecore.com/productDetail.aspx?id=104#.VF-CD2fYfQI
