Test/Review of Efan IMR18650 3200mAh (Purple)
3 posts / 0 new
HKJ
HKJ's picture
Last seen: 3 hours 16 min ago
DSC_6552
Official specifications:
  • Capacity: 3200mAh
  • Nominal Voltage: 3.70V
  • Standard Charge: Constant current 1250mA, Constant voltage 4.20V, End current(Cut off) 50mA
  • Fast Charge : Constant current 4000mA, Constant voltage 4.20V, End current(Cut off) 100mA
  • Max. Charge Voltage: 4.20V
  • Max. Charge Current: 4000mA
  • Standard Discharge: Constant current 500mA, End voltage(Cut off) 2.5V
  • Fast Discharge: Constant current 10000mA/20000mA, End voltage(Cut off) 2.5V
  • Max. Discharge Current: For continuous discharge 20A
  • Weight Approx.: Max. 48.0G
  • Operating Temperature: Charge 0 ~ 50°C, Discharge -20~ 75°C
  • Storage Temperature: 1 month -20 ~ 60°C, 3 months -20 ~45°C, 1 year -20 ~ 20°C
  • Dimension: (D)18.3 + 0.2/-0.3 mm (H) 65.0 ± 0.2 mm
Efan%20IMR18650%203200mAh%20(Purple)-info
This is a modern high current 18650 cell with good capacity.
DSC_6550 DSC_6551
DSC_6553 DSC_6557
DSC_6554
DSC_6555
DSC_6556
Efan%20IMR18650%203200mAh%20(Purple)-Capacity
It does fine up to 10A, but above that there are significant looses in the cell.
Efan%20IMR18650%203200mAh%20(Purple)-CapacityTimeHours
Efan%20IMR18650%203200mAh%20(Purple)-Energy
Efan%20IMR18650%203200mAh%20(Purple)-PowerLoadTime
Efan%20IMR18650%203200mAh%20(Purple)-TripCurrent
Efan%20IMR18650%203200mAh%20(Purple)-Charge
Conclusion
This cell has good capacity for a high current cell, it does not really handle 20A, but looks good at 10A.
Notes and links
The batteries was supplied by Efan for review.
Compare to 18650 and other batteries
Chicken Drumstick
Last seen: 10 months 1 week ago
Are these any relation to the Efest 3100 20A cells? They look almost identical. Thanks for the review.
HKJ
HKJ's picture
I do not know it, but I agree, they are a good match in the comparator.
